Oct 13, 2015, 11:27 PM
Winner Model 78in MX2- Electric only, no Gas
Specification:
-- Wing span: 78in/1980mm
-- Length: 77in/1956mm
-- Weight: 4200-4300 (without battery)
Equipments required:
-- Motor: 6360, Q80, 600-700g, 2500-3000W brushless outrunner motor
-- ESC: 80-100A HV
-- Servo: 50-70g, 12kg/cm or above, metal gear
-- Battery: 10S 4500-5000mah, 12S 3300-4000mah
-- Prop: 19*10E, 20*10E, 21*12E, 22*10E
-- Spinner: 82MM included
Recommended setup I:
-- Motor: Dualsky XM6360EA-12/180KV
-- ESC: Hobbywing Platinum 100A V3 HV
-- Servo: Hitec HS-7954SH*5
-- Battery: Duasky 6S 3250mah 45C*2
-- Prop: JXF 20*10E wood
Recommended setup II:
-- Motor: Dualsky XM6360EA-10/218KV
-- Battery: Dualsky 5S 4600mah 25C*2
http://www.winnermodel.com/cp_view.asp?id=302
WM MX2 78" 170E (4 min 31 sec)
