E-flite® Pawnee Brave Night Flyer - RC Groups
Aug 06, 2015, 02:40 AM
ChuckTseeker's Avatar
New Product
Brave Night Flyer BNF Basic
http://www.e-fliterc.com/Products/De...D=EFL6950#home
Key Features
AS3X® technology for rock-solid flight stability
External LED NAV lights (installed)
Pushbutton controlled, internal LED airframe night lighting (installed
Includes hardware needed for optional working flaps
Spektrum™ 6-channel AR636A DSMX® receiver (installed)
Powerful 15-size brushless motor (installed)
E-flite 40-amp brushless ESC (installed)
(4) Spektrum A330 Micro Servos (installed)
Accepts 3S 2200mAh Li-Po battery packs (sold separately)
Constructed with durable Z-Foam™ material
Sturdy aluminum main landing gear
Lightweight chrome spinner with 3-blade propeller
Painted canopy with a clear view of the pilot and cockpit
Easy to complete final assembly
Overview
The E-flite® Pawnee Brave Night Flyer is a scale park flyer for the intermediate pilot who wants a nimble airplane that can be flown practically any time of day. Like a respectable crop duster should, this scale-inspired design packs plenty of power under the hood. Besides four-channel control and a steerable tail wheel, working NAV lights add a touch of realism that make getting up early for flights at dawn more than tempting. Even more vibrant is the hollow-core structure that’s been filled with a pushbutton controlled, LED lighting system so that it’s practically impossible to lose this model in the dark. In addition, finely-tuned AS3X® technology adds the kind of stability that makes dusting the ground low-and-slow pure joy.
The Scale Delight You Can Fly at Night
The agriculture business attracts a wide range of pilots all wanting to make screaming down on the deck and between power lines a seasonal job. Dedicated crop duster designs truly put the needs of the pilot in the forefront with features like protective cockpits and gobs of power to make tight turns safe. Happening upon a crop duster in action over a lush field of grain is equivalent to an impromptu air show complete with low passes and graceful arcing turns. The E-flite® Pawnee Brave Night Flyer model allows RC pilots to dart across the field just like the real thing, day or night.
Like a respectable crop duster should, this scale-inspired design packs plenty of power under the hood. Besides four-channel control and a steerable tail wheel, working NAV lights add a touch of realism that make getting up early for flights at dawn more than tempting. Even more vibrant is the hollow-core structure that’s been filled with an LED lighting system so that it’s practically impossible to lose this model in the dark. In addition, finely-tuned AS3X® technology adds the kind of stability that makes dusting the ground low-and-slow pure joy. And if you want to slow down even further, you have the option to make the built-in flaps operational by simply adding two servos.
Technology that makes flying more satisfying
The advanced AS3X® (Artificial Stabilization – 3-aXis) system built into the Spektrum™ 6-channel AR636A receiver is what helps give the E-flite® Pawnee Brave Night Flyer an incredibly solid look and feel in the air. It works behind the scenes to help counter the effects of wind and turbulence by combining 3-axis sensing with specially tuned flight control software. As a result, a nimble crop-duster like the Pawnee Brave is made even better because your workload to fly smoothly is significantly reduced.
Internal LEDs
The hollow-core structure of the Z-Foam material has been filled with white LED lights. Just press the button inside the battery compartment and the entire airframe will brilliantly glow in the dark.
External NAV Lighting
Inspired by the full-scale, external navigation lights on the wing tips, plus the landing light recessed into the wing lead edge offer an addition sense of flight orientation.
Optional Flaps
You can add a higher level of scale performance by making the built-in flaps functional. All the hardware has been provided to suit the addition of two micro servos required.
Product Specifications
Wingspan: 48.0 in (1217mm)
Overall Length: 36.6 in (930mm)
Wing Area: 382.6 sq in (24.68 sq dm)
Flying Weight: 45.8 oz (1300g)
Motor Size: 15 Electric
Radio: 5+ channel minimum
Recommended Battery: 2200mAh 3S LiPo
Assembly Time: Less than 1 Hour
Is Assembly Required: Yes
Detailed Information
Video Overview
Pawnee Brave Night Flyer BNF Basic (2 min 20 sec)
Aug 06, 2015, 02:52 AM
oops wrongway
AlfaMike's Avatar
Hopefully a review coming Chuck? Looks tempting!
Aug 06, 2015, 09:22 AM
peterswolf's Avatar
That looks pretty cool!
Aug 06, 2015, 09:55 AM
I wonder when that cargo container will reach California.
Aug 06, 2015, 12:26 PM
On the ol' Interweb
Subscribed
Aug 06, 2015, 12:52 PM
Tree hopper
gabe221's Avatar
T a g !!
Aug 06, 2015, 02:34 PM
Michael Heer's Avatar
E-flite lists it as available in October. I would have started the thread in scale but it can be flown at most parks. Mike H
Aug 06, 2015, 02:40 PM
Ron Lauser
PACubFlyer103's Avatar
Damn! Another one to put on my list! I'd better start making room in the hangar.
Aug 06, 2015, 03:05 PM
Tree hopper
gabe221's Avatar
No need to worry, there'll be @ least 3 other threads, as usual.
Aug 06, 2015, 03:08 PM
Stitching 'em back together!
stitch1's Avatar
Looks good.
Aug 06, 2015, 03:58 PM
GLHS592's Avatar
I like it. I hope they offer it PNP without the led lighting.
Aug 06, 2015, 06:46 PM
Lower AL
SeeMeDo's Avatar
Dusty just started choking today when I opened the email, looks like I may need to find a home for my C-188. Like the size hope it does well.
Jeff...............
Aug 06, 2015, 07:41 PM
oops wrongway
AlfaMike's Avatar
I really need to put in a complaint. This is just killing me, this Pawnee looks great but there's also a new Radian, umx P3 Bipe, umx F16 plus all the others I still need to add to my collection. (Corsair, Mosquito, P51 etc). Plus I'd like to upgrade from my DX6i. Just can't handle it (nor can my wallet)...........
Aug 06, 2015, 09:28 PM
I'd rather be flying!
turboparker's Avatar
Oh, oh. Gotta have this one, along with the UMX F-16 & the UMX version of Skip Stewart's new P3!
I've got a serious soft-spot for the Pawnee. Back in the early 70's, I sometimes flagged for the guy my dad moonlighted for. He had a Pawnee & a Snipe Commander.
Joel
Latest blog entry: Landing tutorial
Aug 06, 2015, 10:12 PM
Tree hopper
gabe221's Avatar
Originally Posted by turboparker
I've got a serious soft-spot for the Pawnee. Back in the early 70's, I sometimes flagged for the guy my dad moonlighted for.Joel
We use GPS and smoke now.
Video E-flite Pawnee Brave Night Flyer BjarneKvilvang Electric Plane Talk 0 May 11, 2016 03:47 AM
For Sale E Flite Pawnee Brave Night Flyer BNF haliotis Aircraft - Electric - Airplanes (FS/W) 0 May 04, 2016 07:13 PM
Sold E-flite® Pawnee Brave Night Flyer alan1h Aircraft - Electric - Airplanes (FS/W) 5 Apr 17, 2016 04:11 PM
For Sale E Flite Pawnee Brave Night Flyer BNF haliotis Aircraft - Electric - Airplanes (FS/W) 0 Apr 08, 2016 02:09 PM
Wanted E-flite® Pawnee Brave Night Flyer xlrDALLAS Aircraft - Electric - Airplanes (FS/W) 0 Feb 23, 2016 10:05 AM
