Oct 19, 2016, 12:08 PM
biomecanoid's Avatar
Can you guys post the items that you have managed to break so we make a rough list ?
Oct 19, 2016, 01:00 PM
Originally Posted by biomecanoid
Can you guys post the items that you have managed to brake so we make a rough list ?
I think that rear plastic transmission should be 1st on list, especially if you have brushless setup
Sent from my Nexus 5X using Tapatalk
Oct 19, 2016, 01:04 PM
Also I have been noticed that with alu upgrades car is little heavier in front than before which should be fine for handling at higher speeds
Oct 19, 2016, 02:41 PM
[QUOTE=rchrist;35995315]Take it apart and double check your setup. Watch the movement and the angle of the moving parts and look for binding issues. Slacken back on some screws to see if something frees up. Only the rockers I've put on so far with no issues.
Fixed
[ATTACH]
Oct 19, 2016, 03:21 PM
Slideways at warp speed.......
kiwi_craig's Avatar
I'll ask the question again, how many people have actually stripped a transmission gear set ?
Oct 19, 2016, 03:49 PM
Originally Posted by Alexsasax
Fixed
What was the issue with that part. I've got two to put on.
Ric...
Oct 19, 2016, 04:13 PM
Ric...
I had to remove a bit of the area that is touching each other
Oct 19, 2016, 04:18 PM
Thanks, will keep that in mind for my install.
Ric...
Oct 20, 2016, 02:08 AM
I guess you mean there right ? :
Front
http://www.banggood.com/Feiyue-FY-01...l?rmmds=search
Rear
Does the front break easily ?
Oct 20, 2016, 02:12 AM
Some updates from my FPV built. Finished two FPV trucks now. So much fun. Here are some pics from this weekend.
Oct 20, 2016, 02:27 AM
Front
Rear
Don't know for frontal ones but I damaged rear one. It wasn't broken, it was deformed and really hot. But like kiwi_craig wrote maybe it was lonely case. Last week guy uploaded on yt when he broke metal one with 3s And yes, that's parts I ordered
Oct 20, 2016, 02:29 AM
Plain matte black is very good very serious looking. So did you just scrape the paint of the original and paint it ?
Oct 20, 2016, 02:46 AM
OK i will put front and rear transmission on the order list
Lets see what others have to say, what other parts did they manage to break.
Since i am waiting for the missing pinion gear from banggood i may as well order upgraded parts for the ones that break.
Oct 20, 2016, 01:15 PM
Brake Weight's Avatar
@ flyandi
Where did you get the LED insert lights for the light buckets?
Oct 20, 2016, 01:20 PM
You mean the actual LED lights? Those are standard automotive LED's.
http://amzn.to/2eya688
The LED's are not glued into the holders and can be removed by bending the legs. They have 470k resistors soldered to them so they can receive anywhere between 6V and 15V.
