Oct 03, 2015, 02:34 AM
Help!
CG and AC for my foamy
Hi
I need help with my RC model.
I want to know my CG and AC in the photo you will find the measurement also aileron dimension
Measures
Panel span
730
mm
Root chord
732
mm
Tip chord
400
mm
Sweep
109.1
mm
Angle
8.5
Results
Wing Area
82.64
dm²
MAC Distance
329.32
mm
MAC Length
582.23
mm
CG
165.66
mm
Wing Load
96.81
g/dm²
Deep linking URL
Oct 03, 2015, 04:05 AM
Teddy Ong
Teddy Ong's Avatar
Wow! That's really large. Try this http://fwcg.3dzone.dk/
Do you consider adding a canard at the front to improve stability or stall cahracteristics or something? Good luck.
Oct 03, 2015, 06:23 AM
Thanks Teddy
No need for canard but my concern is there is small wing infront of the main big wing . So what I want to is that will effect if I consider only CG for the big wing and ignore the small one if yes it will effect how to calculate my CG and the dimensions of my ailerons ..
Oct 03, 2015, 06:43 AM
Laughs at un-boxing videos...
basicguy's Avatar
I would ignore the small delta in front of your wing. It is small and close to the fuselage, The amount of lift that it generates will be negligible. If it really bugs you you could try this calculator: http://wingcgcalc.bruder.com.br/en_US/? It will let you build the wing in two panels.
When you look at these programs they don't take into effect the lift and drag effect of the fuselage
Oct 03, 2015, 07:29 AM
thanks basicguy
So what about aileron any idea about size
Oct 03, 2015, 06:01 PM
basicguy's Avatar
Many of the models that I have, have a 7" chord and have a 1-2" aileron chord. By scaling up to 700mm I would consider 100-200mm for an aileron chord.
I have not built on this scale so take it for what it is worth. Perhaps looking at a small homebuilt full size aircraft might give you some basis.
Oct 04, 2015, 06:36 AM
I typically shoot for at least 25% of chord. So if your chord (including ailerons/elevons) is 8, go for aileron/elevon chord of at least 2.
For model airplanes especially (where low Reynolds number facilitates flow separation more easily), it is much better to have a large control surface deflect a little than a small surface deflect a lot - you want to minimize the chance of flow separation.
Some RC planes have even much larger surfaces to achieve extreme 3D maneuvers.
I also just like the greater roll authority
Also, see https://www.rcgroups.com/forums/show....php?t=2189965, reports 50 and 51 (and some of the prior posts for more background). There are some cases where huge elevons are simply dictated by the constraints of the particular airplane.
Oct 04, 2015, 07:35 AM
Thanks all
Nov 28, 2015, 07:15 PM
sdbruder's Avatar
Now you can save your plans too. It was about time! http://winglib.com
