Aug 27, 2015, 01:55 AM
ChuckTseeker's Avatar
New Product
E-Flite UMX P-47 BL BNF Basic
At last a 2s warbird YES! and one of my fave
Overview
The P-47 was built to give the pilot the most power possible. Nothing is more evident to this point than the shape of its fuselage which was designed around a revolutionary supercharger which gave the eighteen-cylinder radial engine its full-rated horsepower even at 30,000 feet. Combined with eight 50-caliber machine guns and a complement of bombs or rockets, the P-47 proved how versatile it could be especially when its superior diving capability was used to pounce on both air and ground opponents. The E-flite® UMX™ P-47 BL combines brushless electric power with a potent 2S Li-Po battery system for a commanding ultra micro warbird that’s sure to make flying this fighter an exhilarating experience.
The E-flite® UMX™ P-47 BL model is a warbird designed to satisfy fighter fans who want a scale ultra micro with gusto. Its lightweight foam airframe features a realistic outline and stand-out details. Packed inside are a brushless motor and a 2S Li-Po ready power system turns a realistic four-blade propeller. With the gear removed, the performance of this Major Howard D. “Deacon” Hively, P-47 tribute can fully come to life yet still offer the ability to land softly onto a grassy corner of the field. Or, you can leave the wide-track landing gear plugged in and use the steerable tail wheel for authentic ground handling. But no matter how you fly, innovative AS3X® technology makes this warbird perform as if you’re at the controls of a giant scale machine that’s been expertly tuned. Great handling, awesome performance—this is the ultra micro warbird you’ve always wanted.
Brushless Power
The 180BL brushless outrunner motor installed spins a realistic four-blade propeller to provide fighter-like acceleration and throttle response.
AS3X® Technology
The advanced AS3X® (Artificial Stabilization – 3-aXis) system built into the Spektrum™ 6-channel ultra micro receiver is what helps give the E-flite® UMX™ P-47 BL warbird an incredibly solid look and feel in the air. As a result, your workload to fly smoothly is significantly reduced while your control always feels natural so you can make your maneuvers look great more easily. It’s an impressive flight experience that will have you feeling like you’re flying an expertly-tuned warbird model that’s much larger.
Removable Landing Gear
Both main wheel struts and the tail wheel plug in so they are simple to remove for when you want to fly with the look of retracts up and locked.
Scale Detail
This P-47 tribute is based on the Thunderbolt Major Howard D. “Deacon” Hively flew with the 334th Fighter Squadron stationed in England during WWII. The realistic trim scheme is complemented by the dummy engine, scale wheels and four-blade prop.
Product Specifications
Wingspan: 19.0 in (482mm)
Overall Length: 17.1 in (434mm)
Wing Area: 69 sq in (4.45 sq dm)
Flying Weight: 3.35 oz (95g)
Motor Size: 180 Brushless
Recommended Battery: E-flite 200mAh 2S 7.4V 30C Li-Po Battery
Flaps: No
Retracts: No
Is Assembly Required: No
Detailed Information
Video Overview
E-flite UMX P-47 BL BNF Basic (2 min 21 sec)
Aug 27, 2015, 02:10 AM
I will be buying this.
Aug 27, 2015, 04:14 AM
chulian1819's Avatar
UMX? this plane is huge!!
Aug 27, 2015, 06:08 AM
Barrett_G's Avatar
Been waiting 3 years for this!!! I'm buying two!!!
Aug 27, 2015, 06:21 AM
They call me Lipo...
Justwingit's Avatar
WOW !!!
This little plane looks sweet.....thanks HH for destroying my wallet this fall.....
Aug 27, 2015, 06:32 AM
oops wrongway
AlfaMike's Avatar
I'm in - 2s makes all the difference. UMX Pitts is great, this should be too. Need a second job......
Aug 27, 2015, 06:33 AM
RC-addicted
Serge Roth's Avatar
Finaly, they listen...
A war bird in 2s and brushless!
More, HH, more!
Aug 27, 2015, 06:36 AM
too many planes
ww2birder's Avatar
Very cool..... I be flying this one indoor this winter if possible. The nose piece will be the first thing to be crushed. should be rubber or something other than foam.
Aug 27, 2015, 06:37 AM
mattman0182's Avatar
Yet another US plane. :/
Aug 27, 2015, 06:49 AM
Adam Stang's Avatar
Originally Posted by Justwingit
WOW !!!
You can't catch a break can you man? We are all plane broke! I have to agree with Chuck...this has been a long time coming. And I mean this in the best possible way...
THANK YOU HORIZON FOR NOT F'ING UP ANOITHER UMX WARBIRD WITH A CRAPPY BRUSHED MOTOR!!! THANK YOU SO MUCH INDEED!!!
I hope I didn't over state that...
Adam
Aug 27, 2015, 07:14 AM
"Is it hard to fix?"
YES!
I will be getting this one.. the Pitts was phenomenal! Can't wait!
(yup, I am a little exited over this one)
Aug 27, 2015, 07:15 AM
This looks sweet! Hope it's the first in a long line of 2S brushless warbirds...with the F4U Corsair close behind!
Suspect it will fly great with Hyp 240mAh Babbelbatts!!
Tom
Aug 27, 2015, 08:03 AM
I'd rather be flying!
turboparker's Avatar
Holy CRAP!!! HH listened!!!! Finally, a UMX figther with proper performance - and it's a Jug, no less!!! And it appears to have a semi-symmetrical airfoil!!
Thanks, guys!!!
Joel
Aug 27, 2015, 08:46 AM
Park Stormer
I got back into RC just in time
Pre-ordering ASAP!
That said, 20" wingspan and a 2S batt...It's less Micro, and more Ultra!
Edit: Wow, it's only $130
That's only $20 more than the UM Corsair.
Aug 27, 2015, 08:48 AM
Fly Low - Hit Hard
Red Flyer's Avatar
Carpe Diem !
I'm in.
RF
Sold BNIB E-flite P-47 BL BNF Basic blissinindy Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Dec 21, 2015 05:15 AM
