This thread is privately moderated by bgproducts, who may elect to delete unwanted replies.
Sep 25, 2015, 02:51 AM
New products on Banggood
(Subscribe thread here to get notified on future updates and products)
Immersion RC SpiroNet 8dBi Mini RHCP Right Hand Circular Polarized Patch Plate Antenna
(click here for details)
$28.49
  • Right-Hand circular polarization
  • 5.8GHz ISM Band
  • 8dBi gain
  • Beam width -3dB at +/- 45 degrees (H + V) (90 degree total)
  • F/B Ratio >356dB
  • VSWR < 1:1.35 at 5800MHz
  • Impedance 50 ohms
  • Weight 7g
Sep 25, 2015, 02:54 AM
Walkera Runner 250 Advance Drone 5.8G FPV GPS System with HD Camera Racing Quadcopter RTF
$471.99 - $860.99 (depends on version)
  • Item name :Walkera Runner 250 Advance
  • Main Rotor Dia: 140mm
  • Overall(LxWxH) Size: 225x205x92mm
  • Weight: 570g (with battery)
  • Remote control: DEVO 7
  • Receiver: DEVO-RX710
  • Flight Control: FCS-Runner 250-GPS
  • Flight Control System: MWC platform
  • GPS: GPS and GlONASS dual-mode
  • Illustrated: 5.8Ghz band 5733Mhz default
  • OSD: Runner 250
  • Buzzer: Runner250
  • Figure mass emission: TX5816 (FCC) TX5817 (CE)
  • Optional camera:800TVL camera
  • Brushless Motor: WK-WS-28-014 (CW / CCW)
  • Brushless ESC: Runner 250
  • Lithium Battery: 11.1V 2200mAh 25C 3S Li-Po
  • Flight time: 10 to 13 minutes
  • Working temperature: -10 ℃ to + 40 ℃
Feature:
  • GPS System racing quadcopter
  • New flight control system
  • 1080p 60 FPS recording camera
  • New backpack package
  • Direction warning lamp
  • Intelligent buzzer alarm
Sep 25, 2015, 02:58 AM
FQ777 AF957F 5.8G FPV With 2.0MP Camera One Key Return RC Quadcopter
$85.99
  • Channel: 4Ch
  • Gyro: 6 axis
  • Flight time: 6 -7 minutes
  • Control distance: 120 - 150 meters
  • Charging time: 60 minutes
  • Battery: 3.7V 650mAh 25C battery
  • Quadcopter weight: 129g
  • Quadcopter size: 340*340*80mm
  • Camera: 2mp(720P)
  • Photo: 1280*720
  • Video: 30fps
  • FPV range: up to 120 meters
  • FPV monitor: 4.3 inch/built-in 3.7V 500mah battery
Features:
  • FPV 5.8G transmission
  • 2.0MP 720P camera for pictures and videos
  • 6 axis stabilization system
  • Headless mode
  • One key return home
  • 4.3 inch FPV monitor screen
Sep 25, 2015, 03:02 AM
HiSKY HMX280 HMX 280 X-6S 2.4G Remote Control Transmitter
$49.99
  • Item Name: X-6S Transmitter
  • Battery:4 x AA (Not Include)
  • Dimensions: 21 x 18 x 5 cm
  • Weight: About 661 g
  • Compatible with X-6S, HMX280 Quadcopter
Sep 25, 2015, 03:07 AM
FeelWorld FPV719 500cd/m² 5.8G 32CH Wireless 7 Inch FPV HD Monitor
$123.99
  • Model: FPV719
  • Brightness: 500cd/m²
  • Resolution: 800*480 Pixels
  • Contrast: 500:1
  • Screen ratio: 16:9
  • Backlit: LED
  • Format: PAL-4.43,NTSC-3.58
  • View angle: 70°/70°(L/R)50°/70°(U/D)
  • Input signal:AV/RF
  • Power : Input voltage: DC:9~18V
  • Consumption: ≤13W(with battery)
  • Built-in battery :7.4v/2200mA(2hours)
  • Work temp.:‐20~50℃
  • Storage temp. : ‐30~65℃
  • Install with 1/4-20 screw hole for tripod mounting
  • Dimension:191L×134.7H ×23D (mm)
  • Weight: 380g/ 470g(with battery)
Sep 28, 2015, 04:59 AM
Eachine 800TVL 1/3 CCD 148 degree 2.6mm FPV Camera NTSC PAL
$18.79
  • Item Name :800TVL 1/3 CCD 148 degree 2.6mm FPV Camera
  • FOV:148°
  • Power Supply: 3.6-5.5V(powered by image transmission)
  • Current: 60mA@5V
  • Sensor: 1/3” CCD Over 800TVL
  • Type:PAL / NTSC (NOT free switch)
  • Resolution: 800TVL
  • Operating temperature: -20° C - 70° C
  • Camera Size: 32 X 32 X 23.5mm
  • Lens Size(Length x Diameter): 15.3mm X 14mm
  • Lens: 2.6mm IR coated
  • Weight: 12g
Sep 28, 2015, 05:02 AM
HJ 3DR Radio Telemetry 433MHz 915MHz Soft Antenna for APM PIX Pixhawk PX4 Flight Controller
$25.99
  • Complete compatible with 3DR radio telemetry, Air module(Serial) used for drone, Ground module(USB port) is used to connect computer on ground.
  • 433MHz and 915MHz optional.
  • With 2.5dbi antenna, the longest distance in highest transmitting power is about 1000m.
  • Tranmitting power is 11 in default parameter, if you wanna a longer distance, please adjust it by yourself.
  • When 2 modules are binding wireless, their parameter can be adjusted or upgraded by the APM ground station(Mission Planner); if they can't bind,and you want to set the Air module separately, you need a single FTDI tool to connect it, because the Air module only with TTL level serial port.
Sep 28, 2015, 05:06 AM
Matek 4S Lipo to 12V Linear Voltage Regulator Regulate Module For FPV Camera Multicopter
$1.99
  • Item Name: Linear Voltage Regulator
  • Input Voltage:13~17V, 4S LiPo
  • Output Voltage: 12V, accuracy 2.5%
  • Output Current: Continuous 300mA
  • Size: 25*10*3mm
  • Weight: 1g
Oct 05, 2015, 01:33 AM
Hubsan H107D FPV X4 5.8G 4CH 6 Axis RC Quadcopter VS Estes Protox FPV
$128.99
  • Item Name: Hubsan H107D FPV X4 Quadcopter
  • Motor(X4): 0820 Coreless
  • Frequency: 2.4GHz + 5.8GHz (Video transmission)
  • Transmitter: 2.4GHz 4 channels vs 4.3 Inch LCD
  • Control distance: 50 - 100meters
  • Live video distance: around 100 meters
  • Battery: 3.7V 380mAh li-po battery with auto cut off safety PCB
  • Charging time: about 30 minutes
  • Flight time: around 7 minutes
  • Camera: 0.3M pixels camera included, resolution: 640 x 480
  • Memory card: SD card inserted in TX, Micro SDHC class6 2-16G (not included )
Features:
  • Instant video review on transmitter
  • Lightweight airframe with nice durability
  • Latest 6-axis flight control system with adjustable gyro sensitivity
  • Permits super stable flight, flying outdoor & indoor
  • 4 night LED lights & rubber feet
  • USB charging cable allows to charge by computer or wall charger
Oct 05, 2015, 01:37 AM
V262 Upgraded WLtoys V333 Headless Mode 2.4G 6 Axis RC Quadcopter RTF
$87.99
  • Item name: V333 RC Quadcopter
  • Frequency: 2.4G
  • Channel: 4CH
  • Gyro: 6 axis
  • Flight Duration: 8-10 Minutes
  • Remote Control Distance: 100-150 Meters
  • Recharging Time: 1-1.5 Hours
  • Battery For Quadcopter: 7.4V 850 mAh(included)
  • Battery For Transmiter: 6 x AA Battery (not included )
  • V262 Dimesion: about 55 x 55 x 5cm
Features:
  • With Headless Mode,no need to adjust the position of aircraft before flying
  • Support camera,missile launcher,water connon,hook&basket and bubble blower
  • Large and lightweight airframe with nice durability
  • With 2.4G Transmiter, Easy Adjust Frequency
  • Full Scale Remote Control with built-in 6 axis gyro system
  • High capacity battery included,provide longer flight time
  • And upgraded version of the V262
Oct 05, 2015, 01:39 AM
Skywing Slick 38 Inch 952mm EPP 3D Aerobatics RC Airplane Kit
$89.99
  • Item Name: Slick 3D Plane
  • Color:Red,Blue(optional)
  • Wingspan: 952mm
  • Overall Length:985mm
  • Material: EPP
  • Flying Weight: 580g(without battery)
Oct 05, 2015, 01:43 AM
JJRC H16 YiZhan Tarantula X6 WLtoys V666 V686G V222 5.8G FPV 720P Camera With Monitor Real Time Transmission
$50.99
  • 5.8G 720P Camera with Monitor
  • Channel: 8CH
  • 4.3-inch Wide Screw
  • Resolution: 720P video, 2MP picture
  • 200mW 23DBM
  • Transmission Distance: 200-300m
  • Suitable for : JJRC H16 YiZhan Tarantula X6 WLtoys V666 V666N V686K V686G V222 and all other WLtoys RC Quadcopter with camera, can use their transmitters to control the camera for taking photo or recording video.
Features:
  • 5.8G 8CH optimal
  • 4.3 inch wide viewing angle and high-light screen
  • Maximal 600 meter of effective image transmission distance
  • Adoption of independent lithium batteries for camera, instead of using batteries on the aircraft.
  • Adoption of adjustable technology disturbance for 8 people all at once.
Oct 05, 2015, 01:45 AM
33X16.5mm FLIP32 MINI NAZE32 Flight Controller Support PPM Without Compass
$22.49
The smallest Flip32, runs Baseflight or Cleanflight software.
  • Size:33x16.5mm
  • Weight:2g without headers
  • 3-axis MEMS gyro + accelerometer (MPU6050)
  • Pressure sensor (MS5611)
  • STM32F103CBT6 32-bit Cortex M3 processor
  • Direct conntect to Airbot 35x35 GPS /Compass
  • Only supports PPM RC Input
  • 6 motor outputs for multirotor mode, incl. pads for Battery voltage monitoring
  • Additional UART pads for Battery and Buzzer
  • Direct connection of spectrum satellite
  • Onboard MicroUSB for setup and configuration
  • MultiWii-based configuration software for easy setup
NOTE: This is a PPM sum/S-bus/Spectrum satellite controller only. Make sure to add an ppm encoder if you want to use a normal pwm rx.
Oct 05, 2015, 01:47 AM
U-blox GPS GLONASS Module G7020 Chip Built-in TCXO for FPV Multicopter
$19.99
  • Main chip: U-Blox G7020
  • C/A code, 1.032Mhz flow
  • Receive channal: L1 [1575.42MHz]
  • Receive channal: 56CH
  • Compatible with GPS, GLONASS, L1OF, Galileo E1B/C1
  • Performance: <2.5m [Autonomous] [50%]
  • Max altitude: 50000m
  • Speed: < 0.1m/s
  • Max. speed: 500m/s
  • Acceleration:<4g
  • Capture sensitivity: -147dBm
  • Follow sensitivity: -160dBm
  • Refresh rate: 1Hz~10Hz
  • Cold start time: 30s (on average)
  • Warm start time: 30s (on average)
  • Hot start time: 1s (on average)
  • Operating temperature: -40~85 Celsius
  • Dimension: 16*18*5mm
  • Working voltage: 3.3~5.5V
  • Built-in 15*15*2mm ceramics antenna
Features:
  • Built-in TCXO devices to maintain good consistency within -40~85 Celsius.
  • First class 2dB low noise amplifier and low consumption filter
  • High ESD protection, ensure ESD can achieve 8KV
  • Default support wide range differential GPS enhance system
Oct 05, 2015, 01:50 AM
Eachine PCB Power Distribution Board w/ OSD Socket Support NAZE32 CC3D OSD For QAV250 Quadcopter
$8.59
  • Item name: Power Distribution Board
  • Size: approx. 183 x 66 x 1mm
  • Color: Black
  • Net weight: 51g
Features:
  • 100% Brand new and high quality!
  • Suit for NAZE32 and CC3D flight controller
  • With OSD Socket
  • ESC power and signal solder pads
  • Use For QAV250 Quadcopter
