Dquad - iniMini H180 Frame - RC Groups
Sep 07, 2015, 09:02 AM
Dquad
Djondb's Avatar
New Product
We, from Dquad, are very proud to introduce to you the iniMini H, the next level of Mini
Metall Danny's First iniMini H Test (0 min 57 sec)
This frame is not only incredibly tough, but it can also be built to be one of the fastest out there. Its small size (176mm M2M) makes it perfectly fit for flying at the playground next door. It fits 4" props and a wide variety of motors, giving you the opportunity to build it to suit your flying style exactly.
Keeping in mind that the frames are getting smaller and smaller, but the hardware that has to be put on them remains pretty much the same, we designed a PDB that takes care of most of the essential connections.
Right now it has the required integrations for a NAZE32 rev5 using female header pins. It will connect the ESCs (including signal), V-Bat and also a buzzer.
Specifications:
Materials: 3k Twill Weave Matte Carbon Fiber 1.5mm / 3mm
Motor to Motor: 176mm
Fasteners: black button hex head steel cap & Anodized Black Aluminium Standoffs
Propeller size: 4
Motor Mount: M2 12mm 16mm (motor size 1306 & 1806) & M3 16mm -19mm (motor size 2204 & 2206)
FPV Camera: suitable for camera like the PZ0420M and the HS1178
Features:
Integrated Power distribution board (PDB) fully naze32 compatible
Integrated chase lights on PDB
Integrated esc connections on PDB
Integrated Buzzer on PDB
Integrated VTX and RX antenna mounts
Anti-vibration mount for Mobius or GoPro
The iniMini H is coming (0 min 16 sec)
more info at http://www.dquad.nl/iniMiniH.html
Expected release will be end of September. Pre-orders at multirotorparts.com started! Get yours now!
Sep 07, 2015, 10:21 AM
nisccheee
looks cute goes like like a rocket
Sep 07, 2015, 04:00 PM
Speeeed!!WOW!
Sep 08, 2015, 04:00 AM
z33
z33
subscribed
Sep 08, 2015, 04:07 AM
Just another FPV addicted teen
EpicRC's Avatar
Looks like a micro blackout! Subbed ( any chance of a 220 size?)
Sep 08, 2015, 10:36 AM
Dquad
Djondb's Avatar
There will be an option for 5" arms making it 210mm in the near future!
Sep 08, 2015, 11:36 AM
FPV pilot
orley's Avatar
What is the bare weight of the frame? And what is the estimated price range?
Sep 08, 2015, 11:37 AM
I really like the use of the PDB as power and signal. Cutting down on the amount of wires is a great way to save weight and clean up the design.
If I weren't already overloaded with mini quads (and a hex!) I'd buy this just to support that idea being used.
Sep 09, 2015, 03:41 AM
Dquad
Djondb's Avatar
Bare weight of the frame (including HD cam mount) is currently measured 97grams.
I will update this when we get all the original parts but difference will be minimal.
the price of the iniMini will be competitive with established frames that are already around
Another real benefit that it currently has is the ability to (re)program your esc's very easily. Just take off your FC, connect the flash-tool to the female header pins of the ESC that you want to flash (signal & GND), connect battery and you're able to flash the ESC.
Sep 09, 2015, 04:20 AM
EpicRC's Avatar
Sweet!! Is there a pre order button?
Sep 09, 2015, 02:45 PM
Telechat's Avatar
I just can't get why Blackout completely missed the boat on 180 quads. The guy killed its business himself.
It's definitely the closest thing to a Blackout 180, even the name relates to it.
Sep 11, 2015, 03:10 AM
Dquad
Djondb's Avatar
There will be one very shortly at multirotorparts.com!
When you want a frame that is strong, maintainable, has good fly characteristics and is easy to build, chances are indeed that you end up with something that looks similar to an already proven concept.
Sep 13, 2015, 02:45 AM
How to build your iniMini H (1 min 10 sec)
That is the cleanest mini i saw so far! Awsome build video!
Sep 16, 2015, 12:45 PM
Dquad
Djondb's Avatar
I just got word that pre-orders just started at multirotorparts.com 😀
Sep 16, 2015, 02:29 PM
Ziet er goed uit... I still have a Blackout to build, but tempting... very tempting!
