ZMR250 "Dragonfly" Tricopter - RC Groups
Aug 20, 2015, 06:48 PM
Just finished my ZMR tricopter, let me know what you guys think. Thanks.
Many thanks to these designs on Thingiverse:
BluefishNZ - ZMR250 Tricopter tilt assembly
Chr1s - ZMR 250 Uni-Spacer with Air-Slots
1. ZMR frame from BG
2. 3D printed spacer from Chr1s
3. 3D printed yaw assembly from BluefishNZ
4. DYS 1806 2300KV
5. KK2 mini with RC911 firmware (awesome)
6. ZTW 12A opto ESC
7. 5V 3A step down converter
8. Gemfan 6030 pros
9. Hitec HS-65MG servo
10. Zippy 3S 1000mah lipo (getting about 7 minutes with these)
ZMR "Dragon Fly" Tricopter (3 min 1 sec)
Aug 20, 2015, 07:40 PM
I void warranties
So these are built out of standard ZMR250 quad frames and front arms and a conversion tail / yaw setup? Is there parts for the conversion sold somewhere?
I like how short between the plates the thing is, looks great. Good pictures too!
Aug 20, 2015, 08:04 PM
Yes sir, built from a ZMR frame set. 3 arms were use along with the bottom and middle plate. The yaw assembly and spacer were 3D printed. The parts are not sold anywhere that I am aware off. If there are interests I can do a complete build log...
Aug 20, 2015, 08:22 PM
I void warranties
Yes please, this is only the second I've heard of this, I'd like to see it all done up! What do the 3D printed parts look like?
What size is it?
Aug 20, 2015, 08:37 PM
What size is it?
Here are the direct link to the 3D printed part on Thingiverse:
http://www.thingiverse.com/thing:916537
https://www.thingiverse.com/thing:889866
Anything that is green in the pics are 3D printed, except for the wiring sleeve that is.
Aug 20, 2015, 09:43 PM
noir522's Avatar
Whats even better is that the zmr250 can be had with an integrated pdb
Aug 21, 2015, 04:38 PM
Going to try printing this tonight.
Aug 21, 2015, 06:38 PM
That looks great, do you have the stl file I can try?
Aug 21, 2015, 06:46 PM
Sure, here it is. I haven't fit tested it yet. It's derived from the 3mm arm version.
I plan on printing it out of PLA, 20% hexagonal infill.
Aug 21, 2015, 06:47 PM
Awesome, going to print it right now and see the fitment.
Aug 22, 2015, 12:14 AM
Fly it like you stole it..
Tram's Avatar
That's pretty sweet!
Aug 22, 2015, 07:42 PM
Thanks.
Just an update, it has been flying so well that I'll like to make another one with jihlein middle 3D printed part that he modify. If I have all the parts then I'll update this thread with many pics as I go along....
Aug 23, 2015, 02:50 AM
says hello from Norway
helinor's Avatar
I was thinking of building one of these with a PTB board but looks like rear arm will interfere with the BAT solderings pads on it...?
Aug 23, 2015, 04:42 PM
Given that you used an HS-65MG servo for the tail control, did you print the servo mount for the TGY-210 or the TGY-9018 servo?
Thanks!
Aug 23, 2015, 05:26 PM
Thanks!
I use the TGY-210, that mount has a cut in the middle to clear the servo wires.
