Thread Tools |
This thread is privately moderated by DexSnake, who may elect to delete unwanted replies. |
Trader Rating: 28
$520.00 USD
Seller Pays Shipping
For Sale
Team Associated RC8 B3e Team 4WD 1/8 Electric Buggy Kit
I have a brand new factory sealed in the box Team Associated RC8 B3e Team 4WD 1/8 Electric Buggy Kit.
Free shipping with insurance to the lower 48. Let me know if you have any questions. Features: 7075-T6 hard anodized aluminum chassis features an optimized weight bias layout for improved handling and stability Front suspension features pillow ball uprights for increased adjustability and improved durability Lightweight ring gears and optimized precision ball bearing sizing reduces drivetrain rotational mass for improved acceleration and battery efficiency Gearboxes feature a 3.38:1 internal gear ratio with fast-access differentials for quick removal, tuning, and maintenance Six universal drive shafts for efficient drivetrain power delivery and ease of maintenance 7075-T6 aluminum 16mm Big Bore threaded shocks with TiN coated 3.5mm shafts, larger diameter precision springs, and optimized bladders for more precise volume compensation 7075-T6 aluminum shock towers front and rear feature finely tuned shock mounting and upper arm positions Refined suspension geometry with lower hinge pin inserts for quick and easy roll center adjustments Lightweight one-piece wing mounts feature height and forward positioning adjustment for more precise handling Two-piece sliding motor mount for easy gear mesh adjustment and motor removal Pro-Line RC8B3e clear body and Team Associated molded wing included The RC8B3e shares over 90% parts compatibility with the RC8B3 nitro buggy, offering the perfect solution for multi-class racers Specifications: Scale: 1/8 Power: Electric Length: 488mm Width: Varies based on setup Weight: Varies based on setup Wheelbase: 327.3mm Drive: 4WD Needed to Complete: 2 channel radio/transmitter & Transmitter batteries 1/8 Scale Specific Speed Control, Motor, and pinion (see motor manufacturer’s gearing recommendations for correct pinion size) 4S LiPo Battery & Charger High Torque Steering Servo 1/8th scale buggy tires, wheels & CA glue Polycarbonate paint for body Tools |
Trader Rating: 1
Rc8
Hi,I was interested but they sell for new $540 ?
