This thread is privately moderated by Boris B, who may elect to delete unwanted replies.
Feb 23, 2016, 07:33 AM
eL_Verde's Avatar
Originally Posted by Boris B View Post
Thanks amigo
voltage gain is adjustable
max voltage = 1
min valtage (default 3,3) = min adjustment. It is even more than 25%!
When you raise min voltage up you will get less compensation.
BTW in my video i flew with compensation too! I am not sure how naze32 handles voltage reading compared to spfracing.
I also think that vbat compensations helps agains prop wash as the motor gives more constant power during power dips. Those are the main reason of prop wash weid oscillations besides air effect
Super nice my friend!!
max voltage 1
min voltage 0 ?
which is the range? 0-1?
Need tune little bit this point and for me will works super nice, it's a great feature for have all the control since flight
I'm uploading video to youtube for showing here how good works your amazing Betaflight works
Later post it, regards man ! Thank you!
Feb 23, 2016, 08:07 AM
Lets break some props :D
joseico90's Avatar
I'm wanting to upgrade from my SN20 esc's.. but I must admit I'm a bit baffled by the choices available.
Looking at what's coming in terms of what we will be able to run in Khz soon (and now) I'd like them to be at least 6 months "future proof"
My SN20's are running 2.6khz quiet happily with the LUX and 2.4.1 but I fancy something better.
Suggestions?
Feb 23, 2016, 08:22 AM
mrmurder19.75's Avatar
Suggestions?
Irrelevant. Deleted.
Feb 23, 2016, 08:31 AM
Team AlienWarpSquad
max voltage = 1
Nice. Added to Wiki FAQ.
Feb 23, 2016, 08:51 AM
Crash Test Dummy
powdermnky007's Avatar
Suggestions?
WAIT. In a month or two they are releasing Blheli_S escs that will support oneshot42 and have hardware pwm (if my memory serves) which is similar to the new kiss 24a escs. I don't understand all the details, but it offloads some of the work from the MPU to another chip. The end result is supposed to be a much smoother esc, and I guess a more efficient one as well.
I'm holding out until quad mcfly does a few rounds of tests after they come out. However long that is :P I'm still flying 12A escs without the active braking. So if I can wait, you can too
Feb 23, 2016, 09:14 AM
joseico90's Avatar
I'm holding out until quad mcfly does a few rounds of tests after they come out. However long that is :P I'm still flying 12 escs without the active braking. So if I can wait, you can too
Sounds like a plan...
Feb 23, 2016, 09:20 AM
wuzzle's Avatar
This is the single most awesome change in history of Betaflight. (Maybe after airmode PID-authority-handling in high throttle situations)
Feb 23, 2016, 09:27 AM
wuzzle's Avatar
And on a sidenote: My KISS 18A v1.2 seem not too happy about 2.6kHz. After I recalibrated the ESCs and armed for the first time motors did not spin. I then upped throttle al ittle bit and the ESCs/Motors went crazy. I ended up destroying one Cobra 2204/2300kv and four KISS18A v1.2 this way.
So be careful guys when directly applying too fast signals on your old ESCs. Atleast you sould activate fast_PWM and use a slower cycle for those. Maybe this post helps somebody to prevent destroying 100€ worth of parts in an attempt to push the naze over the limit.
Ah well that's what we do for science, isn't it?
Feb 23, 2016, 09:31 AM
I'd rather be flying
QuadMcFly's Avatar
I've got a lead on test units for BLHeli_S ESCs from two manufacturers so far. Looks like it will be at least mid-march before they have them ready. It's coming soon, but it takes time to get all the design done and manufacturing prepped. I'm extremely excited about this!
To better explain hardware PWM vs what happens now on BLHeli/SimonK, it is good to compare it to hardware serial vs software serial in the flight controller. Software serial relies on bit-banging the I/O pins at the right timing through software, vs the Serial hardware UARTS, that are much faster and handle all the output without the processor on the MCU having to do much. It's the same thing with hardware PWM. Instead of having to bit-bang the output on the pins at the right frequency, the PWM perifferal does it all for us through dedicated logic without taxing the onboard processor to manually turn the pins on and off. It just has to send a command to the peripheral telling it what period and duty cycle to run. Very nice to have. I use the same thing to output my PWM/Oneshot/Multishot code on my test hardware that I use in my bench tests, and it makes a massive difference in stability and responsiveness, even in that relatively low load scale.
Feb 23, 2016, 09:32 AM
QuadMcFly's Avatar
So be careful guys when directly applying too fast signals on your old ESCs. Atleast you sould activate fast_PWM and use a slower cycle for those. Maybe this post helps somebody to prevent destroying 100 worth of parts in an attempt to push the naze over the limit.
I was able to run my KISS 18A at 3.8khz with only minor problems at the top of the throttle due to a very high KV motor and very light prop. Other than that it worked fine. My guess is there was something else going on there at the flight controller level.
Feb 23, 2016, 09:34 AM
zenman's Avatar
Hmmm...glad that didnt happen to me. My kiss18a setup on 2.6khz has never flown better. I did not recalibrate mine though.
Feb 23, 2016, 09:49 AM
wuzzle's Avatar
Well I used 2300kv cobras and had NO Prop attached. Other than reduced cycle time I did not change much that could have affected the ESCs. Did you recalibrate your ESCs with 3.8kHz? It only happened for me when I calibrated with 2.6kHz.
Feb 23, 2016, 09:52 AM
eL_Verde's Avatar
max voltage 1
min voltage 0 ?
Here is the test FIGHT on 2.4.1 Betaflight, 2.6khz , PID 1, PID voltage ON, little bees 20 And Naze rev5.
Drone X Labs - Hyper X frame "El verde edition" (2 min 45 sec)
Feb 23, 2016, 09:54 AM
QuadMcFly's Avatar
Yep, I calibrated at 3.8khz. I'm outputting the signal straight from an MCU though, no FC involved. No props probably didn't help, but my guess is something went wrong in the calibration.
Feb 23, 2016, 10:03 AM
When you say calibrating the ESC in 2.6 and 3.8 khz, do you mean FC frequency? If yes, then why does that matter?
Also can someone please explain how fast_pwm is related to looptime and what I should consider when setting them up?
New Product RCTimer OZE32/flip32 AIO Flight Controller ACRO & Pro Discussion Thread rctimer Multirotor Drone Electronics 1425 Jan 17, 2019 05:34 AM
New Product BeeRotorF3 AIO (BRF3) Flight Controller (integrated OSD) Discussion Thread rctimer Multirotor Drone Electronics 1297 Aug 29, 2018 01:09 PM
Discussion Official Drone Registration Discussion Thread **Discussion Here** bansheerider Model Aircraft & Drone Advocacy 4320 Dec 07, 2017 01:53 AM
New Product Discussion thread---FQ777-124C MINI With 2.0MP HD &Switchable Controller BG Well Micro Multirotor Drones 41 Aug 11, 2016 05:51 PM
