This thread is privately moderated by hapyjac2, who may elect to delete unwanted replies.
Oct 31, 2015, 11:46 AM
Trader Rating: 88
AMA CD
hapyjac2's Avatar
$160.00 USD
Seller Pays Shipping
Sold
Evolution 10GX 10cc 2-Stroke Gas Engine
Only slight use, Still mounted on Hanger 9 P-51 that it pulled with authority. Not flying so dismantling plane,
Air frame will go cheap but I wont ship, local pickup only, and will include electric retracts and lots of spare parts, even the original box & manual. Only after the engine is sold. Or I'll make a Killer deal for Plane RR RTF. Battle tested, but still fly's great.
INFO:
This is the Evolution 10GX 10cc 2-Stroke Gas Engine. Glow engine enthusiasts that are looking to propel their .46- to .61-size models with an engine that is both inexpensive to operate and extremely easy to tune, look no further! The Evolution 10GX engine is the smallest gas 2-stroke engine available, and was designed to fit traditional mounting spaces so there is no special installation necessary.
This 10cc engine is a special mill. Not only due to the fact that it is extremely small for a gasoline engine, but also because it allows enthusiasts who love operating fuel powered models the opportunity to experience the ease of tuning and fuel savings associated with gas power plants that is not found with high cost nitromethane fuel systems. The 10GX offers performance and savings, but it is also very lightweight and perfect for a variety of .46- to .61-size applications.
Features:
Gasoline engine lowers operating costs as much as 90%
Standard 40- to 46-size beam mount allows for traditional mounting
Light weight means better performance
Uses a 5% oil mixture with gasoline for less mess at the end of the day
Ignition case is half the size of traditional ignition cases for more mounting options
Exceptionally broad torque range supports propeller sizes from 11 x 7 up to 13 x 8
Specifications:
Type: 2-stroke gas airplane engine
Displacement: 0.59 cu in (9.83cc)
Bore: 0.94 in (24mm)
Stroke: 0.85 in (21.5mm)
Cylinders: Single
Total Weight: 22.0 oz (627 g)
Engine (Only) Weight: 15.3 oz (436 g)
Muffler Weight: 3.25 oz (93 g)
Crankshaft Threads: 1/4 x 28
Benchmark Prop: EVO 12 x 6 @ 11,100 rpm
Prop Range: 10 x 613 x 8
RPM Range: 2,30018,000
Fuel: Gasoline 8792 octane, 2-stroke oil 20:1 gas/oil ratio
Muffler Type: Expansion chamber (included)
HP: 1.68 hp (1.7 PS) @16,400 rpm
Cylinder Type: ABC
Asking $160.00 shipped no box But I have the original manual.
Nov 02, 2015, 08:25 AM
Trader Rating: 6
Can you post some pics of the actual engine do we can see the condition.
Nov 02, 2015, 09:44 AM
Trader Rating: 88
AMA CD
hapyjac2's Avatar
Photos up
Nov 03, 2015, 07:32 AM
Trader Rating: 55
the carb is pressure fed right not a pumped carb.
Nov 03, 2015, 07:43 AM
Trader Rating: 88
AMA CD
hapyjac2's Avatar
It is a Pressure fed carb.
Nov 04, 2015, 03:15 PM
Trader Rating: 6
PayPal Sent
