May 30, 2016, 10:25 AM
Originally Posted by oize
The simplest way is to use USB OTG cable (your phone has to support it).
Bluetooth is also very good but the range is about 50m.
If you want greater distance, 3DR radio is good option.
You can use clones but keep in mind that they have fake FTDI chips and they doesn't work on Windows.
Bart
My clone I linked works fine on windows . never had an issue. just flashing the air model couldn't be done over the airlink. Which I think never works. so I had to open case attach it to a FTDI board I had and soldered pins on the pads to make it easier to do.
Jun 03, 2016, 07:45 AM
Discovering the joys of flying
Adilson's Avatar
Good morning
As requested, I'm posting here the problem I found with ez-gui.
I'm a satisfied users for quite some time and I purchased the tool but lately I am unable to change inav configuration. Right now I'm using inav 1.1 and ez-gui closes if I try to enter the configuration menu. It seems to work fine in the other parts tough.
Thanks in advance
Jun 03, 2016, 04:57 PM
eziosoft's Avatar
Originally Posted by Adilson
Good morning
Thanks in advance
Hi. Just to precise things. You are talking about "Cleanflight config" button?
Bart
Jun 03, 2016, 05:10 PM
Adilson's Avatar
Bart
Yes, that's correct. Everything else seems to work fine but when I press it to make configurations changes like mag orientation, for instance, it crashes.
Jun 03, 2016, 05:43 PM
eziosoft's Avatar
After a crash if there is a possibility to send error report please to it and add some description. Also if you are using official iNav 1.1 could you pase your CLI dump here?
Bart
Jun 03, 2016, 06:31 PM
Adilson's Avatar
Bart
I did an error report a couple days ago but I'll gladly do it again.
Yes, it is iNav 1.1 and here's the dump
# version
# INAV/SPRACINGF3 1.1.0 May 28 2016 / 15:44:31 ()
# pflags
# Persistent config flags: 0x00000000
# dump master
# mixer
mixer QUADX
mmix reset
smix reset
# feature
feature -RX_PPM
feature -VBAT
feature -INFLIGHT_ACC_CAL
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -CURRENT_METER
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -ONESHOT125
feature -BLACKBOX
feature -CHANNEL_FORWARDING
feature RX_PPM
feature VBAT
feature SOFTSERIAL
feature GPS
feature FAILSAFE
feature TELEMETRY
feature LED_STRIP
feature ONESHOT125
feature BLACKBOX
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map TAER1234
# serial
serial 0 1 115200 38400 0 115200
serial 1 2 115200 57600 0 115200
serial 2 1 115200 38400 0 115200
serial 30 4 115200 38400 9600 115200
serial 31 0 115200 38400 0 115200
# led
led 0 0,15::C:1
led 1 0,0:::0
led 2 0,0:::0
led 3 0,0:::0
led 4 0,0:::0
led 5 0,0:::0
led 6 0,0:::0
led 7 7,15::A:0
led 8 8,15::A:0
led 9 0,0:::0
led 10 0,0:::0
led 11 0,0:::0
led 12 0,0:::0
led 13 0,0:::0
led 14 0,0:::0
led 15 15,15::C:1
led 16 0,0:::0
led 17 0,0:::0
led 18 0,0:::0
led 19 0,0:::0
led 20 0,0:::0
led 21 0,0:::0
led 22 0,0:::0
led 23 0,0:::0
led 24 0,0:::0
led 25 0,0:::0
led 26 0,0:::0
led 27 0,0:::0
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
set looptime = 2000
set emf_avoidance = OFF
set i2c_overclock = OFF
set gyro_sync = OFF
set gyro_sync_denom = 2
set mid_rc = 1500
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rssi_ppm_invert = OFF
set rc_smoothing = ON
set input_filtering_mode = OFF
set min_throttle = 1150
set max_throttle = 1850
set min_command = 1000
set servo_center_pulse = 1500
set 3d_deadband_low = 1406
set 3d_deadband_high = 1514
set 3d_neutral = 1460
set 3d_deadband_throttle = 1000
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set disarm_kill_switch = ON
set auto_disarm_delay = 5
set small_angle = 25
set reboot_character = 82
set gps_provider = UBLOX
set gps_sbas_mode = NONE
set gps_dyn_model = AIR_1G
set gps_auto_config = ON
set gps_auto_baud = ON
set inav_auto_mag_decl = ON
set inav_accz_unarmedcal = ON
set inav_use_gps_velned = OFF
set inav_gps_delay = 200
set inav_gps_min_sats = 6
set inav_w_z_baro_p = 0.350
set inav_w_z_gps_p = 0.200
set inav_w_z_gps_v = 0.200
set inav_w_xy_gps_p = 1.000
set inav_w_xy_gps_v = 2.000
set inav_w_z_res_v = 0.500
set inav_w_xy_res_v = 0.500
set inav_w_acc_bias = 0.010
set inav_max_eph_epv = 1000.000
set inav_baro_epv = 100.000
set nav_disarm_on_landing = OFF
set nav_use_midthr_for_althold = ON
set nav_extra_arming_safety = ON
set nav_user_control_mode = ATTI
set nav_position_timeout = 5
set nav_wp_radius = 100
set nav_max_speed = 300
set nav_manual_speed = 500
set nav_manual_climb_rate = 200
set nav_landing_speed = 200
set nav_land_slowdown_minalt = 500
set nav_land_slowdown_maxalt = 2000
set nav_emerg_landing_speed = 500
set nav_min_rth_distance = 500
set nav_rth_tail_first = OFF
set nav_rth_alt_mode = AT_LEAST
set nav_rth_altitude = 1000
set nav_mc_bank_angle = 30
set nav_mc_hover_thr = 1500
set nav_mc_min_fly_thr = 1200
set nav_fw_cruise_thr = 1400
set nav_fw_min_thr = 1200
set nav_fw_max_thr = 1700
set nav_fw_bank_angle = 20
set nav_fw_climb_angle = 20
set nav_fw_dive_angle = 15
set nav_fw_pitch2thr = 10
set nav_fw_roll2pitch = 75
set nav_fw_loiter_radius = 5000
set serialrx_provider = SPEK1024
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_default_lattitude = 0.000
set frsky_default_longitude = 0.000
set frsky_coordinates_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_sound_interval = 5
set battery_capacity = 0
set vbat_scale = 110
set vbat_max_cell_voltage = 43
set vbat_min_cell_voltage = 33
set vbat_warning_cell_voltage = 35
set current_meter_scale = 400
set current_meter_offset = 0
set multiwii_current_meter_output = OFF
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_roll = 0
set align_board_pitch = 0
set align_board_yaw = 0
set gyro_lpf = 42HZ
set moron_threshold = 32
set imu_dcm_kp = 2500
set imu_dcm_ki = 50
set imu_dcm_kp_mag = 10000
set imu_dcm_ki_mag = 0
set pos_hold_deadband = 20
set alt_hold_deadband = 50
set yaw_control_direction = 1
set yaw_motor_direction = 1
set yaw_jump_prevention_limit = 200
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set servo_lowpass_enable = OFF
set failsafe_delay = 10
set failsafe_off_delay = 200
set failsafe_throttle = 1100
set failsafe_kill_switch = OFF
set failsafe_throttle_low_delay = 100
set failsafe_procedure = SET-THR
set rx_min_usec = 885
set rx_max_usec = 2115
set acc_hardware = 0
set baro_use_median_filter = ON
set baro_hardware = 0
set mag_hardware = 0
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set blackbox_device = SPIFLASH
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set acczero_x = 0
set acczero_y = 0
set acczero_z = 0
set accgain_x = 4096
set accgain_y = 4096
set accgain_z = 4096
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 7 h
rxfail 8 h
rxfail 9 h
rxfail 10 h
rxfail 11 h
rxfail 12 h
rxfail 13 h
rxfail 14 h
rxfail 15 h
rxfail 16 h
rxfail 17 h
# dump profile
# profile
profile 0
# aux
aux 0 0 0 1700 2100
aux 1 1 1 1300 2100
aux 2 2 1 900 1300
aux 3 4 1 1700 2100
aux 4 3 2 1400 1875
aux 5 10 2 1150 1400
aux 6 10 2 1650 1875
aux 7 9 2 1875 2100
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
servo 0 1000 2000 1500 90 90 100 -1
servo 1 1000 2000 1500 90 90 100 -1
servo 2 1000 2000 1500 90 90 100 -1
servo 3 1000 2000 1500 90 90 100 -1
servo 4 1000 2000 1500 90 90 100 -1
servo 5 1000 2000 1500 90 90 100 -1
servo 6 1000 2000 1500 90 90 100 -1
servo 7 1000 2000 1500 90 90 100 -1
set nav_alt_p = 50
set nav_alt_i = 0
set nav_alt_d = 0
set nav_vel_p = 100
set nav_vel_i = 50
set nav_vel_d = 10
set nav_pos_p = 65
set nav_pos_i = 120
set nav_pos_d = 10
set nav_posr_p = 180
set nav_posr_i = 15
set nav_posr_d = 100
set nav_navr_p = 10
set nav_navr_i = 5
set nav_navr_d = 8
set deadband = 5
set yaw_deadband = 5
set throttle_tilt_comp_str = 0
set default_rate_profile = 0
set gimbal_mode = NORMAL
set mag_declination = 0
set p_pitch = 30
set i_pitch = 20
set d_pitch = 70
set p_roll = 30
set i_roll = 20
set d_roll = 70
set p_yaw = 100
set i_yaw = 40
set d_yaw = 0
set p_level = 120
set i_level = 15
set d_level = 75
set max_angle_inclination_rll = 300
set max_angle_inclination_pit = 300
set gyro_soft_lpf_hz = 60
set acc_soft_lpf_hz = 15
set dterm_lpf_hz = 40
set yaw_lpf_hz = 30
set yaw_p_limit = 300
# dump rates
# rateprofile
rateprofile 0
set rc_rate = 90
set rc_expo = 70
set rc_yaw_expo = 20
set thr_mid = 50
set thr_expo = 0
set roll_rate = 0
set pitch_rate = 0
set yaw_rate = 0
set tpa_rate = 0
set tpa_breakpoint = 1500
Jun 03, 2016, 06:32 PM
Adilson's Avatar
This is a very clean inav install, as you can see, just the basic configuration is done, I didn't even calibrate this frame.
Jun 05, 2016, 01:40 AM
Full-Blown RC Junkie
Snowboard_Nut's Avatar
I'm now running iNav 1.1.0 that you compiled especially for F1's with FrSky Telemetry and I tested your exact scenario of changing Mag Orientation via EZ-GUI>Cleanflight Config without error, and the change stuck and verified after rebooting both EZ-GUI and the Naze. Not sure if this info is pertinent considering your using an F3, but thought some feedback about the matter may help in some way.
Jun 05, 2016, 03:53 AM
Sometimes when I apply pid changes the fc gets stuck, the red and green light is permanent on. Only rebooting the fc helps. connected via bluetooth hc-06.
Jun 05, 2016, 01:24 PM
is hdop for satellites on ezgui.. i have the paid version just wondering as it would be good...?
Jun 05, 2016, 01:41 PM
eziosoft's Avatar
As I remember correctly I've added it but only for iNav. I'm not sure if it in released version. I'm on shot vacation so can't check that.
Bart
Jun 05, 2016, 01:45 PM
eziosoft's Avatar
Is it the official 1.1 or you have compiled it by yourself?
Bart
Jun 05, 2016, 01:55 PM
Bart
ok no prob....
yeah i running inav... i see it on cleanflight GUI but not on my ezgui.....
Jun 05, 2016, 02:20 PM
Adilson's Avatar
Bart
Compiled myself from the source because I wanted NEO7 GPS support.
Jun 06, 2016, 08:15 PM
eziosoft's Avatar
Good morning
Thanks in advance
Hi.
I've probably fixed it. The problem was
there is no NONE in official cleanflight.
Just pushed a beta. It'll be available in few hours.
