Nov 04, 2015, 09:30 AM
AMA 697691 / FAA 13675
Interesting reaction to a purely academic question. I don't need to measure current on my applications so I was curious why others wanted to read current. Although RTFQ has nothing to do with my question, I think gervais was pretty much on target.
Referencing my issue 14 of AMP'D called, Storing Lithium for Longevity, you can see that with Lithium Polymer batteries, the voltage alone can be used as a "gas gauge".
This comprehensive list from MaoChris is an excellent answer. Thanks!
There are several benefits for current reading during flight:
- Calculation of used capacity from the LiPo.
- Fine-tuning of LiPo/motor/propeller combinations.
- Set up of an maximum allowed current controlled by the FC.
- Figure out the current change of the MR with different payloads.
Nov 05, 2015, 03:49 AM
MaoChris's Avatar
Referencing my issue 14 of AMP'D called, Storing Lithium for Longevity, you can see that with Lithium Polymer batteries, the voltage alone can be used as a "gas gauge.
To some degree your statement is right Greg. However, the voltage of a LiPo pack is depend on many factors, like IR, current consumption, size of the cables in the MR and how many connectors are installed before the actual voltage measurement. So to define the remaining capacity in the cells just by the voltage is a bit difficult and differ from pack to pack as well as if you use the same pack in a different bird.
So I do believe, the current measurement version (converted to consumption / mAh) is more accurate.
REM: This is my personal opinion, so please don't shoot me out of the sky.
Nov 05, 2015, 04:42 AM
MaoChris's Avatar
What is the accuacy ? Any QC ?
I got quite some of these questions via PM's and I thought I better post the answers here.
To post here all the quality control during the production would be a very long story, so all I can say is, that it is carried out and recorded.
The final QC before the boards are shipped, is a setup with an FC (Pixhawk) and connected to MissionPlanner to check the calibration values for current and voltage measurement.
This final test result will be passed to the customer together with the order confirmation and shipment tracking number by e-mail.
REM: Which power module supplier out there actually use the PM to power up a real FC before shipment ?
So I hope everybody understands, that if I say "safety first"... then I mean it.
Nov 05, 2015, 02:38 PM
Made in Germany
Really ? I donīt remember one "flash protocol" for a PM (and I bought several) .
Others would sell this as calibrated or think thats too much...
Nov 05, 2015, 04:51 PM
OK, here it comes... a really, really, and I mean really, stupid question:
Why are there two red wires and not black/red going in and black/red coming out???
thanks,
G
Nov 05, 2015, 05:24 PM
Made in Germany
You donīt need the fat GND wire for current measurement. Stays untouched. Shuntboards with + and - wires soldered pretty close to each other, bear certain risks.
Nov 05, 2015, 07:30 PM
Copy that... Thanks.
G
Nov 05, 2015, 10:53 PM
MaoChris's Avatar
thanks,
G
An "Hall Sensor" does not care about polarity, only about the current flow trough a single wire in the right direction. So the sensor can be installed into the "positive" or "negative" main wire, only important is that the current flows according the "arrows" on the sensor board.
At the moment there are "red" wires preinstalled at the board...
BTW, there are no stupid questions... there are only stupid answers sometimes.
Nov 06, 2015, 07:45 AM
MaoChris's Avatar
Good news, for anybody who wants to get one of the 200A sensor board with UBEC.
The web shop is up and running, just visit: www.mauch-electronic.com
REM: The web page itself needs some facelift and updating... please forgive me about that.
Nov 06, 2015, 02:43 PM
Copy that. Thanks...
Nov 06, 2015, 08:59 PM
just4funxwing's Avatar
Ok, I ordered one to check out and have on hand for my next build...
Nov 08, 2015, 08:08 PM
RotoRon's Avatar
This would be awesome if it was integrated into a square power distribution board with 45mm mounting holes.
Well, it's awesome already, but the less separate components, the cleaner the build.
Nov 08, 2015, 08:30 PM
hey whats burning?
metalbender4by's Avatar
I think I may pick one up too. Very nice work. Looks completely professional and functional.
Nov 09, 2015, 02:02 AM
ron-sand's Avatar
I've also got some of these units on my way for testing
Nov 09, 2015, 02:47 AM
Made in Germany
The less separate the components, the higher the risk of failure and impacts.
And:
Why sensor board and UBEC are separated ?
- A switching power supply can be a very “noisy” part in the power supply chain and it is very difficult to shield the coils (1.5MHz) from the current measurement board. So it was decided to keep the two away from each other.
Another thing is, that users tend to place those 45mm boards right underneath (or close to) the FC, which sure is looking good but not a good idea concerning RF and EMI impacts.
For me its the best solution to place the tiny sensorboard very very close to the battery plug and to hide the extra BEC separately.
