This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Oct 18, 2015, 03:20 PM
Jack Crossfire's Avatar
Odriod I/O
So the Odroid has a 2nd UART on its 30 pin header, the STM32 board has another unused UART, but it isn't exposed on any pads & no-one was in the mood to make a new board. Back to SPI it was. Based on goog searches, getting SPI to work on the Odroid is a big deal. It wasn't expected to be as easy as the PI because of the small userbase & expectations didn't disappoint. Where the PI has a gootube video on every minute subject, in plain english, the Odroid documentation consists solely of gibberish like "download code" or "just change the dtb". The PI would officially come nowhere close to the required processing power.
Finally, ended up bit banging the SPI using simple writes to the /proc filesystem to change GPIOs. This achieved 3.33kbit while all 4 CPUs were processing video at 50%. Since each bit contains 3 sleep statements, it's a sign the kernel was switching tasks at 10khz. Without sleep statements, it went at 38kbit with spurrious gaps of 100us. 100us is a 10khz frequency.
38kbit is too fast for the STM32, which also uses software defined SPI. 3.33kbit can send only 13 bytes of information per frame at 30fps. All problems would be solved by making a new STM32 board with another UART. Just this small amount of bit banging made a 1% increase in CPU usage on all of the Cortex-A7's.
Finally, the GPIO voltage was only 1.8V, so level conversion transistors had to be soldered to bring it up to 3.3V. The mane problem is now fixing the Odroid to the vehicle.
