Hubsan X4 H501S 5.8G, a micro brushless 5.8G/1080P FPV (under construction) - Page 1587 - RC Groups
Jan 12, 2018, 03:41 PM
Crashing goes better
Westerlee's Avatar
I know about mode 4, but couldn't find it....
Just found this.
HUBSAN H501S - H501SS STANDARD REMOTE controller: mode setting (1 min 22 sec)
Jan 12, 2018, 04:09 PM
Westerlee's Avatar
Still nothing on the telly.....
So hobby time
Playing with some cheap smartphone lenses.
The setup can be removed without leaving a scratch.
Some good old double sided tape does the trick.
Jan 12, 2018, 04:21 PM
Thanks again. Yeah man-boys and their toys. Ha
So what does mode 3 do to the sticks.
Oh well. Still no internet here at the house
Till next tuesday so i cant really research it.
Jan 12, 2018, 04:29 PM
John Luciano's Avatar
http://www.midnightsunrc.com/rc-tran...odes-explained
Jan 12, 2018, 04:36 PM
From previous posts:
1. No, you cannot mix channels (not sure why you'd want to particularly) on a Hubsan controller. You can if you want mix on a Taranis or Devo and also set differential rates. You could also switch mixing on and off if you assigned the function to a switch.
2. Reversing channels does exactly that. It reverses the function, eg right rudder becomes left rudder etc. This is of limited use (in fact channel reversing has now been removed from the TX firmware) but is useful if you want to fly with a reverse looking camera, as all you do is reverse A&E and then fly with the rear of the quad as the new front. (although you tend to get a lot of sky view...)
Jan 12, 2018, 05:23 PM
Thankyou both.
I do believe mode 4 is exactly what im looking for.
Jan 12, 2018, 06:18 PM
ok,i guess I didn't explain very well,looks like mode 4 is what I was after.
but how to enable it,i know 1,2 and 3 now but 4 ?
well I just tried mode 3 and that didn't work either.
so I only have 2 modes in the advanced transmitter or did I do something wrong.
putting and holding both sticks up and right while turning on does nothing.
Jan 12, 2018, 06:24 PM
Not all Transmiiter allow switching . Some do allow mode 1 or mode 2 "
Jan 12, 2018, 06:55 PM
well that sucks,think I found what I'm looking for and cant enable it.
ha,fiqures.
thanks
Jan 12, 2018, 08:16 PM
Westerlee's Avatar
Just finished hobbying hahaha
The lenses wore not what i expected.
It worked, quit nicely but......
It was like i was looking trough a tube or tunnel.
But then i saw my nd filter and that gave me a idea.
But it was to small, so had to figure something else.
Let YouTube be your friend and found this footage.
How to make a POLARIZER FILTER (1 min 56 sec)
Luckily i had some stuf lying around so .....hobbytime
The result, i got now a couple of removable filters.
Now waiting for some good weather
Jan 12, 2018, 08:34 PM
Originally Posted by Paradox Pete
The firmware is not to fix stabilisation
It's to fix the codec which is very much broken in earlier versions....
I'll have to look at 1.1.10 and see if the ISO and noise settings are improved
They are :-) More tweaking can be done but its quite big step in right direction.
As for stabilisation you are right
Jan 13, 2018, 07:35 AM
The only R/C pilot in the city
Scorpio9999's Avatar
Originally Posted by theoztreecrasher
Keep posting them, mate.
Oz, I do.
Hubsan H501S Flight #12 (13 min 34 sec)
Hubsan H501S Flight #14 (9 min 39 sec)
Jan 13, 2018, 09:00 AM
Ok reps.
So why remove mode 3,4 options ?
Im assuming most people dont use them.
Is their away to reenable them.
This is with the new advanced transmitter.
Aint i a pain in the arse !!!
Jan 13, 2018, 09:24 AM
Ok reps.
99% of the world fly either mode 1 or 2.
0.999999999997% fly mode 3
0.000000000003% fly mode 4
(Note: 79.8% of all statistics are just made up)
Jan 13, 2018, 09:39 AM
Well i guess i fall in that 3/10 th catagory.
So no way,right?
Great !
Edit. If this cant be done, i'll try mode 1.
It is the same thing, just sticks reversed.
Thanks again.
