Oct 07, 2015, 09:23 PM
Laughs at un-boxing videos...
basicguy's Avatar
Turnigy TGY i6 Programming Flaperons
Set up my first flaperons with the Turnigy I6 radio system. I used strip ailerons and individual aileron servos.
Starting in the functions menu I went to aux channels
Turned off the inputs to channel 5.
In the mix menu
Mix 1: Put the master of channel 1 (rt aileron) and a slave of channel 5 (left aileron).
Mix 2: The master is VRA and the Slave is Channel 1 with a mix of 50%.
Mix 3: The master is VRA and slave is channel 5 with a mix of -50.
By setting the mix to minus it reverses the direction from the aileron direction. You can make the action more or less by changing the percentage.
The plane flys good with this setup. At full flap deployment it really flys slow at light throttle. I have not had difficulty with tip stalls but try and keep the bank angle low with full flap deployment.
Any comments?
Jan 15, 2016, 02:10 PM
macfabiano's Avatar
Great!!
Apr 05, 2016, 02:58 AM
built, fly and crash....hihii
D17E's Avatar
In the mix menu
Any comments?
Hi....
Nice tutor....i like to try it with my fs i6...
Btw, on this mix..how to setup with a switch..if i want to normal mode or not use this flap....and if i want use this flap, i just turn on the switch....
Thanks so much....
Apr 05, 2016, 07:57 AM
D17E's Avatar
In the mix menu
Any comments?
Hi basicguy
I tried to my mustang, its not working well....
Any advices....?
Apr 05, 2016, 09:01 AM
basicguy's Avatar
What is it doing?
Apr 07, 2016, 12:14 AM
D17E's Avatar
What is it doing?
Thanks for reply basicguy...
My aileron be moving same direction right n left.....
Apr 07, 2016, 12:17 AM
D17E's Avatar
Btw...
Is on flysky fs i6 can assign a switch for mix...?
On this Tx i just found the knob VRA or VRB to assign on mix....
Is any firmware can i update to use a switch on mix...?
Sorry my bad english...
Apr 07, 2016, 06:14 AM
basicguy's Avatar
Did you set up mix 3 to be a minus 50%.
There is a way to set up the control to a switch. I have done it since I wrote the post.
Assign channel 6 to be controlled by a switch. The control is in menu AUX Channels.
Then set up mix 3 with the master as channel 6 and slave channel 5.
Apr 07, 2016, 07:02 PM
D17E's Avatar
Thanks replying,
I fixed my set by 2 mix, mix 1 100% and mix 2 -100%....
But here can not use a swicth function, just knob vra or vrb.....
I mean here, if i want to use flaperon just activate a switch such switch b or c....
On the menu mix i am not found what i want....
Apr 07, 2016, 09:52 PM
basicguy's Avatar
You need to change the settings on this page.
Make the source for channel 6 SWc then assign go to mix 3 making the master = channel 6 and slave channel 5. I didn' t use 100% on the flaps, feeling it was too much.
Originally Posted by D17E View Post
Thanks replying,
Apr 11, 2016, 10:55 AM
D17E's Avatar
Thanks basicguy, i succesed use a switch with my mix, but only 2 mix, i think use mix3 spended mix...
Btw, if set to -50%, di control surface move half from di other one....
Apr 12, 2016, 08:34 AM
basicguy's Avatar
Am having trouble understanding you. Sorry.
Assign a switch to channel 6 in the Aux. Channel control, Then make the master of both Mix 2 and Mix 3 channel 6 Use the percentages to make the flaps move the amount you want.
If you have assigned channel 6 to something else then I don't know how to make it work with a switch. Perhaps you can devise some sort of mechanical stop on the dial.
Apr 12, 2016, 12:19 PM
D17E's Avatar
Here my setting now...its correct..?
Apr 12, 2016, 03:36 PM
basicguy's Avatar
On mine the ailerons are on channel 1 and 5. It looks like you have ailerons on 1 and 6 and are using another logic tree.
Apr 12, 2016, 06:12 PM
D17E's Avatar
Correct basicguy....
