Mar 09, 2017, 05:04 AM
Scale Feiyue fy-03 at my prototype DIY Dyno.
All electronics are stock 22t pinion
DIY RC Dyno 1st test run (2 min 7 sec)
Mar 09, 2017, 07:08 AM
Adakar's Avatar
Originally Posted by ican3d
What size? 1.9?
Hi
nope same diameter as originals but wider
Cheers
Mar 09, 2017, 08:24 AM
biomecanoid's Avatar
Originally Posted by FrancaRC
Try this one:
http://www.banggood.com/Corona-CS238...4699821201605X
My friend have it and its very good
Just received and installed this Corona servo on my Feiyue and its much better than the upgraded servo banggood suggests. Installation was very easy i just screwed the servo in-between the provided holes of the mount basically making a third hole as i was screwing. I consider this servo a direct replacement
Did a test run and the car can keep straight lines easier now. Do you think i should install the gyro again ? last time my servo died when i was using it.
Thank you Franca for the suggestion
Mar 09, 2017, 10:25 AM
Your Welcome and i am happy for help You
Mar 09, 2017, 12:01 PM
Do you think its safe to install the gyro again ?
Mar 09, 2017, 01:20 PM
I think u can use gyro since that servo is analog.
Sent from my Nexus 5X using Tapatalk
Mar 09, 2017, 01:26 PM
You mean there is an issue with digital servos ?
Mar 09, 2017, 04:11 PM
Embargo lifted.
kenstogie's Avatar
Originally Posted by Brake Weight
High turn/slower brushed motors are hard to find. The only options really are putting a small pinion gear or a low kV brushless motor. 2000ish kV motor would be fairly slow.
thanks ☺
Mar 09, 2017, 06:19 PM
Slideways at warp speed.......
kiwi_craig's Avatar
good to hear the corona is a step up, must get mine fitted !
love the mini dyno , very cool !
Mar 09, 2017, 06:26 PM
Very easy to install too, you just make a 3rd hole between the 2 existing ones. At least that's what i did.
Also the corona servo sounds very well, has a healthy working sound to it.
The "upgraded" servo suggested by banggood always sounded weird and had noises coming out of it even when it was centered, sitting still and not working. Weird
Mar 09, 2017, 06:29 PM
They are best but don't handle any binding..
Mar 09, 2017, 06:31 PM
What do you mean by binding ?
Mar 09, 2017, 07:00 PM
kiwi_craig's Avatar
I suspect the gyro will be better suited to the analogue servo with its lower refresh rate
Mar 09, 2017, 07:53 PM
ultra cheap pilot
ican3d's Avatar
Originally Posted by Adakar
Hi
Cheers
Those wheels looks really good on FY03, awesome!
Mar 10, 2017, 02:22 AM
Steering parts must move freely without friction. This car have flexible chassis wich can cause some friction.
