Oct 23, 2015, 04:14 PM
shschon's Avatar
New Product
Unique Models LTV XC-142 Experimental RC Airplane
Anyone tried this yet?
IN ACTION - Unique Models LTV XC-142 (3 min 34 sec)
Unique Models LTV XC-142 Experimental RC Airplane PNP-banggood.com (1 min 19 sec)
Ling-Temco-Vought XC-142A Promo Film - 1967 (19 min 34 sec)
ONE OF A KIND us air force XC 142 VTOL Aircraft (10 min 6 sec)
http://www.banggood.com/Unique-Model...p-1003834.html
Oct 24, 2015, 08:25 AM
The model shots never dwell on the transitioning phase of the flight.
Peter
Oct 24, 2015, 03:18 PM
shschon's Avatar
Peter
First video about 3:00-3:06 there is a transition from plane back to heli mode.
Nov 09, 2015, 07:37 PM
Xc-142
I just ordered one from Banggood and three 4s 2600 Lipos off eBay
Nov 10, 2015, 07:37 PM
Flying is Fun.Even if U Crash!
Claydoc's Avatar
Please let us know how it all works out!
Nov 10, 2015, 07:38 PM
Claydoc's Avatar
I have the Canadair CL-84 of theirs... good fun machine.
Nov 15, 2015, 09:49 PM
I ordered one too but I ordered two 2600 6S lipos as per the spec sheet and advert.....
Nov 15, 2015, 09:54 PM
RCvertt's Avatar
What kv are the motors? 6 cell, they must be rather low or it would break the sound barrier.
Nov 20, 2015, 05:55 PM
bouncebk2003's Avatar
Wow!Coolest model I have seen!I am very tempted to order one.Maybe as a Christmas present to myself!
Nov 20, 2015, 06:08 PM
Well,I couldn't wat.Just ordered one!
Dec 21, 2015, 03:07 PM
I got CL-84, but now it is stored in the hangar, the reason is that it is almost not possible to turn.
The controller in FF keeps the wings level so it affects the aileron commands the turn radius is about 150-200m.
Appreciate if someone can share his FF experience.
Shraga
Dec 21, 2015, 03:46 PM
RCvertt's Avatar
That doesn't sound good. Even with an auto-level feature the TX should take priority over the airplanes controller sensors.
Sounds like you are screwed if you stay with that controller. You can try some old tricks that the flight controller will still try to fight. Shorten the aileron horns on the ailerons. Or lengthening the servo horns if they use a wire to move the ailerons. Shortening your TX sticks may also help.
Dec 21, 2015, 05:56 PM
Ran D. St. Clair's Avatar
Shraga
Before you do anything mechanical, just max out the TX output throw, volume, endpoint, or whatever it is called in your TX.
While I do not have direct experience with their flight controller, I do have a friend with their CL-84 similar model. They do not want you getting those models upside down or doing aerobatics with them. The CL-84 could probably physically do it if not for the FC limitations. The XC-142 might not survive the attempt. I know this from my own design XC-142 model which has tumbled (and crashed) many times.
They are just trying to keep you from crashing and while they might have gone a little overboard, you need to accept that this is a difficult model to keep in one piece. The scale proportions are marginal on directional stability in forward flight, and it's a VTOL as well. it's not a sport model. Not by a mile.
Jan 01, 2016, 12:53 PM
jmcclv's Avatar
Hi
Any idea of flight time we can expect ?
Do you think i can add FPV system ?
JM
Jan 01, 2016, 01:42 PM
RCvertt's Avatar
Most likely 8 to 9 minutes without FPV gear. From the looks of the transition FPV might be disorientating.
