Jan 27, 2004, 10:29 AM
Josh,
Both static and heat can damage fets , if you cant find any other reason then maybe it is the fet .
What are you powering the Tx with ? if the battery isnt capable of delivering the required current the signal will suffer .
I have 6 off 800ma NiMh pack in mine .
Stewart
Jan 27, 2004, 10:47 AM
Josh,
I can't view your images. I get redirected to the server "phvrf.yahoo.com" which doesn't appear to exist.
D.
Jan 27, 2004, 02:27 PM
Thats NOT indestructible
j8m8l's Avatar
Sorry guys.
The pics should work fine now, I was having trouble hosting them with Yahoo.
Stewart.
It is running from a 700mah NICAD, this should be able to handle the current of the 5 LED's.
Could one damage the mosfet in such a way that it still worked, just not fully/properly?
Josh.
Jan 27, 2004, 03:48 PM
You're not using a 12F6XX for the TX are you?
Some nice work btw.
D.
Jan 27, 2004, 04:12 PM
j8m8l's Avatar
Thanks.
Thats the IR Transmitter v.2 (attached to a Sanwa VG600, I have just bought a RD8000 for when I get it all working ).
I was hoping that the I could avoid the excess resistors and transistors by using a mosfet (was a wrong !).
Josh
Jan 27, 2004, 06:16 PM
jberg's Avatar
Josh,
you can use one mosfet for all leds, but you still have to use one current limiting resistor in each line of leds!
Regards, Jochen
Jan 27, 2004, 08:57 PM
Odd, I didn't. I have 8 LEDs in a 1x8 parallel array attached to an IRFD123 mosfet with no limiting resistors (other than 1 between the PIC and gate pin). Average (measured) current draw is only 30 mA @ 9.6v (tho that may be a bit higher at this high a frequency). I believe Koichi mentioned that the LEDs are off 99+% of the time, which would somewhat explain the low averages I'm measuring. At the current and duration, the peak current should be well below the LEDs peak capabilities. No burnouts according to my digital camera...
Has anybody else measured the current draw on their LED array? The IRFD123 has an Rds of 0.4ohm, so I don't think that's limiting current flow. Vg is 4v, but the PIC should be outputing square pulses, so it shouldn't matter.
Odd.
D.
Jan 27, 2004, 10:04 PM
KevinMc's Avatar
Hi all,
I've been lurking in here for a few months now and just recently got off my duff and started building. Having just finished off my transmitter, I guess I'm just about at the same point as Josh (j8ml8). I also noticed a drop in voltage on the rails of the LED board (which I separated from the encoder section). I eventually clued into the fact that this was probably due to chokes in the lines of the trainer port of the Tx that were reacting to the immediate demand for current when all the LED's were switched on. (Good design for EMI, bad for us.) My recourse was to put a BFC across the power rails on the LED board and it made a world of a difference. (Attached is an after shot of my rails.)
Jan 27, 2004, 10:06 PM
KevinMc's Avatar
Here's the Tx setup, not the BFC hanging off the LED board.
Jan 27, 2004, 10:19 PM
KevinMc's Avatar
And another scope grab of the voltage across one (of five) LED current limiting resistor, which on my board are only 0.5 ohms. Although almost all of what I've built has come straight from Koichi's web pages, I found that the current limiting resistors specified were consuming too much power, and as a result I dropped the value to get a reasonable peak current flow. Calculations based on the attached plot indicates that I'm seeing a peak of 700ma through each LED branch. (My network is a 5p x 5s array, with a current limiting resistor for each series branch.)
The one thing that I'm noticing is that my array now gets warm. (No doubt from the increased current flow.) Has anyone else experienced this?
BTW, very large "Kudos" to Koichi, Andy, and all the rest of you that have contributed so much to this thread.
Jan 28, 2004, 05:37 AM
j8m8l's Avatar
Jochen.
I do have one resistor for each series "line" of LED's !
KevinMc.
That looks like the problem I have.
I will try a 220uf across the power lines for the array (BFC?)
I will measure the current with the 10ohm, and adjust from that.
Josh.
Jan 28, 2004, 07:55 AM
KevinMc's Avatar
Josh- BFC: you got it!
Jan 28, 2004, 08:09 AM
j8m8l's Avatar
Thanks Kevin.
I will solder this up when I get home and hope for the best !
BFC - Big Fat Cap ?!?
Josh
Jan 28, 2004, 08:46 AM
KevinMc's Avatar
Josh,
The "F" has so many possibilibities, but you're on the rignt track...
(Freakin' was always my preference.)
KM
Jan 28, 2004, 02:11 PM
j8m8l's Avatar
I have added the cap and tested again (with the proto rx).
Reception still seems erattic.
I will scope it tomorow (If I get to school, its snowing and the last time that happened London shut down !).
Would'nt the simplist solution be to tap power straight from the battery (Y lead or similar ?).
Josh
