Mar 24, 2019, 02:35 PM
Tried to fly today. The esc must be faulty. Took about 15 mins to get the motor spinning. Flew for 15mins and i have now retired it to the back of the garage. Going to buy something else.
Mar 24, 2019, 02:47 PM
BMFA 190658
SilentPilot's Avatar
Why not just get a replacement ESC?
Mar 24, 2019, 03:41 PM
Where can i get spares from?
it could be the motor or something else. Im going to get another hitec red receiver and an artf glider. Any recommendations under 120 that would fit 3s lipo batts
Mar 24, 2019, 04:58 PM
→ 404 Not Found
Justapoke's Avatar
You can use just about any ESC. As long as it has the same rating, like 20 or 30A for example.
Get a Plush ESC from Hobbyking, or a HobbyWing from Banggood for example. They are cheap and top quality.
Might be your ESC is just fine, but you have messed with it's program setting. If a motor spools up very slowly it normaly means it's set to governer / helicopter mode.
Did you calibrate your ESC?
Mar 24, 2019, 05:04 PM
→ 404 Not Found
Justapoke's Avatar
Reading back:
Originally Posted by steeevo
i disconnect the esc from channel 3 of the receiver i lose power to the receiver and then reconnect it i get lots of quick beeps then the motor connects and works. Something is not right.
Quick beeps means programming mode. I do think you have changed the ESC's programming (you do this with stick inputs)
Best to watch a few videos on youtube so you learn how to use / callibrate and program a ESC.
Your glider should also have ESC programming instructions in the manual.
Mar 24, 2019, 05:24 PM
I cannot get into the esc programming mode. I have tried and tried. I have watched all the videos. I will try and find another esc but i will probably end up throwing it and buying something rtf
Mar 24, 2019, 05:39 PM
BMFA 190658
You can throw it my way!
Mar 25, 2019, 10:10 AM
Fully Sending It
Xpress..'s Avatar
double
Mar 25, 2019, 10:11 AM
Fully Sending It
Xpress..'s Avatar
steeevo, at the risk of sounding like an ass (that's not the intention), but this airplane is not complicated to setup. Did you follow the calibration steps on the previous page? Just because you can't get the ESC to cooperate does not mean the entire aircraft is trash. It's very silly to think such.
Call our service center if you need help over the phone, one of our guys can walk you right through the steps and if all else fails, we can get you warranty service on the ESC.
858.748.6948
Latest blog entry: My relationship with Hitec
Mar 27, 2019, 01:37 PM
I am in the uk. Thanks for the offer though. Watched alot of videos on the esc and i still cant get it too work. I may try a programming card and see if that works
Mar 27, 2019, 02:49 PM
BMFA 190658
Whereabouts in the UK?
Mar 27, 2019, 03:15 PM
Rye, East Sussex
Mar 27, 2019, 05:23 PM
BMFA 190658
Hmmm... a bit far away!
May 05, 2019, 03:19 PM
http://flahut59.over-blog.com/
flahut59's Avatar
Hello
I have a sport panda to which I have added fins.
I'd like to buy the funglider's wings to increase the wingspan.
are flight qualities really different?
thank you
Discussion Multiplex Funglider in European shops ! EuroDriver Foamies (Kits) 0 May 29, 2015 06:25 PM
