Oct 22, 2015, 02:20 PM
RMRC
McSkies's Avatar
New Product
RMRC Goby 180 & 210
We are proud to release the RMRC Goby 180 multirotor frame!
No waiting, its here NOW!
Features:
True "X" 180mm design to give you the ultimate flight experience
Multiple different frame configurations
Durable, 4mm single piece main frame with Limited Lifetime Warranty
Specifications:
Main frame: 4mm carbon fiber, 56g
Battery plate: 1.5mm carbon fiber, 6.0g
Top plate: 1.5mm carbon fiber, 4.5g
Total frame weight: 66.5g (without hardware)
180mm (motor to motor)
RMRC
McSkies's Avatar
Available Now! RMRC Goby 210 frame for 5" props
Oct 23, 2015, 08:20 AM
Kevin forgot to mention it was designed for 2204 motors and 4s
We are very proud of this frame and are so confident of its strength we are offering a lifetime warranty on the main plate!
Oct 23, 2015, 01:19 PM
Looks awesome, but I'm missing a mounting hole for the FPV antenna.
Also, is there any distributor in europe for these? Shipping and customs kinda ruin things for all of these awesome 180 frames.
Oct 23, 2015, 01:29 PM
n_B
n_B
Nice! I like the look of that battery plate. Will the Mudskipper be similar in design?
Oct 23, 2015, 01:50 PM
we thought about the SMA, and figured it is just as easy (and usually stronger) to use a right angle adapter. We currently do not have any distributors for this frame... Our shipping coupon should help though!
Thank you! The battery plate can be rotated different ways to assist strapping different size batteries!
The Mudskipper is TOTALLY different and is coming very very soon!
Oct 23, 2015, 08:49 PM
choopi's Avatar
This a real nice frame! I may have to get one to have a closer look!
Oct 23, 2015, 10:53 PM
astroX, Warpquad,Geprc,Diatone
Will the arms accommodate 1806 size motor bolt spacing as well as 2204? (without modification)
I just bought one assuming it will as I intend to use these motors on it, they are in between 2204 and 1804 size motors (perfect for a little more oomph than your typical 1804/1806 size motor without shortening the run time as much as 2204's due to lower weight and less amps to run) but they do have the smaller bolts and bolt pattern of the 1806 motors. Hoping I won't have to pull out the dremel to get them mounted on the goby arms.
Oct 24, 2015, 08:22 AM
Without knowing the exact bolt pattern of the motors I cannot say for sure if they will fit, but they definitely should! The hole pattern on the arms was designed to be as universal as possible.
When you get it please post and let us know what you think about it! I hope you love it
Oct 24, 2015, 11:16 PM
KD0ZET
Sheldon 78's Avatar
What size props are a good start w/ 2204 2300KV and 3S batts?
Oct 25, 2015, 12:47 PM
6x4.5 works well. Lately I have been using 5.5x4.5 too, they still give really good performance without working the motor (or battery) quite as hard as the 6x4.5's I used to run.
Oct 25, 2015, 02:11 PM
I void warranties
Candyman, are you saying this little thing takes 6" props?!
That's awesome if so! I don't know of any other 180's that take >5"ers.
Oct 25, 2015, 02:44 PM
roostnureye's Avatar
subscribed!!!
Oct 25, 2015, 05:34 PM
Hi Sheldon,
This quad was designed to run 4" props. With 2204 motors you would be very happy with 4x4.5 props. They provide excellent response with both 3s and 4s
Oct 25, 2015, 10:06 PM
oops, sorry , thought I was in a different thread for a 250mm quad when I replied
A 2204 will run any prop available in 4 inches without even breaking a sweat.
Hoping to see a 4x4.5 3 blade prop at some point from hqprops.
