Sep 07, 2015, 02:39 AM
anyone front mounted it? anyone has a photo of the back motor that controls roll? Are there screws visible or it's like the T2-D, shows no screw. looking at alternatives to fit it on the Xugongs.
Sep 07, 2015, 06:58 AM
ringolong's Avatar
Here is a pic of the back.
Sep 08, 2015, 09:25 AM
Had a quick flight with it, just a little jitter but other than that.Great
(0 min 28 sec)
Sep 08, 2015, 02:08 PM
kiosk's Avatar
you cant put an ND filter on the camera with this gimbal right? doesnt look like the attachment allows it....
Sep 09, 2015, 09:35 AM
I'm having trouble with hooking usb up to the gimbal controller when I have it connected to my Tarot Flight Controller. Only way is to pull out the connector from the cable going to the flight controller and putting the USB cable in.
With the size of these connectors, they won't last long.
Anybody having any success connecting & getting the GUI for the gimbal to work with the flight controller connected?
My issues is I seem to need a different roll motor torque setting when connected to the Tarot FC. Still trying to figure it out.... But I don't think I should keep pulling the cable connector out of the side of the Tarot Gimbal controller to switch between USB and FC.
Hopefully, someone can point out what I'm doing wrong.....
I use a separate radio receiver for the gimbal. I use sbus for the FC but a standard receiver for the gimbal.
Thanks in advance for any help.
Sep 09, 2015, 10:28 PM
thank you. looks like not mountable out of the box. a little mod could be needed.
Sep 10, 2015, 12:29 AM
albx's Avatar
I bought this gimbal, but I'm very disappointed, the Feiyu tech mini 3D have more features and is cheaper, why tarot haven't included a pan control and a mode where you can lock the camera to a point like the mini 3D ???
Sep 10, 2015, 03:32 AM
Hi albx, can I please ask where you bought the Feiyu tech for cheaper? Thanks.
Sep 10, 2015, 03:45 AM
albx's Avatar
http://www.banggood.com/FYMiNi3D3-Ax...-p-978464.html
and for europe it's 139,99
I haven't bought it yet, but I'm tempted to sell mine and buy it
Sep 11, 2015, 12:11 AM
I got mine last week , but only now I had a few minutes to check it out :
What I don't like so far -
Gimbal is not balanced with gopro 3+ on pitch and roll axis (badly on roll)
Unable to yaw 360 degree as there is little pin stoping it .
You need allen key to secure gopro
After you mount gopro there is very little room to put nd filter ( I won't be able to put mine wit this holder , I may use rubber band to secure a gimbal )
Yaw axis works, but not as good as dys smart gimbal ( out from the box )
I hope that help some of you
Sep 15, 2015, 07:24 AM
ringolong's Avatar
New video with the the gimbal connected to the controller, and gains adjusted. Mostly hovering, but flew a little bit.
I still need to move the gimbal to a better place.
[2] Tarot 680, ZYX-M, Tarot T4-3D 3 axis gimbal, DJI 3508, 6s 8000mah, Castle Creations, Gopro black (10 min 5 sec)
Sep 17, 2015, 01:18 PM
I m interesting in this gimbal but All videos seen was without wind and a loosing horizon.... what we ll see if it has wind out there?
Sep 17, 2015, 06:35 PM
ringolong's Avatar
Forward flight is in wind correct, or do you want to see hover in wind?
Not sure I know what "loosing horizon" means?
Sep 18, 2015, 01:51 AM
Yes hover/flight above 3-4b...
Not level on turns.
Alot of videos shows this issue
https://www.youtube.com/results?sear...ry=tarot+t4-3d
Sep 18, 2015, 01:54 AM
albx's Avatar
Originally Posted by harrysvr
Not level on turns.
I calibrated my sensors and it's perfect, always leveled
Sold Tarot GOPRO T4-3D 3 Axis Brushless Camera Gimbal tseaver FPV Equipment (FS/W) 1 Mar 13, 2017 09:59 PM
Sold Tarot GOPRO T4-3D 3 Axis Brushless Camera Gimbal airfilmx Aircraft - Electric - Multirotor (FS/W) 0 Sep 20, 2016 06:07 PM
For Sale Tarot GOPRO T4-3D 3 Axis Brushless Camera Gimbal airfilmx Aircraft - Electric - Multirotor (FS/W) 0 Sep 16, 2016 06:12 PM
Sold Tarot GOPRO T4-3D 3 Axis Brushless Camera Gimbal airfilmx Aircraft - Electric - Multirotor (FS/W) 0 Sep 11, 2016 09:31 PM
Sold Tarot GOPRO T4-3D 3 Axis Brushless Camera Gimbal airfilmx Aircraft - Electric - Multirotor (FS/W) 0 Sep 07, 2016 05:54 AM
