Aug 26, 2015, 01:49 PM
Throttle undress on its own on naze32/ clean flight
Hi guys I'm new and this is my first post so here it goes
Zmr250
Clean flight
Naze32
Over tried stock on figuration (old. Re wright/ flux.... )
All esc calibrated all end points calibrated
I hover but when I take off my hand from stick keeps climbing by itself. Or when I'm trying to go forward or any direction I'm also getting throttle increase and elevation without touching the throttle.
I don't know if I explained it well enough but that's what I'm getting and any help would be great
Thanks Zee
Aug 26, 2015, 03:31 PM
Team AlienWarpSquad
Just sounds like you need a lot of practice to learn how to fly.
Aug 26, 2015, 03:51 PM
I agree with the practice. But I don't think it depose to do what I explained or is it?
Aug 27, 2015, 05:35 AM
You haven't described a "problem". You have described an observation of flying and the difficulties thereof.
As well, it may be a matter of pids being a little off. But, not enough info to say that.
Robert
Aug 27, 2015, 02:48 PM
Ok dose the quad go higher in elevation without you touching the throttle?
For example if I go forward left or right not tuching yawl or throttle the quad gets throttle on its own resulting it gaining elevation (going up) is this a pid setting? Or ... Hope that clears it up or am I still not making sense
Aug 27, 2015, 03:26 PM
Team AlienWarpSquad
That can happen and may have many causes.
Properly Tuned PIDs can help.
What flight Mode??
How high above the ground( in ground effect)?
Aug 27, 2015, 05:18 PM
Dolmaracing,
On all 'better' tuned craft I've seen, yes, this occurs.
On those craft not tuned so well, losing altitude with motion happens.
On many a craft, without proper tuning, yawing will send you straight to the ground.
I would say that there is not ground effect problem here. There is a power, prop and weight problem.
This thing weighs close to or over 7lbs/3.175kg with a 4000mah battery. T-motors 2814 710kv. 12" props.
It will go up and over 1000 feet.
Needs smaller propellers or 4s system to run better: motors come down warm.
I get 6 or so minutes with the 4000mah battery.
I will be getting a 10kmah battery soon to fly with. And yes, now will buy one of those 10c 10000mah batteries to satiate my curiosity.
Robert
