Dec 23, 2002, 11:23 AM
Great work Koichi!
I thought the DigiQ motors were similar in size to the BitChar-G motors (1.55 g)? Aren't they about 6 mm in diameter?
If you are correct and the DigiQ motor weighs only 700 mg, then I'll need to get some of those!
-David
Dec 23, 2002, 11:53 AM
jberg's Avatar
Koichi,
really great work!
Am I right when assuming that to do something similar to your solution one would have to rebuild your infrared transmitter addon, then identify the encoded binary signal path in the transmitter and hook up the addon to that signal. Your PIC code would then generate the 38kHz infrared signal.
To receive this signal I would try to put a pair of infrared detectors to the signal input of Andy Birkett's decoder PIC.
Andy, Graham, what do you think?
Regards, Jochen
Dec 23, 2002, 12:00 PM
in pursuit of low wing loading
Gordon Johnson's Avatar
Koichi,
I'm even more impressed. You took the trouble to lighten the Didel 81t spur gear by making it have spiral spokes instead of just circle lightening holes. How much weight did that save?
It also looks like you made your own rolled balsa fuselage tube.
It looks like your prop was boiled balsa formed over a mold, rather than carved. Am I correct?
Very impressive indeed!
Gordon
Dec 23, 2002, 09:52 PM
Koichi Tanaka's Avatar
The weight of a DigiQ motor was mistaken. It was 0.9g surely.
It is gear unit 0.8g + motor 0.9g = 1.7g.
Length is short although the diameter of a motor is the same as the thing of Bitchar-G at 6mm.
fuslage rolled and made 1mm balsa.
A propeller is made from a balsa block.
The balsa of specific gravity 0.1g/cm3 is used and the dope which thinned is applied.
PIC which I made operates by 38kHz.
Dec 25, 2002, 05:42 AM
Las Vegas Realtor
Inari's Avatar
Tanaka san,
Hikoki wa utsukushii desu! This is a beautiful design. I particularly like the prop and the quick-change power unit idea using magnets.
John Brassner
AMA 84036
http://www.inarico.com/misc/rc
Dec 28, 2002, 06:00 AM
jberg's Avatar
Hi all,
I will give Koichi's concept a try. The tx PIC code is working already connected to the teacher/learner plug of my Multiplex Pico Tx. Infrared parts arrived today. I plan to combine Koichi's tx addon with Andy Birkett's rx PIC code.
I'll keep you informed.
Regards, Jochen
Dec 28, 2002, 06:11 AM
Thats NOT indestructible
j8m8l's Avatar
Has Koichi given out his code/schematics?
Josh
Dec 28, 2002, 06:33 AM
jberg's Avatar
Josh,
yes, it is on his page (the link is on the first page of this thread), and if you filter the page through http://babelfish.altavista.com then you will get a funny but readable translation.
Regards, Jochen
Dec 28, 2002, 07:42 AM
j8m8l's Avatar
Coool
I wish i was good enuf at electronics to make that!!
Josh
Dec 28, 2002, 04:00 PM
jberg's Avatar
It WORKS! :D
Hi all,
just some minutes ago my infrared system worked the first time on the bench.
In the picture from left to right:
- The transmitter addon, fits to the learner/teacher socket of my Multiplex Pico Tx (crystal can be removed)
- My programmer/tester board with an IR sensor and a PIC processor with Andy Birkett's code in it.
It works on the bench, now I have to make an RX with a SOIC version of the PIC.
Now my costs per rx (excluding DC booster and ESC) go down from 33 EUR to 3,50 EUR.
I'll keep you informed. Thank you very much, Koichi!
Regards, Jochen
Dec 28, 2002, 04:07 PM
j8m8l's Avatar
Jberg
Some questions
Could that be used with the Z-tron RX's?
How many IR emitters are u using ?
Cant the ESC code be written into the pic?
Do you need the Dc-Dc?
Can you make me one ?
Josh
Dec 28, 2002, 04:09 PM
j8m8l's Avatar
Hey
My bst m8's mum is Japanese, and his dad speaks/reads it, would you guys like me to see if he will translate the nessecary pages for us?
Josh
Dec 28, 2002, 04:44 PM
jberg's Avatar
Josh,
ZTron: don't know, Graham? Mark? Andy?
emitters: 4 up to now, more to come (depends on flight tests)
The ESC code *is* in Andy's PIC code.
DC/DC: Yes, the IR sensor needs 5V, and the coils are stronger at 5V. There are only 4 parts, very small and light (switched capacitor)
At first I will make *me* one (a flyable one), then we will see!
Yes, ask your friend's dad (and perhaps we ask Koichi?)!
Regards, Jochen
Dec 28, 2002, 04:49 PM
j8m8l's Avatar
jberg
i am feeling stupid today
Can you explan how andys code fits into all this?
Josh
Dec 29, 2002, 04:39 AM
jberg's Avatar
Josh,
that's very easy: The signal that the IR sensor generates is directly fed into a PIC chip containing Andy's code, and the coil connectors are directly coming out of this chip, as is the connector to drive the ESC MOSFET gate. This system is *very* similar to a ZTron receiver.
The good and new part is that every thing is publicly know now so that you can make the complete system yourself (tx and rx).
Regards, Jochen
