Aug 10, 2015, 12:10 PM
SeByDocKy's Avatar
Mini-HowTo
DEVO 7E Tutorials (Under construction)
AVANT-PROPOS
Here is a serie of tutorials dedicaced to the Devo7E radio, a compact lightweight model compatible with the DeviationTX OS
This opensource software permits to control third party radio frequency chips and by consequence to support a lot popular protocols:
DSM2/DMX2/FrSky/Flysky/V202/SYMA, etc....
A total of seven videos to achieve the building of the super "Devo7E". The objective is to stimulate beginners by showing basic steps of the 6 proposed mods.
As not being an electronician, I am sure purists can criticize some parts but at least these videos can be used as a starting point.
I am giving also a list of materials and tools mainly in Banggood because they referenced almost all requierements
The main item, you will need is a Devo7E (the E is important because there is a Devo 7 not deviationTX compatible)
http://www.banggood.com/Wholesale-Walkera-Devo-7E-7CH-Transmitter-Mode-2-Without-Receiver-p-48117.html
Tools
1) In general, you will need one or two good soldering irons, at least one with a thin tip
http://www.banggood.com/907-Constant-Temperature-Electric-Soldering-Iron-Lead-free-22OV-60W-p-920554.html
and
http://www.banggood.com/9-in-1-Electric-Soldering-Tools-Set-With-Iron-Stand-Desolder-Pump-p-924163.html
2) An Iron tip cleaner
http://www.banggood.com/Wholesale-1-...105842201212FR
3) Third hand with Magnifier
http://www.banggood.com/New-2_5X-7_5X-10X-LED-Light-Magnifier-Stand-Clamp-Magnifying-Tool-p-90554.html
4) Heat shrink tube
http://www.banggood.com/Wholesale-30mm-Adhesive-Polyolefin-31-Heat-Shrink-Tubing-Tube-Sleeve-Sleeving-Wrap-1_6ft-p-47178.html
5) Tweezers
http://www.banggood.com/7pcs-BGA-Precision-Tweezer-Set-Antistatic-Tweezers-Stainless-Tweezers-p-924799.html
6) Pliers
http://www.banggood.com/4Pcs-Mixed-Needle-Round-Nose-Pliers-Tool-Kit-Jewelry-Making-Tool-p-930792.html
7) Magnifier glass
http://www.banggood.com/20X-LED-Magnifier-Magnifying-Double-Eye-Glasses-Loupe-Lens-p-943829.html
8) Electrical tape
http://www.banggood.com/3M-Electrical-Insulating-Tape-Household-Electrical-Adhesive-Tape-p-931869.html
9) Flux
http://www.banggood.com/Wholesale-10cc-Repair-Tool-Solder-PCB-SMD-Soldering-Paste-Flux-Grease-SMT-BGA-IC-RMA-223-p-35758.html
10) Hex screwdriver
http://www.banggood.com/ProsKit-HW-221M-8-In-1-Folding-Aluminum-Hex-Driver-Wrench-p-990134.html
INTRODUCTION
Introduction to DeviationTX OS possibilities
Devo7E tutorials: part1 - introduction (9 min 55 sec)
DEVIATIONTX INSTALLATION
How to install DeviationTX with your fresh Devo7E. Without any modding, by just installing this OS, you can fly DSM2/DSMX/J6Pro
protocols but with limited range
- Nightly Build
http://www.deviationtx.com/downloads...nightly-builds
- DevoDfuse V2.0
http://www.walkera.com/en/upload/upgrade/
or
http://www.hobbyone.com.hk/updater.php
Devo7E tutorials: part2 - deviationTX installation (14 min 57 sec)
DISASSEMBLING THE DEVO7E
You will need a 2mm hew screwdriver
Devo7E tutorials: part3 - devo7E disassembling (7 min 39 sec)
CYRF6936 DIODE MOD
The hardest mod to do with your Devo7E. If you don't plan to use intensively the DSM2/DSMX/J6Pro protocols,
you can bypass this mod. In the worst case, if you diode mod failed, you can install in replacement the CYRF6936 module of the DEVO8S
http://www.banggood.com/Walkera-WK-DEVO-S-MOD-Upgrade-Module-DEVO-8-12-To-DEVO-8S-12S-p-922596.html
Alternatively if you don't want to jump with a wire the diode, you can use this conductive ink
http://www.banggood.com/0_3mL-Conductive-Silver-Paint-Wire-Paste-Grease-For-Electronics-PCB-Repair-p-976248.html
Devo7E tutorials: part4 - CYRF6936 diode mod (31 min 14 sec)
CYRF6936 ANTENNA MOD
The antenna mod permits to install for example any kind of 2.4G antenna and/or a WiFi booster to extend the range.
You will need a RG316 cable ending with RP-SMA connector
http://www.banggood.com/6Inch-15cm-RG316-Cable-Connector-RP_SMA-Male-Jack-to-Female-Plug-Bulkhead-Crimp-p-983166.html
and a 2.4G antenna. I select this model (you can choose any 2.4G model you want as soon it's ending with a RP-SMA connector)
http://www.banggood.com/Wholesale-Dual-Band-2_4-or-5_8Ghz-6dBi-RP-SMA-Omni-Directional-Wireless-WiFi-Router-Antennas-p-49578.html
Devo7E tutorials: part5 - CYRF6936 antenna mod (27 min 10 sec)
3x2 SWITCHES MOD
This mod is very useful to add the usage of two extra channels. For example to select a flight mode of a DIY racer.
Here is the pinout (courtesty Daryoon)
You will need:
- 2 x 3-way switch
http://www.banggood.com/RC-Tranmitter-Switch-For-Walkera-Futaba-FlySky-WFLY-JR-p-989223.html
- 4 x 1N4001 diodes
http://www.banggood.com/25-Pcs-1N4001-IN4001-Diode-1A-50V-Assortment-Kit-Set-p-932504.html
- 1 x Dupont wires
http://www.banggood.com/40-x-30cm-Male-To-Female-DuPont-Breadboard-Jumper-Wire-Cable-p-89708.html
Devo7E tutorials: part6 - 3x2 switches mod (59 min 52 sec)
NRF24L01 MOD
The installation of a nRF24L01 RF chips permits to control most of toys's protocols: WLtoys, SYGMA, YD717, Cheerson, Hantai and many more. So if you have more some nanos, micros, and minis, the nRF24L01 is probably a "must to install" into your Devo7E.
You can find the nRF24L01 pinout at
https://bitbucket.org/PhracturedBlue...eModuleInstall
and the devo7E pinout
You will need:
- 1 x nRF24L01
http://www.banggood.com/2_4G-NRF24L01-PA-LNA-Wireless-Module-1632mm-Without-Antenna-p-922601.html
- 1 x uFL to RP-SMA coaxial cable
http://www.banggood.com/10cm-PCI-UFL-IPX-to-RPSMA-Female-Jack-Pigtail-Cable-p-924933.html
- 1 x 2.4G antenna
- 1 x Dupont wires
- 1 x Copper foil EMI shielding
http://www.banggood.com/Wholesale-6-Feet-X-50mm-Copper-Foil-Tape-EMI-Shielding-for-Fender-Guitars-6-ft-X-2-p-49769.html
Devo7E tutorials: part7 - nRF24L01 mod (52 min 59 sec)
CC2500 MOD
The installation of a CC2500 RF chips permits to control mainly two FrSky protocols, i.e. the D8 and V8.
FrSky are known to be one the best protocols in term or range (> 1km) and support telemetry. Ideal for DIY racers.
You can find the CC2500 pinout at
You will need:
- 1 x CC2500
http://www.banggood.com/CC2500-PA-LNA-Romote-Wireless-Module-CC2500-SI4432-NRF24L01-p-922595.html
- 1 x 2.4G antenna
- 1 x Dupont wires
Devo7E tutorials: part8 - CC2500 mod (1 hr 2 min 38 sec)
Aug 10, 2015, 12:11 PM
SeByDocKy's Avatar
Reserved
Aug 10, 2015, 12:21 PM
I void warranties
Please dont overlook the brand new extra POT mod we've got going on at Devo forums! Up to 6 additional analog inputs (NOT counting the two add-on 3-way switches you have mentioned)!!
http://deviationtx.com/forum/7-devel...-for-devo-tx-s
Aug 10, 2015, 12:24 PM
SeByDocKy's Avatar
Yes probably the next video I will do
But already these videos requiered to me a lot of efforts ...
Aug 14, 2015, 07:16 AM
I void warranties
What range are you guy's seeing out of the various CC2500 modules with the different FrSky 2-way receivers?
Sep 09, 2015, 04:44 PM
Is there any chance you could help me, Iīm new at this and just got my first brushless quad (eye one extreme) I want to use this controller with the one link but not sure how to. Tried once but on the seventh channel I get stuck. also donīt have a sport mode option, just beginner or expert.
any help I would appreciate. Tried looking on other threads but can't find nothing.
Thank you
Sep 28, 2015, 03:52 AM
Brisbane, Australia
I really appreciate you doing this thread SeByDocKy. Thanks
Oct 01, 2015, 12:25 AM
SeByDocKy's Avatar
Thank you
What you can do is to install a DSMX compatible receiver with your EOX
Oct 01, 2015, 12:26 AM
SeByDocKy's Avatar
Thks
Oct 06, 2015, 03:48 PM
thearne3's Avatar
I need some advice:
I removed the old Tx to install the new 12s full power module and lost some solder tabs on the board. (Honestly, I don't know how this doesn't happen most of the time!). Specifically 2 and 3 counting from the left (blue and orange in the Hacks instructions).
Is there any other way to get to these inputs? If not, any reason to keep the unit or just toss in the garbage? ;-(
Oct 08, 2015, 05:00 AM
Brisbane, Australia
thearne3 do you still need this info, I can have a look tomorrow if you want.
Oct 08, 2015, 10:55 AM
thearne3's Avatar
Hi all,
SeByDocKy was kind enough to respond in a PM. In case anyone else has this problem:
Carefully scratch through the board at each tab spot. A silver/copper spot will eventually appear. They are small, but I was able to solder to each. The leads are definitely delicate, so I'm hoping the connections last! I may try reinforcing with hot glue...
Oct 09, 2015, 07:25 AM
Brisbane, Australia
Thats good to know thearne3, I was hoping there would be some other spot to attach the wires to but obviously not.
SeByDocky, my new Devo 7e arrived and I was able to follow your video for installing the firmware with no hiccups, it all went very smooth! Nice job you did. I also installed an nRF24L01 module, for the antenna I soldered a 31mm wire onto the centre of the antenna connector, so far I've had no range problems (the module has the power amplifier in it). I can bind and fly all my nano/micro quads with this tx, as well as my micro planes. This is SO convenient. The firmware (and whole project) really is a credit to those who developed it. The 7e has a light and accurate feel in the sticks and its way easier to fly the quads than with the stock tx's which means more flying and less crashing I won't be adding any switches to this tx because I like the minimalist look. With the ability to set up switches or virtual pots with the trim and display buttons, I don't think I'll need any extra switches (plus my needs are basic). Next I will investigate rechargeable battery options for the 7e, and figure out if I need to do the range mod on the DSM2/X module, if I don't need the range I won't do it (and save battery power). The only minor downside is finding out how to actually set up a model and use the radio, there is documentation, but the fine print and hands-on how-to's are spread about the forums posted by Devo owners. Nothing that a bit of digging around can't fix.
Oct 21, 2015, 09:11 AM
SeByDocKy's Avatar
Yes 99.999% of credit to PB who did this amazing deviationTX project
Oct 22, 2015, 01:36 PM
Hey I noticed that the the Devo S mod seems to be gone from BG now and I don't see it anywhere else for any reasonable price... does that mean that now you are risking your Tx by doing the range mod?
