Thread Tools |
This thread is privately moderated by Sawn Craft, who may elect to delete unwanted replies. |
New Product
Sawn Craft - Front Yard Fighters
Sawn Craft is thrilled to announce the release of our new series of aircraft kits, the Front Yard Fighter series! Aircraft that will be developed under the FYF banner will be sized such that you can easily fly them right in your front yard (or any small space)!
This new series takes us away from the XPS foam that we are using with our other kits and into extremely durable EPP foam! These aircraft are designed to stand up to the rigors of indoor flying where walls, ceilings, and other pilots often get in the flight path! The FYF series will be jump started by a pair of fantastic flying models! Those models are the: Sawn Craft Bearcat 24! and the: Sawn Craft Zero 24! Both models are CNC-cut out of extremely light and durable EPP foam and includes all carbon, laser-cut control horns, and hardware required to complete the build! These aircraft are designed around a fairly standard 2S brushless power system. The 14g motor spins a 6x4 prop and with a 10A ESC the entire system outputs around 50W! Designed to fly in an area as small as the size of a single basketball court, you can be sure that they will work in your small venue! Maneuverability is key in small spaces so you will notice the large control surfaces on these kits; those allow for precise control and great aerobatic capability! These warbirds have the power and control to dogfight with the best aces in the air and then celebrate victory with some 3-D maneuvers! Sawn Craft FYF Bearcat 24 & Zero 24 Specs
These two kits are just the first of what we hope are a large series of different warbirds designed for durability, maneuverability, and fun in smaller spaces! All kits in the series will be offered for sale as unpainted and painted so you can choose to finish your model any way you'd like. The complete electronics kit is available on our website here. Both of the Front Yard Fighter kits are available now at Sawn-Craft.com! |
Looking great, Jonathan!
