Nov 02, 2015, 11:41 AM
Si Vis Pacem Para Bellum!
Doubletap's Avatar
New Product
Hobby People QUEST 2.1M EPO Glider w/ 4 Servo Wing
Hobby People QUEST 2.1m EPO 4 servo wing glider.
http://www.hobbypeople.net/media/cat...1/1/117218.jpg
http://www.hobbypeople.net/media/cat...1/117218_b.jpg
http://www.hobbypeople.net/index.php...x/?p=1&q=quest
Hobby People Quest 2.1M
Rx-R Brushless-Powered High-Performance Electric Sailplane
This is a Hobby People Quest 2.1M Rx-R Brushless-Powered High-Performance Electric Sailplane. The Quest - a thermal seeking high performance molded-foam sailplane for those who are ready for more! Developing the Quest meant keeping the advanced and beginner pilot in mind. From the fuselage with a bolt-on tail and landing wheel to the powerful 800Kv brushless motor for quick climb-outs, every detail was considered to enhance your flying experience. We scrutinized every element and material for a foam glider. The 2-piece wing utilizes a sleeker airfoil, allowing the Quest to glide from one end of the field to the other in search of a thermal or speed at the slope. The elegant design of the fuselage reminds you of a great looking sailplane with enough room to introduce your own accessories, such as FPV and LED lights, all without losing sight of the basics.
The first thing you notice after you install the wings is the large presence of the Quest. The Quest has a wingspan of over 6 and a half feet! That’s 527 square inches of wing surface for the Quest to easily float with the lightest of thermals or rising air at the slope - all while keeping the Quest flying weight down to 42 ounces. The included ESC will allow for 35 amps of continuous current draw and 2 to 4 cell Li-Po batteries. It's also programmable, allowing you to adjust Battery Type, Voltage Cut-Off, Acceleration, Timing and Brake (requires optional programming card, sold separately).
Sometimes the need for speed is necessary! The included 800kv brushless motor gets the Quest to altitude fast! Combined with it's large 12x8 folding propeller, it delivers the power you need and folds tight against the fuselage, eliminating power-off drag. The Quest includes efficient air ducts for cooling the motor, ESC and Li-Po battery. A scale-like landing wheel is included to allow you to perform scale-like landings.
This Rx-R version of the Quest 2.1M features preinstalled flaps, so you can add crow and other advanced sailplane features to your flying experience. A radio system, battery and charger are not included and must be purchased separately. See the Items Required, But Not Included section below for a complete list.
Features:
• EPO Molded Foam Construction with Decals Applied
• Quick and Easy Final Assembly - No Glue Required
• Two-Piece Wing with Carbon Fiber Wing Joiners and Removable Tail Assembly
• Advanced Blended Airfoil and Center-Mounted Fuselage Landing Wheel
• Removable Canopy with Strong Snap Latches Allow Easy Battery Access
• Dual Aileron Servos for Precision Control
• Dual Flap Servos for Advanced Sailplane Mixing
• 3536 800kv Brushless Motor and 2S to 4S 35 Amp Brushless Programmable ESC with Brake
• 2-Blade 12 x 8 Folding Propeller for Efficient, Low Drag Power-Off Gliding
• Servos Installed with Control Linkages Ready for Final Setup Adjustments
Specficiations:
• Wingspan 82.7 inches (2100mm)
• Wing Area 527.0 square inches (34.0sq.dm)
• Length 45.5 inches (1155mm)
• Weight (Approximately) 42.3 Ounces (1200g)
• Wing Loading 11.6 ounces/square foot (35.3g/sq.dm)
Items Required, But Not Included:
• 5-Channel or More Radio System*
• 3S 11.1 Volt 2200mAh 20C Li-Po Battery
• AC or AC/DC Li-Po Balance Charger
• Double-Sided Foam Mounting Tape
• Hook & Loop Mounting Material
*This Rx-R version of the Quest features two separate aileron servos and two separate flap servos, each joined with a Y-harness. This allows you to control the ailerons and flaps independently using a 5-channel radio system. If you would like to separate each of the aileron and flap servos to enable advanced sailplane functions, such as aileron differential mixing, crow mixing and more, the Y-harnesses can be removed and the servos can be plugged into your receiver separately. A 6-channel or more radio system that supports advanced sailplane programming and flight modes, such as the Airtronics SD-10GS (P/N 751755) will be required.
New Product Hobby People QUEST 2.1M EPO Glider w/ 4 Servo Wing, RxR & RTF Doubletap Foamies (Kits) 6 Feb 17, 2016 05:26 PM
