In my case I will be using a LiFe battery with 10V, so 5Vx0.5A is 2.5W to dissipate in heat. |
I spent last night and this morning looking into how to integrate a voltage regulator of some sort and the results aren't too promising. The 2 main issues are heat, and/or size of components.
The only option i can see is add some pads to attach one of these http://g02.a.alicdn.com/kf/HTB1AJ1cI...per-LM2596.jpg |
I did see your post but failed to respond in my previous post. That is an almost perfect option apart from the component price. I think the step down i linked would be the most cost affective solution.
https://www.pololu.com/product/2831 or this so it can run from a little 1s pack. https://www.pololu.com/product/2564 |
Great project here. I like building with through hole type components and am wondering if this would be the correct digital switch:
http://www.digikey.com/product-detai...061-5-ND/67313 Thanks in advance |
I've looked into the options for regulators and by far the easiest way to is to add a spot for the step-down regulator I linked earlier, 'DSN-MINI-360'.
This will be on the rear of the board and be connected via single header pins or pieces of single core wire. Let me know your thoughts. |
Hi guys, I've got my parts orderd for making one of these (non diversity). Thing is, I don't really need the rx portion of it, the entire reason I bought the parts is to run as a 5.8 spektrum analyzer as part of my ground station.
Is there a way I can comment out some of the init's so it fires right up in scanner mode and that's all it does? Could I then even build it without the buttons, just an arduino, the rx and the oled? |
Or maybe on the rear of the rx receivers, I think the regulator won't add interference in the RF. |
| Similar Threads | |||||
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| Mini-HowTo | DIY: Diversity Receiver - rx5808-pro-diversity - clone | badzz | FPV Equipment | 133 | Sep 25, 2018 09:56 AM |
