Aug 13, 2015, 12:10 AM
flygear's Avatar
AR9x board for Turnigy9x & TH9x
Original first post was moved to 2nd post. You may find some information regarding Rev. A board.
AR9x Rev. A was produced around mid Aug and offered to around 10 users to hear their thoughts and ideas to make better AR9x board for Turnigy9x & Th9x.
http://www.ar9x.net was setup on 8 Nov and AR9x Rev. B released on public with price $29.9
Just over a month lots of questions and answers gathered over many pages. it became very hard to find right answers for many. So, here I list up most useful guides and Q&As.
Even with this list up, sometimes very hard to find right answers. any questions please post here. Thanks.
schematic of AR9x Rev B is available.
Switching from OpenTx to Ersky9x, please refer
3. How to update firmware with eepskye.exe
4. How to flash Ersky9x firmware into AR9x
1. Installing AR9x into TH9x by dhooks6.
2. Latest & Test ver of Ersky9x for AR9x,
unzipped the file and flash "ersky9x_rom.bin" to AR9x
2.a. Er9x NEW User's Manaul
5. Update OpenTX firmware via Companion
6. voice Pack for Ersky9x
7. Ersky9x, Software Voluem adjust Enable
8. Solderless Telemetry connection
9. FrSky DJT mod for Telemetry
10. HobbyKing LCD BackLight connection to AR9x by Joćo
11. LCD BackLight wiring
12. 3 State Toggle switch mode example
13. Extra 4 switches and Pots example by Joćo
14. DS3231, RealTimeClock Install
15. RealTimeClock install example by Joćo
15.1. AR9x Button signal diagram
16. AR9x I/O diagram
17. Trainer Port use example
18. USB, SDcard vertical board schematic
19. Haptic motor drive current
20. How to recover dimmed LCD contrast after uploading Ersky9x
21. Pin Labels correction for Rotary Encoder
21.1 7-way Rotary Encoder wiring and pins
21.2 7-way Rotary Encoder mount 3D model from thingiverse.com
21.3 AR9x Simple Power Switch Wiring
21.4 Simple Rotary Encoder How to
22. How to flash an S.Port device via AR9x by andrewju
22.1 How to Enter hidden "HARDWARE" menu on Ersky9x
22.2 How to update SPort devices by AndrewJu
* SAM-BA is kind of ISP using USB connection to PC.
* It can be useful when Tx doesn't bootup with flash failure.
* Not recommended to use for simple firmware uploading.
23. SAM-BA how to do and Animation
24. SAM-BA download (https://www.rcgroups.com/forums/show...2&d=1450682596)
25. Main processor update
26. Schematic of AR9x Rev B.
Aug 13, 2015, 12:23 AM
RC Warjet
PM sent. Where are you located?
Aug 13, 2015, 12:25 AM
flygear's Avatar
move all First page posts to here
Previous first page of posting & it's all attachments moved here, so the first page can be shown to most updated information.
---------- original first posting --------------------
--- update 16 Nov 15 -------
Rev. B v1.2
1. Back light, Haptic, 2nd RF module connection guide image attached.
--- update 13 Nov 15 -------
Rev. B v1.2
1. Pin Labels correction for Rotary encoder, please refer attached photo.
2. Chip erase pin is relocated from Rev A. (Rev A no public release)
AR9x Sale site released 8 Nov 2015.
http://www.ar9x.net
AR9x Price release
"I strongly believe that it must be near to half of what original Tx price."
I think I can keep that word.
USD $ 29.9
include AR9x main board, Speaker, extra LCD cusion sponge.
Production schedule is set and all complete between 1st or 2nd week of Oct.
expecting first shipping between 3rd or 4th week of Oct.
Working on shipping option and should be set right after compeletion of production.
------------------ Previous Post --------------------
Hi
I built the board called "AR9x" and like to show here.
AR9x is replacement for FS-TH9x & Turnigy9X transmitter main board.
AR9x
Compatible to most known Open Source projects
No hardware modification required.
Simple and Easy replacement
No any additional tools required for firmware load or upgrade, beside USB cable & PC.
Here are most common Q&A I already have;
These are not for Sale! Start to sell from next production lot.
Next production in 4 to 6 weeks.
Price, strongly believe that it must be near to half of what original Tx price is. Fixed price available a week before next production.
------------------- Added Files ---------------------
1. AR9x board inserting guide.pdf
2. AR9x_ISP_guide.pdf ver1.1
3. sam-ba_2.15.zip
4. AR9x IO image
5. Chip Erase pin image
---------Beta Testing purpose Only--------------
6. ersky9x_rom_r217_mv3.zip
7. opentx-sky9x-en-2.0.17.zip
8. ar9x SAM-BA ISP in gif)
https://static.rcgroups.net/forums/at...6-ar9x_isp.gif
-- Edit --
Beta user offer removed.
----- original posting----
don't worry about the location..
Eeven shipping I'll pay for it.
btw, I'll start to send PM in a day or so.. right after make sure all 10 boards are packed first.
Thanks.
Aug 13, 2015, 07:25 PM
dhooks6's Avatar
Sent a pm,
Aug 13, 2015, 08:35 PM
AVR or ARM?
Aug 13, 2015, 08:54 PM
flygear's Avatar
It's ARM Processor
ATSAM3S8C from Atmel
Aug 13, 2015, 09:14 PM
Thank you. I'm primarily interested in it for a diy transmitter and also for conversion of some profi mc series transmitters from mpx, so I most likely don't qualify for your test batch but would possibly get a few boards when they become available for the general public. It would be great if you could share some technical details / specs.
Most important: Does it run OpenTx out of the box (possibly compatible with the 9xr pro) or would the FW have to explicitly support your board?
Aug 13, 2015, 09:52 PM
flygear's Avatar
Compatible with both OpenTX and ErSky9x.
let me gather detailed I/Os and so on.
Aug 14, 2015, 04:14 AM
Thank you for this board, seems to be the most balanced choice to run without any limitation the open firmwares available today.
Aug 14, 2015, 04:58 AM
Flying a Chipmunk in Portugal
jhsa's Avatar
It looks quite similar to the skyboard.. RTC?
Joćo
Aug 14, 2015, 05:15 AM
flygear's Avatar
Joćo
never seen Skyboard but they should be very similar to each other in function wise as board was build from Ersky9x and 9XR Pro source codes.
RealTimeClock? No need.
Aug 14, 2015, 05:54 AM
jhsa's Avatar
Yeah boards that support the same firmware should be very similar indeed Sorry about my comment above. It was quite stupid. Doohh
Hmmmm, allow me to disagree.. I do like the RTC, specially when I log all flights from my models and each of them has its own log book with date and time of every flight, together with notes if there was any situation, or if some repair was needed
But your board looks very nice. Do you have any specifications you could share? Voltages (batteries that could be used), etc??
Joćo
Aug 14, 2015, 06:35 AM
flygear's Avatar
Joćo
I had really big discussion about RTC.
Some really pushed me to put RTC back in.
However, my idea was why I have to pay for some features I don't even care and eventually it will bring cost up.
No RTC no problem to me.
Settlement was making it as an optional.
I'm not sure whether you can see it from the first photo on top, major bus, I/Os are intentionally box aligned with VCC, GND next to.
So, if any one desperate to get RTC, additional cheap board, really cheap board can be provided.
Well, that's the idea.
Aug 14, 2015, 06:45 AM
flygear's Avatar
Joćo
before put up detailed specification
min / Max Voltage = 7.2 V to 15V
max voltage can go up higher but most 2.4 RF module doesn't take higher 15V
Batt V, STM L7805CV , AMS1117 3.3V 1A used for MCU
separate STM L7805CV for 3W Audio AMP but 1W speaker provided.
from 2S to 3S are very Ok.
Of course Battery reverse protection made save the board and any RF module attached as well.
Current Consumption 77mA with sdcard in
without Haptic, LCD back light, RF module.
Aug 14, 2015, 07:09 AM
ErskyTx Developer
Mike Blandford's Avatar
Does it include power switches for internal and external RF modules?
I would agree that having a RTC as standard would be useful. Any files stored to the SD card (log files, model files) really need the date-time included.
Is the I2C bus available?
Does it include current consumption monitoring (current used by the Tx)?
Does it include a power switch for the third serial port? This is something useful for handling a bluetooth module.
I assume it includes a soft power switch for the main board power, needed to ensure the external EEPROM is updated. How is this handled/monitored? The I/O pin used is connected to circuity that also monitors the power being enabled by the trainer jack plug to select student mode.
Does this board support the FrSky SPort? If so, does the connection incude protection if a modified DJT is used that outputs +/- 6V on the telemetry signal.
The SKY board came first. The design was then used for the 9XR-PRO.
Ersky9x is conditionally compiled for the different target hardware, SKY, 9XR-PRO, 9Xtreme, Taranis, Taranis+ and the FrSky X9E. The same applies to openTx.
If this board is compatible with the firmware, then which version of the firmware does it use, or will it need a specific compile version?
Mike.
Sold AR9x board for Turnigy9x & TH9x patzig Aircraft - General - Radio Equipment (FS/W) 1 Apr 04, 2017 06:37 AM
