This thread is privately moderated by ddruck, who may elect to delete unwanted replies.
Jul 25, 2015, 02:10 PM
ddruck's Avatar
Hyperion HP-Z3019-14
Next motor test is very good direct drive Hyperion motor that matches closely the geared Hyperion 2221-3000 with 4;1 gearbox previously tested, unfortunately it has been discontinued, pity.
HP-Z3019-14 specs: 800kv, 400w (30sec 600w no problem), 142g, 2-4S, 5mm shaft
11 props tested here.
All props are Aeronaut unless noted, measured thrust on the bottom of each graph, the high pitch prop thrust, over 10" pitch in this case, is not reliable on bench tests.
Jul 25, 2015, 03:49 PM
Fish are able to fly!
soarerf3j's Avatar
Fantastic job, Dan) Will bring to you same sizes or close of Vitaprop carbon props for testing
Oct 20, 2015, 08:55 AM
Jebera's Avatar
Im good here, just waiting for Vitaprop tests...
Dec 10, 2015, 07:48 AM
Terranozavr's Avatar
thanks for the work you've done!
I do not understand you used gearbox?
Dec 10, 2015, 07:50 AM
Today tested the 3019-14 with 13х4 and 13х8 prop. 4S on the current rising up to 68A
Test in static.
