Jul 30, 2015, 12:41 PM
i will do that thanks
ok ive loaded up the fryskytelemetry example
and the values are wrong on my 9xr pro
how do i fix this i have ersky9x fw, with frsky djt and frsky d8r-ii plus
i commented out everything but gps related stuff and the values are still incorrect
Jul 30, 2015, 06:38 PM
i finally got everything working by flashing my 9xr pro with the latest opentx.
im wondering if there is any bluetooth support for the 9xr pro with opentx
Aug 03, 2015, 12:50 PM
Any chance this library and your S.Port library are on github somewhere, so that its easy to fork changes and/or provide contributions back to you?
Aug 03, 2015, 12:57 PM
Makers gonna make...
pawelsky's Avatar
No, sources will only be published in the relevant threads.
Oct 14, 2015, 12:28 PM
Hi Pawelsky!
Very nice, thank you a million, again. =)
I have not yet tested this, but you have always done terrific work. =)
May I ask one question?
I am a total newbie with Arduino and programming, but I just must ask you..
Do you have any idea how to get the rpm sensor data from a Hobbywing Platinum Pro V3 to your hub?
Its compatible with Mikado V-bar, but have no idea how to implement to Frsky telemetry output..
http://www.sekidorc.com/pdf/Platinum..._en_140213.pdf
So basically just have a serial interface to read the RPM data and convert to frsky protocol and send it to ex. er9x radio?
Can you point me to some direction how to achieve this? Or do you think it needs a HUGE library to convert the data?
I saw that one hobbywing phase sensor people have successfully got working with Taranis, but this is somewhat different.
Any help would be appreciated. =)
- Pete
Oct 14, 2015, 12:53 PM
pawelsky's Avatar
No it doesn't look like a lot of work. You have it all described at the last page of the documentation that you've linked.
Oct 14, 2015, 09:32 PM
Nov 12, 2015, 12:51 PM
Deleted
Dec 02, 2015, 11:54 AM
Anyone, please some help is needed.
I have read a ton of pages of arduino and serial port stuff, but still no data..
Could someone post a simple sample, of working ex. FAS voltage code snippet, just to get started.
All related stuff about the hub is on the sport side and it does not work with the old protocol right?
Dec 03, 2015, 09:53 AM
Deleted
Jan 11, 2016, 11:10 AM
pawelsky's Avatar
I'm afraid there are many errors in your example..
SoftwareSerial mySerial(9, INPUT);
Read SoftwareSerial documentation on how to initialize the serial port, and meaning of the parameters.
BTW, why would you even need the serial port?
fas.begin(FrSkyTelemetry::SOFT_SERIAL_PIN_9);
That makes no sense, check the FrSky telemetry example on how the telemetry initialization shall be done.
if (Serial.available());
What is the purpose of that?
delay(1000);
That is very bad, you should not delay the main loop otherwise you'll lose data.
Serial.read() == SENSOR_FAS)
That doesn't make much sense...
telemetry.setFasData ((float)current, (float) voltage); // Battery voltage & current
You never set current and voltage values so it will always be sending 0 (even if you fix other errors).
Jan 12, 2016, 10:01 AM
Comments deleted.
Jan 12, 2016, 10:47 AM
pawelsky's Avatar
I post my code here in a minute.
Sorry, but I would prefer this thread to not become a place where people throw in their code for review. This library assumes some reasonable level of Arduino experience to use and I've responded to your previous email as an exception only (as nobody responded since beginning of December).
So if you can please help to set up my code to read the data, even one value, like current or voltage from FAS.
This library does not have decoding capabilities (yet) so you can't read the sensor values. You can only emulate sensors.
Jan 24, 2016, 10:45 AM
Variometer mistake
Hello Pawelsky.
I just try your library on a arduino nano with the sample code from the library.
I connect the nano to a D8R II +.
I have a Turnigy 9x with OpenTX with telemetry mod.
All works except I am not able to make the variometer sound working.
I simply modify the sketch to send a new altitude (+3m) evry second.
I see my altitude growing on the 9x screen but no sound on the vario..
I try to use alt or vario as source.. same pb.
When I try to show Vertical speed on the screen it stay at 0.0.
So Is there I didnt understand on the setFvasData vario emulation ??
I dont know if the problem come from the opentx or from the FVAS emulation...
Do you have any idea about ?
Best Regards
Emmanuel
France
Jan 24, 2016, 12:01 PM
pawelsky's Avatar
Originally Posted by manu84
HWhen I try to show Vertical speed on the screen it stay at 0.0.
To my knowledge the vario sensor only returns vertical spead as analog voltage output, so it is not included in the serial stream. There is even no data atg defined to vertical speed in the hub protocol specification.
Unfortunately I do not have the vario sensor nor the data hub to confirm it.
