FEIYUE - FY03 Desert Eagle aka look like Twin Hammer rock racer
UPDATED 23 August 2015
My extreme rock crawling action video, dirt ride and FPV cockpit driving too. [B]My written article about FY03: https://www.supermotoxl.com/projects...oad-truck.html Video:
__________________________________________________ _______________ In-Cockpit FPV driving: Update: 12 June 2016 (FY03 FPV cockpit scaling) ![]() ![]() ![]() ![]() ![]() ![]() ![]() Rock crawling action and dirt power!: ![]() ![]() ![]() ![]() ![]() ![]() __________________________________________________ __________________________________________________ ___ UPDATED 18 August 2015 My baby arrived!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! woooooooooooooohoooooooooooooo!!!! I just updated more on my FY03 gallery here at my website for those who interested to see more in details. Cool. Click here to view the gallery. Videos:
Photos: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() __________________________________________________ _______________________________________________ UPDATED 19 August 2015 More stunning details: Photos: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() __________________________________________________ ______________________________________________ ...... Hey guys, Anyone recently bought this 1/12 scale rock crawler/racer: FEIYUE - FY03. Mine is on the way. Care to share your stuff if you have it. I bought it because it looks so 'mechanically' tempting and cheaper version of Vaterra Twin Hammer. Originally way planing to get 1/10 version what looked like Axial Yeti from either Gearbest.com what looked like under WL-toys but they pull it out last minutes from the shelves. However this FY03 stole my heart. Can't sleep right now as its on it way to my door step. I bought it here at Gearbest.com: FEIYUE - FY03 1/12 4WD Let me know if anyone had brushless mods or reports on durability, drive terrain and etc. I have great future mods awaits for this little gem....mmmmmmmmmmmmmmmmmmmmmm!!!!!!! ![]() ![]() ![]() ![]() ================================================== ============ Parts list updated: 25 July 2017 **************************************** List of parts for FY-03 and compatibles ***************************************** CNCAluminum/metal alloy upgrades: + Steering parts + Steering servo holder + Steering knuckle + Steering 6cm linkages + Front suspension arm + Rear axle arm + 5cm rocker arm linkages + 5cm front shock linkages + Complete set of linkages and pushrods + Universal socket + Axle mounting parts + Front shocks + Rear shocks + Wheel hex hub + Full metal alloy upgrade unit for FY03** + Mid gear hardened teel spur/gear box set (Upgraded/improved) ***************************************** Stock replacement parts/easily worn out parts: ***************************************** Body parts/appearance: + FY03 kit only for custom builders + Body shell/top cage only + Lexan panel/shell cover only + Roof fog lights + Single/front fog lights Parts for "FRONT" chassis section: + Servo saver + Steering linkages + Front independent suspension arm + Front differential gear set + Front full assembled differential gear unit with bulkhead case + Front wheel transmission drive shaft/UJ unit (Improved upgraded version) + Stock front shocks + Stock 5 pin servo for integrated RX unit only Parts for"MID" chassis section: + 1x 26T pinion gear + 3x sets of motor pinion gears + 1x motor pinion gear + Stock 390 brushed motor + Stock plastic spur/gear box set + Mid gear hardened teel spur/gear box set (Upgraded/improved) + Mid full assembled gearbox unit + Mid chassis transmission drive shaft + Slipper clutch disc plate Parts for "REAR" chassis section: + Rear axle full assembled unit + Rear axle plastic axle case only + Rear transmission drive shaft (Improved upgraded version) + Stock rear shocks Others + 12*8*3.5 Ball Bearing set + 9*5*3 Ball bearing set + Wheel hex hubs + Stock FY03 wheels/tyre + Stock Integrated receiver and ESC unit + Generic M4 size lock nuts + Generic ball links ***************************************** Electronics upgrades ***************************************** Servo: + Metal Gear servo 2.8kg torque with 3 pin servo for independent rx electronics(not 5 pins) Radio unit + RADIO LINK RC4G unit combo unit (800~1000m range provided the internal boosterswitched on) comes with steering gyro + Radio LINK R4EH-G receiver for RC4G with internal steering gyro ESC + HobbyWing 60A water-proofed brushed ESC Brushless combo: + Racerstar 2845 Motor Brushless Waterproof Sensorless 35A ESC Combo ================================================== ============ |
If it has 12mm I may look into getting one myself. I just have a hard time trusting no name cheap engrish cars with no parts support.
I would buy the car too but i dont find any spare part dealer for this brand. Not much info too. So im not sure. Will wait your reply ![]() |
Latest blog entry: WLtoys V955 2.4GHz 4 Channel Remote...
Sadly I have no idea what he is saying
Yes, I have one. I run it really tough, a lot of crush and roll over, nothing broken, except two cups of the light bar missing. And the tires are very good quality, grab ground very well. I run it on asphalt road, grass. After two battery, almost no wear out at all. Any question, feel free to ask.
If they are still available I might order one near the beginning of next month
