Thread Tools |
This thread is privately moderated by TechTronic9000, who may elect to delete unwanted replies. |
My BlogJJRC H25G 5.8 Ghz FPV Quad At a glance A new model from JJRC was released in form of the H25G. The particularity of this model is the presence of a complete FPV system beside it's ready to fly experience. The quad sold by GearBest comes with a 2 mega pixels detachable camera, it's own vTX (video transmitter) along with a specially designed remote that includes the vRX and a built in monitor. The camera can also be controlled from the remote, you can select to take pictures or to record video in the same time as you watch where the quad is flying on the scree. The advertised working range is of 200 meters. In depth The JJRC H25G is a brushed quad copter that comes pretty well packed. It's size factor is similar to the much more expensive Phantom series, with a size of 50 x 50 x 18 cm. Also it's weight is around 600 grams which makes it able to be more stable in gusts of wind. The power comes this time from a 7.4 Volt two cell (2S) Li-Po battery that has a capacity of 1800 mAh. In this configuration the quad is able to fly around 10 minutes which is more than decent comparing with older 1S models that were topping 6-7 minutes. You must also keep in mind that FPV system not only adds more weight but also draws more power for the video transmitter. The quad also comes with useful extras included such as propeller guards which can be extremely useful for a beginner pilot. This will not only protect the propellers themselves but also the motors from receiving shocks and will potentiality avoid crashes when objects are hit, like branches, tree trunks, walls and so on. You must keep in mind that they protect but not insure to be crash proof so care must be taken during flight. Other good extras are comprised of a memory card for storing the footage and also a card reader to use it you PC, making this quad more ready to fly but also to use. The complete list of included parts and accessories 1 x Quadcopter 1 x LCD transmitter 4x Propeller (1 set) 4x Propeller guards (1set) 4x Landing gear (1set) 1x Complet screw set 1x Screwdriver 1x Charger 1x 2MP Camera 1x USB Cable 1x 2GB SD card 1x Card reader 1x Manual (English and Chinese) Another included add-on is found in the form of colored LED lights that are installed on each of the arms, making the quad capable to be flown at night or more visible in the daylight. The flight characteristics of the new JJRC H25G quad are given by a 6 axis gyro stabilization system and a flight controller that is also capable of headless mode which makes it a lot more easier to pilot it in the beginning and also a return to home function which will bring the quad back to you in case you can't orient it back. There are also fun functions implemented such as complete 360 degree tricks which consist of flips and rolls to make "cool" video shots and impress friends with them. Full specifications list General Brand: JJRC Type: RC Simulators Features: Radio Control Functions: FPV,3D rollover,One Key Automatic Return,Headless Mode,Up/down,Forward/backward,Turn left/right,Sideward flight,With light,Camera Age: Above 14 years old Built-in Gyro: Yes Night Flight: Yes Material: Electronic Components,Plastic Charging time: About 110min Product Details Remote Control: 2.4GHz Wireless Remote Control Channel: 4-Channels Mode: Mode 2 (Left Hand Throttle) Control Distance: 200m Transmitter Power: 4 x 1.5V AA battery(not included) Model Power: Built-in rechargeable battery Flying Time: 9~10mins Dimension and Weight Product weight: 0.600KG Package weight: 1.360 KG Product size (L x W x H): 50.000 x 50.000 x 18.000 cm / 19.685 x 19.685 x 7.087 inches Package size (L x W x H): 34.000 x 33.000 x 17.000 cm / 13.386 x 12.992 x 6.693 inches Package Contents Package Contents: 1 x Quadcopter, 1 x Transmitter, 4 x Propeller, 4 x Propeller Protector, 4 x Landing Gear, 1 x Screw Set, 1 x Screwdriver, 1 x Charger, 1 x 2MP Camera, 1 x USB Cable, 1 x 2G SD Card, 1 x Card Reader, 1 x Manual ( English + Chinese ) There are currently two availabe colores to choose from GearBest which are RED and Gray. PRO's - Balance charger included instead of simple 7.4V one. - Included prop guards. - Two cell 2S 7.4V LiPo battery - for longer flight time. - LCD monitor built into the transmitter, more durable, less clutter and easier to transport. - 5.8 Ghz band for FPV video signal. CON's - Only 1 set of propellers included. - no longer as mine came with 2x prop sets |
Unboxing of the JJRC H25G quad
Video unboxig, part 1 from the review.
Thread Tools | |
Similar Threads | |||||
Question | Should the build instructions for my plane go in a build thread or in my blog? | Lance Nordby | Sport Planes | 5 | Dec 25, 2015 07:48 PM |
