Aug 03, 2015, 11:33 AM
FPV Dealer,Getting People High
Johnnymeg's Avatar
New 2015 Dominator HD V2 and Dominator V3
**I will Be Updating the first page Often**
Hey guys we got to check out the new line up for the fall of 20115. Not much in terms of "NEW" Products but some really cool upgrades and fixes to existing products .
Fat shark isn't very creative with the names but here are the big hitters and the noticeable changes to them.
Dominator HD V2
Dominator V3
"Attitudes V3"
New ATTV3 is in production! Moved the beautiful DOMV2 optics into a new modular designed ATTV3 and added 3D interlaced support! FPGA programming fills in frames and lines to give equivalent 2D image quality with an interlaced 3D camera making this a FPV race friendly headset (no need for a dual transmitter/receiver that hogs the 5G8 band). Modular design so all the Fat Shark receiver modules and frequencies are available.
3D interlaced camera will release soon after.
Changes...
An in-depth review
Review of the FatShark Dominator HDV2 Vs V3 (27 min 7 sec)
Team-Legit interview the Great White Shark (4 min 38 sec)
Johnnymeg's Avatar
Edit 8/19/15
Fat Shark Dominator HD V2 First Look (10 min 45 sec)
Fat Shark Dominator HD V2 First Unboxing (7 min 50 sec)
Dominato HD2 Specs:
Cost= $520=540 (Estimate)
Expected Release= End of August 2015 (Estimated)
DominatorHD2; The world’s best FPV goggle. The DominatorHD2 once again assures Fat Sharks’ dominance as the premier FPV goggle manufacturer. With its large FOV SVGA resolution image, modular design and integrated DVR, the DominatorHD2 is the undisputed champion of the FPV world. With the DominatorHD2 you no longer have to sacrifice image quality for image size. The DominatorHD2 not only has the highest resolution display of any commercial video glasses (SVGA 800X600), but also the largest field of view (50 degrees diagonal). Components and features were chosen as only an FPV purest would; glass optics were chosen over plastic because image quality and large FOV could not be compromised on. A DVR was built in not for the enjoyment of watching movies but for the purpose of recording the video down link and telemetry data to help with lost model recovery. HDMI input was implemented to ensure forward compatibility with the inevitable digital HD links. The DominatorHD maintains the modular docking ports for back compatibility with existing RF modules.
The Next Generation in Video Goggles. The Dominator HD provides amazing vide quality when paired with HD downlinks or direct connect. These goggles also provide HD 3D image when paired with compatible devices.
Includes:
3m AV cable
HDMI cable with mini to micro and mini to standard adapters
1800mAh Battery w/LED indicator
Battery charge adapter
Zipper carry case
DC DIY cable
Manual
http://team-legit.com/product/fatsha...s-coming-soon/
Johnnymeg's Avatar
Edit: 8/12/15 release price for dominator V3 $350 we will have a preOrder for them when they are released next week.
Dominator V3 specs:
Cost= $350
Expected Arrival - End of August (First Batch) Early September (Second Batch)
DOMV3 pilot production has been completed. We already successfully ran about 30p to check assembly and function. Some minor tooling changes were needed (been completed) and a limited initial production of 200p is scheduled for completion Aug 10th. This limited production will get divided among the top retailers. Full production will start after Aug 21st. I don't really expect retailers to be able to keep regular stock until end of September. Here's some major points:
- Goggles ship with white fan faceplate, 1800mAh LED indicator battery and HDMI cable (mini-mini with mini-micro and mini-standard adapters).
- does not include receiver module or head tracker (however Raceband RX is inexpensive and there will be price reductions on the head tracker module).
- Release price will be $349 (but can expect this to drop around $20 in following months).
- display is 800X480 30 degree FOV and supports side/side 3D.
- HDMI support up to 720p (verified works with Lightbridge, DJI Inspire, Phantom3 with HDMI upgrade, Parrot Bebop and Connex).
- big improvements on the DVR; DVR can now autodetect and switch on the fly between NTSC and PAL (no more split screen). DVR is equipped with supercap to provide enough power to close files should the battery be removed before pressing stop record.
- DVR records analog only (does not record HDMI sources).
Includes:
3m AV cable
1800 mAh battery with LED indicator
charge cable adapter
Zipper carry case
DC DIY cable
Manual
http://team-legit.com/product/fat-shark-dominator-v3/
First Unboxing of The FatShark Dominator V3 Goggles (10 min 8 sec)
New Dominator V3 Behind The scenes Look (5 min 44 sec)
ADDED Attitude V3 Goggles
FatShark Attitude V3 Unboxing (5 min 30 sec)
Aug 03, 2015, 02:02 PM
Team Warpsquad
Mr.Aaron's Avatar
Awesome johnny, thank you for the videos and look forward to hearing your thoughts on your HD sample as I'm interested in them myself.
Aug 03, 2015, 02:08 PM
I call dibbs on the samples when done with the review. Looking forward to the reviews as well, thank you for doing them.
Aug 03, 2015, 03:44 PM
DareDevil
6KillaBC's Avatar
Excellent thanks for posting this, was going to buy the first V2's, but will wait for these now.
Aug 03, 2015, 06:02 PM
attomik's Avatar
Its August!
Aug 03, 2015, 10:08 PM
QuAd FaNaTiC
Razors edge 29's Avatar
I hope price is right
Aug 04, 2015, 12:22 AM
I've seen the 1st video before, what updates are there on the Dom V3? is it mainly the built in fan?
Aug 04, 2015, 01:46 AM
DareDevil
6KillaBC's Avatar
Same...just hope they wont be like apple and release new models every few months.
Aug 04, 2015, 02:39 AM
Johnnymeg's Avatar
The screen is wider now with 16.9. They accept hdmi in now and can run 3d. The fan is now standard on all new dominator goggles. More specs and unboxings coming we have more informal review of the dominator V3s coming out. Mostly behind the scenes and testing.
Aug 04, 2015, 08:29 AM
USA: LakeGeorge, New York
Johnny,
I'll order the DomV3 from you, (non-HD).
Just let me know when.....:-)
P.S.
30 degree FOV?
Latest blog entry: My FAVORITE FPV CockPits'!!!!
Aug 04, 2015, 09:27 AM
I'm looking forward to the new HD V2, I was worried when the original HDs were discontinued.
Aug 04, 2015, 09:33 AM
I agree... but honestly I was really hoping they would make a set with diverisity.
Aug 04, 2015, 11:57 AM
attomik's Avatar
Yes
