This thread is privately moderated by Mad_angler1, who may elect to delete unwanted replies.
Sep 07, 2015, 05:53 PM
Bog Flusher Platinum Grade
Mad_angler1's Avatar
Mini-HowTo
DJI Phantom 3 Advance & Professional Controller Update Information.
DJI Links
DJI Phantom 4 http://click.dji.com/ewNB7_KlW2SdbyRy?pm=link&as=0001
DJI Phantom 3 http://click.dji.com/ewNB7_KlntMl6jMw?pm=link&as=0001
DJI Inspire 1 http://click.dji.com/ewNB7_KlixhKtwvR?pm=link&as=0001
Please Note: As with all my own blog post all links may be affiliate links and i may receive a small commission on any purchase bought through them , if you wish to support me then then are there otherwise you can navigate directly to DJI's website, thank you.
Please See DJI for up to date firmware information
Please Note FW V1.4 onwards does not contain a controller update you need to use V1.320 to update the controller that was the latest build. [/B]
There is a LOT of confusion around controller in this update, please see below to see what you need to do regarding the update
There are 2 versions of the P3 controller, Model GL300A and GL300B, the Model is written on the rear of the controller next to the DJI logo.
GL300A : Up to FW 1.3.20 it could be updated via the USB port, Once you installed V1.320 future updates will be via the DJI Go App.
GL300B, Can only be updated via the DJI Go App, Anything before 1.3.20 is not relevant as there was no update other than via the App.
If you have the GL300B update is via the App only, No further action is required.
GL300A ONLY
If you are currently on 1.3.20 then all future updates are via the DJI Go App.
If you are on V1.1.9, V.1.2.6, 1.2.8 you need to update the controller to v.1.3.20 before it can be updated via the DJI Go App.
If your on V1.1.8 or V1.1.9 you may should to update to V1.2.6/8 before you can update to V1.3.20
1: Install the New DJI Go App and see it it prompts you to update the controller, if it completes then your done.
2: If it says "RC requires upgrade" you need to upgrade the controller to V1.3.20 as per DJI update instructions listed below.
To update it you need firmware V1.3.20 file from DJI downloads page for your P3 model.
Note : V.1.4 and v1.5 does not include the controller update in the package you must use V1.3.20 then update via DJI Go.
You can update either on a formatted USB drive or via a usb cable to the gimbal.
3: Check the log and post the results if failed.
4: if this fails follow and you are on FW 1.1.8 or 1.1.9 update to v.1.2.6/8 first then update to V1.3.20
If that fails follow the below process posted by Tahoe Ed from DJI.
DJI Controller Update Instruction
Updating the Remote Controller Firmware
Ensure the DJI GO app has been updated to v1.2.0 before updating the remote controller. The System Status bar in Camera View of the DJI GO App will flash several times if a firmware update is available. Follow these steps to update the firmware via the DJI GO App.
Step 1- Check Battery and SD Card Capacity
1. The remote controller has at least 50% battery level.
2. Your mobile device is able to access the internet.
3. There is at least 30 MB of free space on your mobile device.
Step 2- Download and Update the Firmware
1. Go to the DJI GO App > Camera View > System Status bar > Overall Status. Tap Download the firmware update package to download and update the firmware. Track the update progress from progress bar in the DJI GO App. The status LED on the remote controller will blink blue during update and blink green when update is complete with success.
Firmware update through the DJI GO app will not work with older versions of the remote controller firmware. If the firmware update fails, follow the instructions below to update the firmware using the traditional method:
a. Update the latest firmware package files from DJI official web site.
b. Extract all downloaded files into the root directory of an SD card or USB flash drive.
c. Turn off the remote controller, Insert the SD card into a SD card reader or the USB disk onto the remote controller USB port when remote controller is turned off.
d. Power on the remote controller and wait 60 seconds until the upgrade begins. Do not power off the remote controller during the update.
e. It will take approximately 10 minutes to complete the firmware update. The camera will sound a beeping sound and the Status LED on the remote controller shows solid blue to indicate the update is in progress. The Status LED on remote controller shows solid green and beeping
sound will stop if the upgrade is completed with success.
f . If you do not have a SD card reader, you may insert the SD card into the gimbal and connect the gimbal with remote controller to upgrade
Update the current remote controller firmware to v1.3.20 through USB flash drive. You will only be able to update the remote controller firmware through the DJI GO app from this point onwards.
Tahoe Ed Post From DJI
https://www.rcgroups.com/forums/show....php?t=2482254
Issues on updating the remote controller and corresponding solutions
GL 300A:
Please try to update GL300A remote controllers by using a USB drive/ SD card adapter or connecting the aircraft gimble port with the controller via a USB cable. If you fail updating with these two methods, please connect your controller with your app (meanwhile keep the aircraft off and keep your mobile device connected with the Internet), then turn on your app, go to camera-aircraft status, download and install the firmware and the remote controller will be updated (More than 15 remote controllers in China have been updated in this way).
GL300B:
Remote controllers whose model type is GL300B can only be updated on your app, however, according to the survey, the updates failed in the following three conditions:
First, The remote controller turns off automatically, then the first led light on it turns cyan. And when you connect your remote controller with your mobile device again, the app says no signal, and thereís no notification that says the remote controller needs to be updated.
Solution: Itís possibly because the 1765 module on the remote controller fails updating. So please press these four buttons on the remote controller at the same time, namely, C1, C2, Recording and the Scroll that adjusts ISO, meanwhile, spare another finger to turn the remote controller on (donít let the other four fingers go), then turn on the app and youíll be able to download the firmware again and please follow the steps on the app and the remote controller will hence be updated. (More than 10 remote controllers in China have been updated in this way).
Second, the app fails updating the remote controller and the first led light turns red.
Solution: please update on your app again. (More than 2 remote controllers in China have been updated in this way).
Third, the remote controller wonít update any ways.
Solution: the 1.2.0 Android app has this bug that no matter your firmware is latest or not, the app will ask you to update the remote controller. The new DJI GO Android app will solve this bug. (Many more remote controllers in China have been updated in this way).
