Aug 03, 2015, 02:14 PM
Kate O'Neil's Avatar
New Product
Castle Creations Mamba Monster X Extreme Power System
First, there was the Monster. Then the Monster 2. Now there’s the Monster X.
As revolutionary as it’s predecessors, the new Monster X Electronic Speed Controller (ESC) takes Castle’s legendary “monster” performance to a whole new level. The waterproof* Monster X is capable of 2S LiPo up to a maximum of 6S LiPo and is the legendary “power up” for 1/8th scale buggies, truggies and on-road vehicles as well as 1/10th scale monster trucks and R/C monstrosities weighing up to 15 lbs.
Features:
* Programmable Auxiliary Wire that allows you to make “on-the-go” adjustments to several settings, such as torque control and max throttle, right from your transmitter!
* Sensor Support for sensored brushless motors (with the purchase of an optional Sensor Harness from Castle Creations).
* Data Logging to capture and record performance data from your last couple of runs.
* Telemetry Ready - Compatibility Coming Soon for Futaba T4PX Transmitters
* Heavy-duty adjustable Battery Eliminator Circuit (BEC) to provide plenty of power for today’s power hungry servos.
* Extreme ESC and Extreme Combos - The Mamba Monster X is available as an ESC only or in combination with Castle’s award-winning 15XX Series brushless motors; the 1515 2200KV or the 1512 2650KV motor.
Input Voltage Range: MIN: 2S LiPo; MAX: 6S LiPo (25.2V)
BEC Specifications: Adjustable: 5.5V, 6.0V, 7.5V. or 8.0V (8A Peak)
On/Off Switch: Yes, waterproof *
ESC Cooling Fan: Yes, removable and factory equipped (30mm)
Size: 5.3cm x 4.9cm
Weight (w/wires): 111.1 g
Application Guidelines ESC: Intended for up to 6S (25.2 Volt) operation in vehicles weighing less than 15 lbs, with batteries, ready-to-run.
Application Guidelines 2200kV Motor and ESC Combo: The ESC and motor are intended for up to 6S (25.2 Volt) operation. Incredible in monster trucks with up to 6S LiPo packs (4S LiPo is the sweet spot), and works great in 1/8th buggies and truggies and on road as well. (vehicle weight limit is 15 lbs or less, with batteries ready-to-run).
Application Guidelines 2650kV Motor and ESC Combo: The ESC and motor are Intended for 4S (16.8 Volt) operation in Buggy and On road vehicles weighing 9lbs or less with batteries, ready-to-run.
Look for the Castle Mamba Monster X at your favorite R/C retailer!
http://www.castlecreations.com
