Apr 18, 2016, 10:28 AM
Has anyone bought the full combo with servos? I'm mighty tempted at Banggood's current price of $435 for everything.
Apr 18, 2016, 07:43 PM
Crashing regularly since 2013
FlyingPhilUK's Avatar
Nope - I got the Motor/ESC Combo
- and went with Turnigy Servos
- the Super Combo looks good though
- probably very similar servos to the Turnigy ones
Apr 19, 2016, 04:21 PM
conbones's Avatar
by buddy got the full kit and the servos are great prety much the same as i run in mine and you cant beat the hobbywing 60 amp esc.
dont know about the motor though i have not seen it in action.
Apr 19, 2016, 06:00 PM
I'd say the Alzrc motor is pretty good
- apart from the shaft coming out
- which is easy to fix (preventively)
Apr 22, 2016, 06:03 AM
Newbie RC'r and member
felixthemaster's Avatar
How are the ALZRC 380 blades? I heard someone's blades ejected in flight.
Apr 22, 2016, 09:29 AM
The tail hub has been known to come apart in flight
- so, most people upgrade to the Goblin part at some point...
I've not had any problems with the ALZRC blades
- but I'm now running Zeal mains and Goblin tails
Apr 22, 2016, 09:33 AM
They aren't very good to look at aesthetically and geometrically, but as long as they work, it's a cheapo way to try 380 blades on my X3. I wonder why they just angle off the tips like that in cheaper blades.
May 01, 2016, 03:20 PM
taking time on my ride
IFHELI's Avatar
Could not resist any longer.......
May 01, 2016, 03:27 PM
Looks nice
- how much?
- where from?
May 01, 2016, 03:37 PM
IFHELI's Avatar
Bought kit from Banggood.
Total cost shipped was $267.50.
May 01, 2016, 03:41 PM
OIC, I thought it was just a new canopy
So how many Devil 380s do you have now?
- must be three, I reckon!
The canopy is available separately,
http://www.banggood.com/ALZRC-Devil-...p-1047343.html
Plus the new white/red one:
http://www.banggood.com/ALZRC-Devil-...p-1049727.html
May 01, 2016, 03:48 PM
IFHELI's Avatar
I have been waiting for the canopy / boom to be for sale and finally gave up and bought the kit. I have three Devils and one G380.
May 01, 2016, 06:33 PM
Do you get tail blow-outs on the G380 & Devil 380?
- i've had 2 or 3 tail-blowouts on my G380, which I thought perhaps meant that the HS was too low
- however, I managed to get a tail blow-out on the Devil 380 today
- it usually happens when I give it maximum collective, plus maximum cyclic
- perhaps, I need to reduce the cyclic travel?
May 02, 2016, 01:58 PM
Seems to be a common enough problem if the HS is below 3000rpm
- so, i should probably up the HS, or get one of these:
http://www.anythingheli.com/sab-alum...up-goblin-380/
May 02, 2016, 03:59 PM
IFHELI's Avatar
I wonder how I missed that on Banggood. Oh well I don`t mind having another one flying. I set it up with a higher HS so it is snappier than the other two Devils and G380. I just swapped pinions on the G380 so it will be close to my new Devil on setup.
I have never had what I would call a blow out of tail on any of them. I run from 3400 to 3600+ HS. What I have been getting is a slight bobble when doing tic-tocs or rainbows. I installed the tail tensioner on all three Devils this weekend. When I flew the new Devil and 2nd Devil the tails were solid. On Sunday I order a tail tensioner for my G380.
If you are running low HS then you should try either speed up tail gears from SAB or ALZRC. SAB is a 20T and ALZRC states theirs is a 19T.
Sold 380 Fast Alzrc Devil 380 cool cat Aircraft - Electric - Helis (FS/W) 1 Mar 11, 2017 03:28 PM
