Nov 10, 2017, 03:04 PM
Originally Posted by Yenya
OK, I'll wait for the linker script and further build process description. I hope I won't brick my i6 :-)
Oh, I see. This is why "git grep -i alt" didn't get anything meaningful.
OK, I will send a merge request. Hopefully this will not clash with future FlySky hardware. Anyway, is the sensor id assignment in your firmware compatible with that TGY-CAT01 altitude sensor?
Please check https://github.com/qba667/FlySkyI6/t...r/source/build
this linker script works on windows, on linux I am getting error because some sections overlaps (simply optimize code or remove overlapping sections).
@Mirko FPV Transmitter RX battery - there is also voltage alarm management.
Nov 11, 2017, 04:00 PM
got it, was the TX bat alarm
which is the suggested value for this alarm?
Nov 11, 2017, 04:05 PM
That will depend on what kind of batteries you have in it.
Non-rechargable AA, will be different to Ni-MH rechargable for example.
Nov 12, 2017, 04:38 AM
it would be nice to know both values
Nov 12, 2017, 04:50 AM
For a standard AA battery, I would say 1 V at the lowest for the alarm.
For Ni-MH I would suggest 1.1 to 1.15 V.
But note that it can vary between battery types (such as brand or "model"), sometimes significantly for the standard AA batteries.
An example can be found here:
http://denishennessy.com/images/bat_graph.png
You want to avoid that cliff at the right where the voltage drops.
Nov 12, 2017, 05:07 AM
perfect, thx for the reply
Nov 13, 2017, 03:41 PM
I have good news for you all - I have automated build process. Make script is working fine on Windows and Linux - the resulting binary is different but it is working fine.
Nov 13, 2017, 04:28 PM
"standalone" airspeed sensor
Hi everybody !
Did somebody made an airspeed sensor to ibus from arduino/PIC/AVR and differencial pressure sensor + pitot tube ?
An old dream to have alarm on stall speed.
Thanks in advance for evry info.
Nov 14, 2017, 01:42 AM
@cirki
Ibus protocol handling can be taken from here:
https://github.com/qba667/MAVLinkToI.../MAVLinkToIBUS
Instead of Mavlink data provide calculated vale from sensor:
https://forum.arduino.cc/index.php?topic=123976.0
Nov 14, 2017, 02:32 AM
Originally Posted by qba667
@cirki
Thanks a lot, I take a look at you code MAVLinkToIbus but at first it made some questions. I have arduino pro mini and has some hardware difference from arduinio micro. (LED_BUILTIN_RX/TX ; TCCR3A/B) It is possible to run on Pro Mini ?
It enought to include in new project IBUSTelemetry.h, and ppm.h or I will need other files?
In MAVLinkTelemetry.h I found the "airspeed" variable in that I can put the value of calculated data from analogread but I have lost in the details to find where I can put the sensor type value.
I think your MAVLinkToIBUS project is too complex for me.
Nov 14, 2017, 02:43 AM
ONCLEFLY's Avatar
New upgrade for better my Flysky FS-I6 @qba667 ?
Nov 14, 2017, 02:53 AM
@ONCLEFLY just few fixes we disused and CAT01 sensor - scheduled for next week. But now everyone can made changes to already hijacked code!
Nov 14, 2017, 02:56 AM
ONCLEFLY's Avatar
Thank you for new.
Nov 14, 2017, 01:34 PM
quadfly51's Avatar
the CAT01 ALT sensor! alrighty then !!!
Nov 14, 2017, 04:03 PM
If anybody interested on "standalone" ibus sensor(s)
Found the solution on github:
https://github.com/Hrastovc/iBUStelemetry
Simple softserial 1 wire iBus for arduino. Tested on arduino pro mini . Easy to configure multipe sensors.
