Sep 22, 2015, 10:12 AM
SeByDocKy's Avatar
Mini-Review
WLtoys Q282J microhexacopter (Under construction)
INTRODUCTION
The second half of 2015 seems to be the semester of toy hexacopters. After 3 or 4 nanos, here is a micro-sized model offering a 2Mpx camera module, i.e. the Q282Jl.
BOX CONTENT
+ 1 x WLtoys Q282J (with a 1S 600mAh LiPo ending with microLOSI connector)
+ 1 x Transmitter (using 6xAA batteries not included)
+ 1 x USB charging cable
+ 6 x Spare props (2 CW, 2 CCW)
+ 1 x 2Gb microSD card
+ 1 x USB microSD reader
+ 1 x Screwdriver
+ 1 x Instruction manual (English/Chinese)
OVERVIEW
-Front view
The camera lens mount is a M7 model (compatible with the 808#16 lens D for example)
-Side view
-Rear view
-Upper view
-Bottom view
Motors
Some 7mmx20mm coreless motors are installed. For a total weight of 63g, maybe this model is not powerful enought to have a good thrust capacity
LiPo
Camera module
The camera module is advertised to be 720p in both in video and photo. In practice it's false... Only photo are in 720p format but videos
are in VGA format @60fps (like the V686J module since it's the same module). By the way, as you can see in this video sample, the general quality good for a VGA camera with a good light sensitivity and color rendition. As expected, the Field of View is a little bit limited. The lens is slightly targetting the ground too.
WLtoys Q282J raw video sample (0 min 8 sec)
As you can see, videos are jellofree, a very positive point with a limited FOV and a micro sized model.
Disassembling
10 screws to remove to split in two part sthe plastic canopy.
The main PCB shows a XN287 RFchips .... It's official since the second revision of the V686, WLtoys changed again its radio protocol to save a fraction of cents. This chip don't offer the same performances at the same datarate than a nRF24L01 or a Beken 2423 (previously prefered). The range out of the box don't exceed 50m.. By drilling a small on tjhe top canomy, you can install the antenna vertically and increase the range by consequence
Transmitter
The classic WLtoys chassis is shipped. Amoing the six panel buttons, 4 are used to select the speed mod. Only Pitch and tilt rates are increased. The yaw remains constant (a little bit slow IMHO). The Light buttons if pressed more than 2s activâtes the "One Key Return", an inaccurate feature potentially source of fly away. The last button if pressed more than 2 sec turns on the Headless mod. The reference is fixed at start up. You can reset this reference by pushing both stick in lower left position. I didn't find yet how to recalibrates gyroscopes.
Finally the top left button turn on/off video recording and the top right bumper activates flips after a right stick direction indication.
FIRST USAGE
WLtoys Q282J outdoors test (Courtesy Banggood) (12 min 16 sec)
CONCLUSIONS
To make short, I didn't like this model. Except the look relatively cute, majors problems can be found in the design.
The choice of 7mm motors for a total weight of 63g is killing all the global performances: relatively poor vertical thust, instability and diffculties in the autolevelling after a fast banking and a short flying duration. More, WLtoys changed again the radio protocol: instead to continue with the excellent flysky ( > 150m, based on a A7105), they prefered a new one based on the "poor" XN297... Consequence out of the box the range is limited. Luckely, you can extend the range via the "antenna mod" and if one day this protocol is deviated, the range will be one more time increased. Finally, the camera module is not a 720p but only a (good) VGA (3 year old module).
UNBOXING
WLtoys Q282J Unboxing and quick testing (Courtesy Banggood) (12 min 34 sec)
PROS
+ Design
+ Good frame rate of the camera module
+ Jellofree recording
EDIT 10/01/15
+ Protocol "Deviated"=> better range
CONS
- Lack of power, vertical thurst
- Instable from 80% during a turn
- Poor range out of the box (~40-50m)
- No HD ready cam but a VGA module
- 4min30 of duration with camera on
- YAP (Yet Another Protocol, XN297 based)
This quadcopter have been courtesy provided by Banggood in order to make a fair and not biased review. I would like to thanks them for this attitude.
You can find it actually for 55USD at http://www.banggood.com/WLtoys-Q282J-2_4G-4CH-6Axis-with-720P-2_0MP-HD-Camera-RC-Hexacopter-RTF-p-993936.html
Sep 22, 2015, 10:13 AM
SeByDocKy's Avatar
Reserved
Sep 22, 2015, 02:35 PM
Fan of just about anything RC
SoloProFan's Avatar
Nice video, despite the lower resolution, but shame about the lower range and lack of power. Does WL Toys have a quadcopter version with the same camera? Generally quads seem to have better power to weight ratios anyway.
Latest blog entry: For the love of the hobby!
Oct 01, 2015, 12:23 AM
SeByDocKy's Avatar
The V686J uses the same camera module
Oct 01, 2015, 12:26 AM
SeByDocKy's Avatar
Good news, the protocol is now deviated: http://www.deviationtx.com/downloads...protocol-combo
On more reason to move to a Devo7E: https://www.rcgroups.com/forums/show...1#post32827156
