Oct 29, 2015, 03:36 AM
New Product
RedRotor RROSD Pro Mini PDB
We are proud to announce our latest addition to our OSD product line… the RedRotor RROSD PRO PDB!
What is it?
Simply put, the RROSD PRO PDB is an easy to use power distribution board and OSD designed to maximize FPV experience while minimizing mini quad build time and reducing the wire clutter mess!
Download User Manual
FEATURES:
  • Dimension 36mm x 36mm (30.5mm x 30.5mm mounting holes)
  • Built-in power distribution and beefy regulators to handle 3S-6S Lipo
  • Built in multi stages power filter for Video Transmitter and Camera with pre-installed and conveniently located connectors
  • 12V and 5V output: can be used for FPV cam, VTX and accessories
  • NTSC and PAL can be easily selected using the onboard button
  • Plug and Play (PnP) OSD information: Flight pack voltage, current draw, total current consumption, RSSI, flight timer, Lap counter&timer
  • Maximum motor current 100A total
  • Automatic flight timer shows actual flight time
  • The additional lost model buzzer sounds off 5 minutes after the quad has crashed.
  • RSSI detection (FRsky ppm and analog compatible) displays in percentage
  • Auto Battery alarm blinks the battery voltage when pack voltage hits the low limit
  • Low RSSI turns on Buzzer (very handy to locate a downed quad)
  • Battery pack alarm feature blinks the battery voltage when pack voltage hits the set limit
  • Onscreen menu allows user to calibrate pack voltage reading, rssi input, battery alarm level…etc....
  • Firmware upgradable to ensure any user can enjoy any new features that we might release the future (optional programmer is needed)
Optional Features:
  • Lap counter and Timer
  • Lost model siren
Where can I order one?
RedRotorrc.com $35
Distributors:
USA - http://www.readymaderc.com/store/
USA - http://www.2dogrc.com/
USA - https://www.multirotorsuperstore.com...rrosd-pro.html
Singapore - www.dronematters.com
Canada - http://rotorgeeks.com
RROSD Pro Introduction (6 min 36 sec)
RedRotor RROSD Pro Mini PDB (6 min 6 sec)
Very helpful tips on Firmware Upgrading by Joshua Bardwell
RROSD Pro Firmware Upgrade How-To (8 min 44 sec)
Oct 29, 2015, 03:37 AM
Lap
RROSD Lap Timer:
The Lap Timer takes competitive fpv racing to the next level by providing the pilot with real time information on lap #, current lap time and best lap time
FEATURES:
Very easy to setup
Light weight transponder ~2g
Single Base station can support unlimited number of tranponders
Low power consumption, a 2S 1000mAh battery can power the base station for over 30 hours continuously
Supports race gate as tall as 15' high by daisy chaining IR Addon module for every 3' high gate. Starter kit works well for gates up to 5'x6'
http://www.redrotorrc.com/index.php?...product_id=117
RedRotor RROSD PRO Mini PDB (W/Lap Timer) Intro (1 min 50 sec)
Oct 29, 2015, 03:50 AM
Reserved for more info...
Oct 29, 2015, 10:40 AM
Dirty Side Down.......o~^o
Hiway's Avatar
I am gonna reach out.... seems you found a way to lull me back to the RedRotorz crew here maybe, lol.
Oct 29, 2015, 12:02 PM
Setup for the ilaps transponders? Pretty cool stuff.
Oct 29, 2015, 12:05 PM
QuAd FaNaTiC
Razors edge 29's Avatar
Looks good.
Wished read out looked more like strider however
Oct 29, 2015, 12:06 PM
This looks great! The only thing I think it's missing is what most osd's are missing... a name plate so we know in a race who is who.
Oct 29, 2015, 12:56 PM
Hiway, Can't wait to see your build magic if you decided to give this board a try
Thanks! the ilaps and RROSD Pro are similar but there is one main difference. The ilaps system records the flight time of each quad locally on a laptop connected to the sensors on the gate.
The RROSD Pro displays the lap time on each quad OSD in real time.
Originally Posted by Razors edge 29
Looks good.
Thanks Razors! I should mention that the firmware for both Strider and RROSD Pro are interchangeable
Great idea! I'll try to implement an assignable ID for each quad. How about a two letter initials!?!
Oct 29, 2015, 01:21 PM
Team Crash
Ordered! Looks great. Thanks for the heads up Tony.
Oct 29, 2015, 01:30 PM
"Furadi"
Conradm's Avatar
That's something you can do in your cam OSD.
Oct 29, 2015, 01:36 PM
RedRotorRC's Avatar
Thanks for the preorder!
Good info Conrad! many people including myself did not know this
Oct 29, 2015, 01:52 PM
"Furadi"
Conradm's Avatar
Yep yep, you just set the title and you can position it where ever.
Oct 29, 2015, 02:07 PM
What size is the current sensor for the osd?
Nevermind ..I see it now.
Oct 29, 2015, 02:09 PM
Bonus.. do all cams have that feature?
Oct 29, 2015, 02:14 PM
"Furadi"
Conradm's Avatar
Hmm not sure but I think any version of the Sony Super HAD ii does. (pz0420, hs1177 ect)
