Jan 23, 2018, 10:28 AM
indoor
1/35 RC tank
To make a Mark IV motorized , it is very easy !
The provided engine is working on 1,5V .
It uses one engine working on low voltage , it is better to replace it with a high voltage one from 3,5 to 6V.
Like this you can put a RC control module to make it working on normal use, stop or reverse .
Feb 04, 2018, 09:17 AM
indoor
1/35 RC tank
There is too in Bangood this product :
Dasmikro 1s5a micro esc
https://www.banggood.com/fr/1S5A-Mic...r_warehouse=CN
With it we can drive directly one electric engine and make it reverse speed if needed !
Feb 04, 2018, 11:20 AM
indoor
1/35 RC tank
Here is the the picture with the used input and output points on the module :
Some capacitors will be added to the electric engine.
Feb 05, 2018, 04:18 AM
indoor
1/35 RC tank
We will use two motors like this one:
Feb 06, 2018, 03:40 PM
indoor
1/35 RC tank
You can not put the cables directly on the pins of the printed circuit.
We must use solderable pins . The own cable will be on contact with it and some plastic shrink will protect the whole connection .
Feb 06, 2018, 03:50 PM
indoor
1/35 RC tank
You have to select the cable white red and black for the radio control input and the two "Bec "cables : ( red and black ) furnished with the module . You can see it on the left view on report #33
With this we can supply on the left the electric engine with a Lipo 1S with a female connector and on the opposite pins are the two connectors for the brushed motor.
Like this we can start safely to connect the module with the radio control unit.
Feb 07, 2018, 10:50 AM
indoor
1/35 RC tank
Two modules like theses one have connected to a transmitter Graupner 41 Mghz FM and receiver .
it is working very well !
Dec 31, 2019, 09:06 PM
Doing it in the Lateral Axis
modfly's Avatar
How about a video?
Here is a video of a 1/35 Tamiya APC that is a single engine crawler converted to RRC
Tamiya 1/35 scale M113 Personnel Carrier Dated 1974 on the Hull. (1 min 6 sec)
I used a toy grade 27mhz setup from a toy car in this one.
Discussion RC conversions for 1/35 tanks rva1945 RC Tanks 13 May 13, 2014 10:25 PM
Found 1/35 rc tank parts Felix_Dinel Cars - Cars and Parts (FS/W) 0 May 13, 2014 08:13 PM
Discussion T-62 Medium Tank in 1/35 scale - custom full realism RC tank78.com RC Tanks 2 Oct 12, 2012 06:33 AM
