Sep 29, 2015, 12:55 AM
eziosoft's Avatar
EZ-GUI Ground Station for Android
Ground Station software designed to work with Cleanflight, Betaflight, iNav and Multiwii based flight controllers.
It displays all available data from a flight controller in a convenient way.
It allows you to easily configure and tune your model from Android device, so you don't have to take your laptop to the flying field.
It supports direct USB connection (Android >3.1) as well as Bluetooth, WiFi and 3DR Radio.
More information
http://ez-gui.com/
To help with translation go here:
http://crowdin.net/project/multiwii-ez-gui
You can download Beta version (when available) :
https://play.google.com/apps/testing/com.ezio.multiwii
Bart
Oct 05, 2015, 10:13 AM
eziosoft's Avatar
Does everyone experience phone or tablets reboots when using EZ-GUI?
Especially with USB connection.
Oct 05, 2015, 04:05 PM
I need to crash!
No reboots in my case.
Instead I'd like to ask the following : besides being very useful for programming the FC, I'd like to use the vocal alerts to let me know about the battery voltage. Problem is that the BT connection drops when the quad is far away and does not automatically reconnect when in range.
P_
Dec 17, 2015, 10:05 PM
eziosoft's Avatar
Is there anything else that should be added to the EZ-GUI? Any ideas?
Mar 02, 2016, 08:03 AM
Having a lot of problems with new EZGUI versions, standard (3.74) and beta (4.7)
EzGUI crashes randomly and mission planner also does not work anymore. Always zooming out in version 3.74. Beta does not have this zooming issues, but always crashing.
Now i am using version 3.61, this is working stable.
Mar 02, 2016, 11:07 AM
eziosoft's Avatar
Hi
Please update to the latest version which at the moment is 3.82. Most of the problems was fixed. And always please send crash reports if you can.
Mar 04, 2016, 04:29 AM
Thanks, this version is working.
Now i can test the new FollowMe modes.
Mar 04, 2016, 11:28 AM
eziosoft's Avatar
Feedback is very welcome as I've not tested it in flight yet.
Mar 06, 2016, 07:06 AM
Is it normal the copter is not pointing at me in this modes?
INav 1.0 new FollowMe Modes (EzGui) (4 min 31 sec)
Mar 06, 2016, 09:40 PM
From Norway
Tried to register on your website to post a bug, but I dont get the email from your, checked my spam.
Anyway, want to report that with an SP racing f3 running iNav and a Nexus 6P Im unable to download blackbox data from a fixedwing airplane. It just hangs on random percentage between 10-50%
I connect with USB on the go, tried both drivers.
Dont have any other boards with black box, and I dont have any other cellphone/tablet with OTG cable, so cant check whos fault it is.
Mar 07, 2016, 03:24 PM
eziosoft's Avatar
https://youtu.be/kt-fsSHyqkA
Yes it is normal. At the moment I don't have a control over the heading. I'm talking with DE about this.
Mar 07, 2016, 03:25 PM
eziosoft's Avatar
I'll look at this asap. Added to my to do list.
Mar 07, 2016, 06:30 PM
From Norway
Anyway I can help?
Mar 08, 2016, 01:38 AM
eziosoft's Avatar
If you want to try new version, it is here:
https://www.dropbox.com/s/6yp85f669z...52248.apk?dl=0
I haven't published it yet because I have to finish few things.
The followMe orbit mode has been much improved, should be faster and more fluid. Also you can set a radius.
New mode added : "Wand". Point the phone in the desired direction and press volume down key. Copter will stay a set distance from you and you can move it by pointing and pressing volume down key.
Mar 08, 2016, 05:14 AM
What would happened if the FC looses connection with the phone ?
