This thread is privately moderated by myrcmodel, who may elect to delete unwanted replies.
Oct 22, 2015, 04:01 AM
myrcmodel's Avatar
FatShark ATTITUDE V3 FPV Goggle Headset w/Trinity Head Tracker
The Attiude V3 FPV goggle is the newest version from Fat Shark, which has moved the beautiful Dominator V2 optics into a new modular designed Attitude V3 and added support for 3D cameras based on interlaced 3D solution.
http://www.arrishobby.com/fatshark-a...tracker-p-3034
Optional diopter inserts (-2, -4, -6) are available for those with less than perfect vision, allowing these goggles to be used by a majority of glasses wearers. Inter Pupil Distance (IPD) adjustment allows the goggle fit to be adjusted to for nearly any face. AttitudeV3 is compatible with the Fat Shark fan equipped faceplate for extra comfortable fit and fog free viewing (not included). The 32 degree diagonal FOV display strikes a perfect balance between large screen immersion and compact pixel density clarity. Fat Shark again proved to be a real supporter of the FPV market and a market leader in the video goggles market with this new release.
Attitude V3 ships with 1000mAh battery pack, 32 channel 5G8 RaceBand receiver and SpiroNET circular polarized antenna.
Headset Specifications:
Optics FOV (field of view): 32˘Xdiagonal (Image size: 1.3m @ 2m)
Type: Plastic optic module
Interpupillary distance (IPD): 59 ˇV 69 mm (adjustable)
Supports optional diopter lens inserts: -2, -4, -6 dpt
Audio Stereo (requires adjustable volume earphone accessory)
User Controls Channel selection/ head tracker reset
Mode selection (wired/wireless)
Contrast/ brightness control/ 2D or 3D
mode selection
Electrical Power supply: 7 - 13 V (2S/3S supply)
Power consumption (@7.4V nominal): 320mA wireless; 200mA direct mode (RX off)
DVR: None
RF Modules (Optional): multi channel and band support (modular RF)
Antenna External dipole (RX is circular polarized compatible)
Mechanical Ergonomic molded headset w/ adjustable headband
Secured rubber eye cups for ambient light reduction
Weight: 150g
Display Full color LCD polarized LED backlit
Binocular display (640 X 480 VGA)
NTCS/PAL auto selecting
2D / interlaced 3D
Head Tracker 9DOF 2-axis
Battery 7.4V 1000mAh Lipo Battery
Interface 3.5mm AV in/out port
Power in port
3.5mm stereo earphone port
Mini DIN head tracker data port
Note Compatibility is only guaranteed with Fat Shark and ImmersionRC transmitters.
5G8 RaceBand Receiver Specifications:
Power supply 3.3~5 V
RX Sensitivity ≤ -90 dB
RF Input Level -90 dBm~+5 dBm
Video Format NTSC/PAL
Operating Temperature -10~65 ˘X
Size 42 x 25 mm
Weight 10.8g
Operating Frequencies:
Band 0-0 (FS/IRC) 5740, 5760, 5780, 5800, 5820, 5840, 5860, 5880
Band 0-1 (Boscam E) 5705, 5685, 5665, 5645, 5885, 5905, 5925, 5945
Band 1-0 (Boscam A) 5865, 5845, 5825, 5805, 5785, 5765, 5745, 5725
Band 1-1 (Raceband) 5658, 5695 5732, 5769, 5806, 5843, 5880, 5917
Package Includes:
1 x ATTITUDE V3 Headset
1 x 5G8 Receiver Module (32ch with RaceBand)
1 x 7.4v 1000mAh Lipo Battery
1 x 5.8Ghz Circular Polarized Antenna
1 x Discharge Lead
1 x Carrying Case
