Aug 06, 2015, 02:33 AM
ChuckTseeker's Avatar
New Product
E-flite® UMX™ P3 Revolution
UMX P3 Revolution BNF Basic
http://www.e-fliterc.com/Products/De...=EFLU5050#home
Key Features
Ultra-lightweight, fully assembled airframe
Mike McConville design for aggressive 3D flight
Advanced AS3X® technology delivers rock-solid handling
Exclusively licensed model by Skip Stewart Airshows
High-speed BL180, 3000Kv outrunner motor (installed)
Spektrum 3-in-1 Receiver/BL ESC/AS3X unit
Authentic Skip Stewart Airshows trim scheme
Industry-leading Spektrum™ DSMX® 2.4GHz technology
(4) Performance linear long-throw servos (installed)
Proportional 4-channel control plus steerable tail wheel
Easy-access forward battery hatch
Overview
The E-flite® UMX™ P3 Revolution biplane is a Mike McConville adaptation of the unique aircraft designed for Skip Stewart Airshows. An exclusive E-flite model for this size class, it delivers 3D maneuvering capability with the stability of AS3X technology.
A Highly-Tuned Bipe with an Exclusive Look
An inspiration, an adrenalin rush, an entertainer—Skip Stewart has redefined what a high-performance air show should be with an internationally recognized level of showmanship. Together, Skip and his aircraft form a sentient combination that seemingly make air and gravity bend upon command. The radical design of the P3 Revolution aircraft is laser-focused on giving Skip a giant performance leap in all dimensions.
The E-flite® UMX™ P3 Revolution biplane is a Mike McConville adaptation of the unique aircraft designed for Skip Stewart Airshows. One glance at its tapered wings and contoured fuselage proves that nothing about this biplane is typical. Enormous control surfaces allow the P3 to execute blinding gyrations and the authority to deliver 3D maneuverability at your command. But no matter how you fly, innovative AS3X® technology makes this air show original perform as if you’re at the controls of a giant scale machine that’s been expertly tuned. And even though every aspect of its outline poses new dimensions of performance and maneuverability, you’ll have fun showing it off even if the maneuvers you execute are as simple as a loop or roll.
AS3X® Technology
The advanced AS3X® (Artificial Stabilization – 3-aXis) system built into the Spektrum™ 6-channel ultra micro receiver is what helps give the E-flite® UMX™ P3 Revolution biplane an incredibly solid look and feel in the air. It’s an impressive flight experience that will have you feeling like you’re at the controls of an expertly-tuned 3D machine that’s much larger.
Authentic
The UMX P3 Revolution is produced under an exclusive license with Skip Stewart Airshows and delivers Skip’s un-mistakable trim scheme.
Exceptional Control
Genuine Spektrum™ electronics include the great holding power of patent pending ultra micro performance linear long-throw servos and industry-leading DSMX® 2.4GHz technology.
Expert Design
World-class aerobatic pilot, Mike McConville, worked closely with the full-size P3 designers and adapted the unique P3 Revolution biplane to deliver a UMX design with outstanding handling for its class.
Product Specifications
Wingspan: 16 in (523mm)
Overall Length: 15.8 in (400mm)
Wing Area: 85 sq in (547 sq cm)
Flying Weight: 3.03 oz (86g)
Engine Size: 180-size, 3000Kv Brushless Outrunner (installed)
Radio: 4+ channel Spektrum transmitter required
Recommended Battery: 7.4V 200mAh 25C LiPo
Needed to Complete
Requires a 6+ channel transmitter with Spektrum DSM2®/DSMX 2.4GHz technology, 200mAh 2S 7.4V Li-Po battery (EFLB2002S30 recommended) and a suitable charger.
UMX™ P3 Revolution BNF Basic (2 min 30 sec)
Aug 06, 2015, 02:38 AM
Flyer81
this looks good I was going to buy the pitts but may wait
Aug 06, 2015, 02:44 AM
oops wrongway
AlfaMike's Avatar
Ooooohhhh!!
Aug 06, 2015, 03:44 AM
chulian1819's Avatar
vs BEast 3D:
cons:
-weights more
-less wing area
-bigger wingspan
pros:
-stream lined
-no wing lines
-engine 3000kv (vs 2500kv in the beast, but a simple engine replacement will do)
Aug 06, 2015, 03:51 AM
RAFMAA
I just restored a UMX Beast! Looks like il be adding this to the micro hangar
Aug 06, 2015, 07:18 AM
addictedtoplanes's Avatar
I thought for a second that Eflite released a Lockheed P-3 Orion. XD Guess not
Aug 06, 2015, 07:32 AM
I just had a look at the pics on the Eflite website, and it looks like the wings and tail surfaces are molded foam, like on the 280 Edge Inverza and Viking, not stamped foam like on the UMX Beast...Wing is thicker. I like it!
Aug 06, 2015, 09:01 AM
I'd rather be flying!
turboparker's Avatar
Now THIS looks interesting! I've had the pleasure of watching Skip perform his routine in person a few times. Jaw-dropping is an understatement!
Joel
Latest blog entry: Landing tutorial
Aug 06, 2015, 09:06 AM
Custom User Name Title
bhoov128's Avatar
Ridiculously cool... I'm in!!
but.... the ugly prototype one and not Prometheus?
Oh well looks like UMX gets more of my cash
Aug 06, 2015, 09:11 AM
Extremely Twisted
Eagle2Nitro's Avatar
It is kind of ugly, but does look pretty 3D-able, with the huge control surfaces.
Aug 06, 2015, 09:17 AM
Yeah - those were my thoughts, as well. A bit of a head-scratcher. No biggie though. One of these will definitely end up in my hangar anyway!
Just think - pretty much any maneuver that the UMX version can perform would be considered 'scale'.
Joel
Aug 06, 2015, 09:20 AM
BryanEW710's Avatar
I think I'd still rather have a Yak-54. Bipes are just too fragile-looking for me.
Aug 06, 2015, 10:10 AM
The P3 does have fully molded wings/fin/rudder not stamped. It has huge power and huge 3D throws. Its a blast to fly. (video is in proofing now).
Were lucky enough to have a Semi-Exclusive license for the P3 (exclusive to the hobby industry except for the very large scale composite P3 made by Weimo) and have worked closely with Skip on this.
The Full Scale P3 is in the works. Just saw photos of the the fuselage fresh out of the molds two days ago.
The P3 does promise to be the next generation in aerobatic biplanes!
Aug 06, 2015, 10:14 AM
Extremely Twisted
I want to see the video.
Aug 06, 2015, 10:20 AM
bhoov128's Avatar
well jeez thanks for chiming in I'll reserve judgment on whether you did a good job until after I fly it
(kidding of course, you did a good job because I'm going to buy it!)
Sold E-flite® UMX™ P3 Revolution bnf iceeman32y Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Mar 20, 2017 01:08 PM
Sold E-Flite UMX P3 Revolution NIB cbk07 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Oct 16, 2016 09:13 AM
Sold E-Flite UMX™ P3 Revolution BNF Basic edge_pilot Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jan 09, 2016 02:32 PM
Sold E-Flite UMX™ P3 Revolution BNF Basic edge_pilot Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jan 01, 2016 07:03 PM
Video NEW E-flite UMX P3 Revolution DominicM 3D Foamies 2 Oct 03, 2015 10:01 AM
