Sig 1/6 j3 cub - RC Groups
Sep 02, 2015, 03:48 PM
Build Log
Sig 1/6 j3 cub
Hey guys I started my build a couple of weeks ago. Decided to start a build thread to go with it.
This is my first sig kit. I've built a few other less involved kits before and some foamys. This will be my first glow powered build. I'm still undecided if I want to go clip wing, full length, undecided on paint scheme.
The package arrivedName: uploadfromtaptalk1441226579605.jpg
Description:
Getting plans laid out
Description:
Building sides of Fuse
Description:
Coming together
Description:
More progress
Description:
Lil more
Description:
We have a door
Description:
Sep 02, 2015, 03:52 PM
I'm having technical difficulties so the front fuse section got ripped off and is being done over but things were starting to not line up properly despite following plans to the T
Sep 03, 2015, 11:33 AM
Description:
Decided to give my fuselage a break and start working on the wing. Fusing the wing tips together
Description:
Sep 03, 2015, 06:52 PM
Keep on truckin'!
Sep 03, 2015, 11:54 PM
Scratch builder
Good. Please take more pictures I like cubs
Sep 04, 2015, 10:15 PM
Can't wait to see this one done !
I built this as a free flight scale model back in '74 ( I'm on the kit's box )
Good luck , it's a sweet model !
Sep 05, 2015, 06:27 PM
E-Challenged's Avatar
I'm flying mine on two 2200 mah 3S lipos in parallel with a .40 equivalent Cobra brushless motor. Model will loop and roll from level flight and is very well behaved. Only complaint is hates to come down and wants to overshoot our somewhat short landing strip. I need to learn to safely slip it to kill airspeed for landings.
Installing and connecting lipo packs through side door/window is somewhat fiddly. Attaching wing struts to fuse attach points with small socket head screws and elastic nuts is also fiddly. A large metal clevis would be easier
Sep 06, 2015, 12:55 AM
marmalade1's Avatar
Subscribed!
Sep 07, 2015, 12:32 PM
I will try to be better about updating and taking more pics as I go along. This may end up being a long build depending on how finances go.
I did manage to get a little bit more done on one of the wing panels. I'm using sig bond glue so lot more waiting between dry times but I really like the strength of the glue bond
Sep 07, 2015, 12:33 PM
Description:
Sep 07, 2015, 03:56 PM
marmalade1's Avatar
Aren't wings just great to put together?
PD
Sep 08, 2015, 09:09 PM
PD
And I just thought I knew what patience was.
Managed to get a little more done to one of the wing panels today. All that's left is some sanding / wood putty and I will have completed one of the wing panelsName: uploadfromtaptalk1441764584923.jpg
Description:
Sep 16, 2015, 12:56 PM
Made some progress over the weekend on the other wing panel. Also made a stop off at hobby shop and picked up some cub wheelsName: uploadfromtaptalk1442426092024.jpg
Description:
Description:
Description:
(Note cordless drills make great weights)
Sep 25, 2015, 12:49 PM
Description:
Made a little more progression on the wing. I'm moving like molasses on this build. I've been under the weather so I have not been doing that much this week. I did manage to join the wing halves and get one side glued.
Oct 19, 2015, 01:40 PM
If you haven't done so when building wing panels, it would be well to twist in some tip wash-out ( trailing edge raised near the wing tips during covering and adjust wing struts to hold it steady. Angling both ailerons upward an 1/8th inch acts like tip washout . Real Cubs had considerable tip washout for lateral stability.
Make sure that both wing panels are not twisted, sighting carefully from the back. The Dubro incidence meter is helpful tool,
Discussion 1/6 SIG J3 piper cub 71" - power plant question DYORD Fuel Plane Talk 5 Mar 19, 2016 09:51 PM
Sold Sig 1/6 Piper J3 Cub r39o Aircraft - Fuel - Airplanes (FS/W) 0 Nov 19, 2015 09:19 PM
Sold RTF 1/6 Sig J3 Cub needacheaphobby Aircraft - Fuel - Airplanes (FS/W) 2 Aug 22, 2012 07:15 PM
For Sale RTF 1/6 Sig J3 Cub $ reduced needacheaphobby Aircraft - Fuel - Airplanes (FS/W) 1 Jul 15, 2012 10:07 PM
