Sep 16, 2015, 11:07 PM
youtube.com searchfor danqfpv
Danq0's Avatar
Eachine Mini APM V3.1 Flight Controller With GPS Module
hello all, been looking to build a quad for some time now. Came across this flight controller, any one have any experience with this?
Description:
Item Name: Eachine MINI APM V3.1 Flight Controller With GPS
Hardware version: V3.1
Dimension: 35 x 35mm
Weight : about 22g
Support mode: fixed wing,multi-rotor
Interface: 8 output, 8 way output, GPS, telemetry +OSD, I2C (for external Compass), voltage and current detection input, USB, power supply input
Features:
Function and firmware are the same as APM, can be used in fixed wing and multi-rotor.
GPS with onboard compass
8-CH output and 8-CH input
Can connect to external GPS,telemetry system and PM module
12-CH function interface
A0 - A12 interface has also been introduced in V3.1 version.
Mini APM no internal integrated compass, need customer self configuration GPS module with a compass.
Package Included:
1 x Eachine Mini APM V3.1 Flight Controller with case
1 x GPS module with compass
1 x connecting wirehttp://www.banggood.com/DYS-Mini-APM-Flight-Controller-With-GPS-Module-p-977560.html
worth it to buy this? or should I just buy this one from ebay ...
http://www.banggood.com/DYS-Mini-APM...-p-977560.html
it includes all this
- F450 Quadcopter Frame x1 (color of the ARM at random)
- APM 2.6 Flight Control w/case x1
- 6M GPS x1
- A2212 980KV Brushelss Motor x4
- 30A SimonK ESC x4
- 1045/1045R Propeller x4 (2 pairs) (color of the PROPELLER at random)
- ESC Connect Board Set x1
- 3.5mm gold bullet plug x 12 (12 pcs female)
- Heat shink tube x2 (50cm yellow + 50cm black)
http://www.ebay.com/itm/121707187413...%3AMEBIDX%3AIT
