Hey there...
Just a quick question about the Tornado FC ... is there any kind of manual or a Pic for the Pinouts? a other one is... if i wana use RGB LED's, the 500mAh Pololu is a bit week for it i guess... i guess it is possible to solder this one on it right? https://www.pololu.com/product/2831 |
Soma/FGA/Flits/Strepto - Can we have some pretty build pics of your rigs to keep us going until we get our toys?
Hi guys
Some pages back, few of you discussed about this light tx, did you tested it, it is a good tx? http://www.surveilzone.com/TS5828-58...FPV-SMA-g-1368 Thx |
For those wanting to shrink down the Immersion 600mW here is one way.
Carefully remove connectors |
That was a lot to read through!
I have used a Xacto razor saw to cut off connectors, multi-pin, SMA, etc. Then it is easy to de-solder the remaining pins. |
Get a Hacksaw Blade, grind the offset in the teeth flat so they are the same
as the rest of the blade thickness or slightly narrower. Use a grinder / linisher etc. Keep this in a safe place, once you have one you'll use it a LOT ! ( NOTE: Dip in water as you go,, Don't let it go blue or it will anneal, go soft. ) You now have a high quality tool that is as good as a File that does very fine cuts. Carefully saw 95% of the way through the 2 or 4 prongs (Gnd Tabs), then gently crack them without stressing the centre (active element wire) connector. Un-solder the active element and the whole thing should come away. You are just left with the stubs of the connector, which will easily come off now with a little heat and a wipe of the soldering iron. DON'T try the shortcut of snipping the prongs with cutters or you may shatter the tracks off the PCB. It will only be good as a paperweight then, and not a very good one at that Good Luck. BTW the same blade is ultra excellent for cutting slots into Foamies to add 1x3mm carbon reinforcing strips etc. It cuts like a LASER. Added: you don't need to do the entire length, just 3" to 4", 100mm or so. |
