Jan 27, 2017, 07:15 AM
Hi guys, anyone here has opted for a 55T on 3S setup?
I've seen a video comparing, and 35T on 2S has almost the same speed as 55T on 3S, but the later has more torque, right?
Any reason not to go the 55T/3S way? besides, I already have some 3S batteries, so it would be cheaper for me to go this route...
Apr 06, 2017, 07:29 PM
biomecanoid's Avatar
Hello,
I have the Austar D90 body and i am looking for a cheap chassis to match it.
Do you think i can put it on the HG P402 ?
Apr 07, 2017, 05:54 PM
parajared's Avatar
What is involved in removing the stock receiver and putting a replacement receiver in?
I am considering FPVing one and I need a 3rd channel to control a pan camera.
Apr 08, 2017, 10:35 AM
Does your transmitter have a 3rd channel ?
Apr 09, 2017, 10:28 AM
parajared's Avatar
Originally Posted by biomecanoid
does your transmitter have a 3rd channel ?
16 channels
Apr 09, 2017, 11:27 AM
16 channels ? Are you using a heli/plane Tx to run you car ?
Apr 09, 2017, 01:15 PM
What protocol are you running ? FrSKY ? FlySKY ? something else ?
Apr 09, 2017, 05:38 PM
parajared's Avatar
FrSKY
I want to use either the elevator channel (which springs back to center) or offset mixing + a mode switch to do reverse.
Apr 09, 2017, 05:50 PM
I use these:
http://www.banggood.com/FrSky-V8FR-I...?rmmds=myorder
in EVERYTHING, cars, planes etc lots of channels, High Voltage and diversity
If you want something cheaper you can get the FrSky-V4FR with 4 channel and without diversity
Apr 11, 2017, 09:32 AM
parajared's Avatar
Thanks Biomecanoid,
Looking at the replacement parts list it looks like I will have to install my own brushed esc and my own rx to make it work. It looks like the servos have wires coming off them which is good. Some of these rc toys have everything integrated into a circuit board which makes it really hard to mod.
2nd,
Do you know what is involved in servo actuated 2 speed gearbox mod? What sized servo do I need? Is it just a servo and a pushrod?
Jan 21, 2018, 09:09 AM
SilbernerSurfer's Avatar
Well this HG P402 has locked diffs, right?
Would it make sense for long range FPV to upgrade to remote lock diffs?
And of course to upgrade to the remote shifting gear?
Are remote lock diffs available for this car?
Is this a kind of copy of the Traxxas TRX-4?
Jan 20, 2019, 06:14 PM
Where o where has my America g
stsguy's Avatar
I need parts
Where is the best place to get an esc? I bought this at a show but the parts I have are not correct
Mar 25, 2019, 10:59 AM
HG-P402 Gears & Grease
HG-P402 Gears & Grease (A look inside) (1 min 43 sec)
May 13, 2019, 08:39 AM
May someone point me to the main thread of the HG P402, pleas? I cant find it via search engine or google!
Thanks in advance!
Nov 13, 2019, 08:49 PM
HG P402 4WD 1/10 (Banggood.com) (11 min 46 sec)
