This thread is privately moderated by Dongskie, who may elect to delete unwanted replies.
Aug 07, 2015, 12:31 PM
Dongskie
Dongskie's Avatar
Build Log
Electric to Gasser Conversion
Building and DIY conversion has always been a challenge for me specially crazy ideas..
Recently I got this cheap electric HUGE RC boat that runs on 3x 550 motor but runs incredibly slow!!
So I looked into my toolbox and found everything I need to do a conversion, a CRAZY idea came to my mind
First here is a review of the electric rc boat "Ocean Queen"
Aug 07, 2015, 12:42 PM
Dongskie
Dongskie's Avatar
Here are a couple of pics of the boat in current state when I got it... I will add the photos for now and update the description as I go along.
The stock electronics have been removed (and thrown away) by the previous owner because he had plans to convert it to nitro power, but his plans had been shelved and never got to work on it.
This is the hull and as it is, there are supposed to be drives 3 propellers in the original setup, as you can see there are 3 protruding drive humps under the hull and as far as I know that isn't a very efficient design.
This is the 4mm drive shaft and the 50mm plastic propeller.
The plastic rudder and an extra drive shaft and the aluminum cooling coil.
Aug 07, 2015, 12:52 PM
Dongskie
Dongskie's Avatar
Found some time to remove the 3 protruding drive line humps.
Laid 2 layers of fiber glass and resin on it.
Aug 07, 2015, 01:18 PM
Dongskie
Dongskie's Avatar
Working on the DIY motor mounts.
Fronts done... or rear??
Front and rear motor mounts done.
Aug 08, 2015, 01:21 AM
Pronoun trouble...
DismayingObservation's Avatar
That's so "crazy" that it's pure genius. Good luck with the conversion! Nice to see someone going from electrons back to internal combustion since it's been the other way around as of late.
Aug 09, 2015, 11:05 AM
Dongskie
Dongskie's Avatar
Totally crazy idea mate, I had been in doubt with this project until I was able to do the DIY motor mount and my hopes became high
The drive line design took me days to think of LOL
Aug 09, 2015, 11:17 AM
Dongskie
Dongskie's Avatar
So I basically had an extra engine from an HPI Baja and it didn't have the standard carb on it but I got a very cheap carb from a big airplane engine and totally looked so different from the stock HPI carb..... and the carb didn't have the normal throttle linkage from the usual HPI ones.
Aside from the unusual throttle link, it didn't have a primer pump too, and this had about 4 inlet tubes!
Here is a closer and blurry photo of the linkage I made.
- blue aluminum stand-off tube as an extension is directly bolted on to the throttle plate shaft
- an HPI servo horn glued and bolted on the opposite end of the stand-off to serve as the linkage lever and mount
- along rod to be connected to the servo arm and pull operation to open the throttle plate.
Aug 09, 2015, 11:32 AM
Dongskie
Dongskie's Avatar
Finalizing the drive line was based on the CG of the boat and is also affected by the location of the engine...
After measuring the CG, I came up with this length for the propeller shaft.
The propeller shaft above is based on a stock Tamiya TT-01 dogbone, chopped in the middle, and forced-fitted, glued and pinned inside the aluminum tube.
Here is the mock set-up.
I hand rolled the shaft to check for binding and alignment.
Aug 09, 2015, 11:38 AM
Dongskie
Dongskie's Avatar
I found out that the bottom inlet tube of the carb was for the pulse pump.
The one with a clear silicone hose was the overflow/return fuel line back to the gas tank.
The top black hose was a breather line, no need to connect to anything.
The right most hose is the fuel inlet line.
Aug 09, 2015, 11:39 AM
Dongskie
Dongskie's Avatar
A mock set-up revealed that I don't have much room to work on
Aug 09, 2015, 11:43 AM
Dongskie
Dongskie's Avatar
Another issue found! Too close for comfort
Aug 09, 2015, 11:44 AM
Dongskie
Dongskie's Avatar
Bling bling
Aug 09, 2015, 11:47 AM
Dongskie
Dongskie's Avatar
Fitted the radio box and servos.
Aug 09, 2015, 12:04 PM
Dongskie
Dongskie's Avatar
Tuning the engine before permanently gluing the engine mounts.
23cc boat engine DIY (0 min 31 sec)
Testing after glue have dried
23cc rc boat engine (0 min 56 sec)
Oct 25, 2015, 04:34 PM
Dongskie
Dongskie's Avatar
Late development, my propeller has arrived and made an adaptor for it.
Originally for a 4mm shaft, I had to look for an adaptor to fit it on my current shaft that holds 3mm prop.
Discussion electric vs gasser template for firewall DuHAst Engines 1 Nov 27, 2016 01:08 PM
Sold Losi 8ight-T Truggy .31 gasser converted electric ARR Like NEW upgraded jmscard Cars - Trucks and Parts (FS/W) 3 Oct 07, 2016 08:55 AM
Sold Losi 8ight-T Truggy .31 gasser converted electric ARR Like NEW upgraded jmscard Cars - Trucks and Parts (FS/W) 0 Sep 19, 2016 09:46 AM
Sold Losi 8ight-T Truggy Gasser converted to electric only run 3 times! NO ESC or Radio jmscard Cars - Cars and Parts (FS/W) 4 Sep 13, 2016 12:06 PM
Sold Losi 8ight 3.0 Gasser to Electric Conversion AS NEW RTR Spektrum Mamba Monster Lipos jmscard Cars - Trucks and Parts (FS/W) 4 Apr 03, 2016 09:06 PM
