Jul 18, 2015, 11:10 PM
Always Building
TheMadCADer's Avatar
New Product
$ 129.99 Eachine Racer 250 FPV Drone Built in 5.8G Transmitter OSD With HD Camera
Its here
$129.99 For a fully built racer
Eachine Racer 250 FPV Drone w/ Eachine I6 2.4G 6CH Transmitter 7 Inch 32CH Monitor HD Camera RTF:
http://www.banggood.com/Eachine-Race...733432201408CW
Eachine Racer 250 FPV Drone Built in 5.8G Transmitter OSD With HD Camera BNF Version:
Additional Flight Controller Options (made specifically for this model):
Naze32 10dof : http://www.banggood.com/Eachine-Race...733432201408CW
F3 Acro 6DOF: http://www.banggood.com/Eachine-Cust...733432201408CW
F3 Racing Deluxe 10D: http://www.banggood.com/Eachine-Cust...733432201408CW
Wiki:http://wikirotors.com/index.php?title=Eachine_Racer_250
***CHEAP REPLACEMENT ARMS:http://www.banggood.com/4X-Original-...733432201408CW***
Description:
Brand: Eachine
Item name: Racer 250
Main wing length: 140mm
Weight: 400g (without battery)
ANTENNA: RP-SMA Male RHCP
Headlight LED: white 3W
Camera: 1000TVL, support for HD night, camera angle is adjustable
Brushless motor: 2204 2300KV
Brushless ESC: Simonk 12A
Flight controller: CC3D
Lipo battery: 11.1V 1500mAh 25C 3S
Transmitter: 600mw 5.8G 32CH built in OSD
Receiver: integrated 6 channel (not included)
Remote control: 2.4G 6 channel (not included)
Flight time: 10-14 mins
Working temperature: -10C to +40C
Features:
Real-time image transmission, automatic search frequency, snowflakes screen, bulit-in OSD (the flight volatge of battery, flight time, current channel).
Carbon fiber, super anti-fall structure.
Easy disassembly quick change propeller device.
Ultrafast flight speed easily manipulated.
Long distance remote control high sensitivity.
Enjoy ignoring crossing barriers.
Manual: http://img.banggood.com/images/uploa...h%20Manual.pdf
Package included:
1 x Eachine Racer 250 FPV Drone
4 x Simonk 12A ESC
2 x CW 2204 2300KV motor
2 x CCW 2204 2300KV motor
2 x black CW propeller
2 x black CCW propeller
2 x white CW propeller
2 x white CCW propeller
1 x mushroom antenna
1 x 11.1V 1500mAh 25C 3S battery
1 x B3AC balance charger
2 x headlight LED white 3W
1 x tail light LED red
1 x 1000TVL camera
1 x CC3D Flight controller
1 x 600MW 5.8G 32CH transmitter built in OSD
1 x remote control strap
Getting Started:
1. Connect your receiver according to the "Receiver Connections" section below.
2. Charge the lipo.
3. Download OpenPilot GCS to your computer.
4. Connect your flight controller to your computer via usb.
5. Have your transmitter, lipo, and quad handy.
6. Complete the vehicle setup wizard to calibrate your escs and configure the flight controller (DO NOT HAVE YOUR PROPS INSTALLED FOR THIS!!!)
7. Click input on the left (transmitter icon). Setup your binding procedure and flight modes.
8. Put on props (front left and rear right motors use CW (clockwise) propellers; front right and rear left motors use CCW (counter clockwise) propellers).
9. GO FLY!!!
Tips/Mods/Useful Information
Vocabulary:
Here is a general glossary from the beginner multirotor section of RcGroups:
https://www.rcgroups.com/forums/show....php?t=2414166
Additional Terms Not Listed:
CC3D - 32bit Flight Controller (FC) that comes installed onto the Eachine Racer 250.
Open Pilot GCS is used to configure the CC3D. More info here https://www.openpilot.org/products/o...trol-platform/
If you would like to use Clean Flight with it:
Cleanflight - How to flash onto CC3D (2 min 43 sec)
Snowflake Screen- A screen effect that is much more preferable than blue/black screen. Basically, instead of completely losing connection when signal is weak, your screen will try to hang on to whatever signal it can get, so you will have as much visibility as possible when your connection is getting worse.
(This will be continuously updated. Let me know if you guys have any word requests)
Receiver Connections:
Originally Posted by DarkAngel74
The wires coming from the FC to Rx are
RBW channel 1 and power
Blue chanel 2
1st yellow channel 3
turquoise are light blue-green channel 4
2nd yellow channel 5
black channel 6
Ch 5. Flight Mode
Ch6. Accessory
If your asking about your RX, sorry..
^^^ I have verified this. My other CC3D clones also follow this setup.
Note: Black wire connects to the outer pin of your receiver and white to the innermost pin for channel 1 of most (if not all) PWM receivers (reversing this can fry your receiver). The singular wires connect to the signal pins of each channel on your receiver (inner most pins on most, if not all PWM receivers).
Always Building
Reserved
Sep 01, 2015, 09:59 PM
Ad Infinitum
Dinamo's Avatar
Will go today to check out this racer. I will try to get some footage of it and share.
Sep 02, 2015, 12:20 AM
Ad Infinitum
Dinamo's Avatar
Preview of the Eachine Racer 250 courtesy Banggood! Enjoy!
Eachine Racer 250 FPV (2 min 34 sec)
Sep 02, 2015, 04:38 AM
is it DSM2 compatible? what receiver does it use?
Sep 02, 2015, 05:43 AM
Always Building
Just updated the first post
Sep 02, 2015, 06:26 AM
SeByDocKy's Avatar
Very interesting .....
Sep 02, 2015, 06:32 AM
Industrial light wizard
panyator's Avatar
Amazing value. Count me in!
Sep 02, 2015, 07:54 AM
rhodesrc's Avatar
Blog team's first glimpse of the Eachine
Here's a few more pics, sadly not in action, we're just teasing at the moment
Sep 02, 2015, 10:02 AM
Ad Infinitum
Dinamo's Avatar
The BNF's version receiver might not be compatible with DSM2 but it can probably be replaced.
Sep 02, 2015, 10:03 AM
SeByDocKy's Avatar
There is a microUSB port too ? (I saw already a serial port)...
What is the defaut receiver wiring ? PWM, CPPM ?
Sep 02, 2015, 10:33 AM
Oh man I want to know more more more.
rhodesrc you say the camera IS NOT adjustable? Just want to check as on the BG description it says it is adjustable by loosening the four screws. Thanks
In general and for anyone. Also would like to know how many channels and which ones the VTX works on and is able to change to.
+1 for wanting to know what receiver type comes with it and what radios it can bind to.
Also what wiring as seby said.
This looks pretty awesome. Would love to test one out Aaron but either way really looking forward to hearing much more.
Oh also wonder what flight modes it has pretuned.
Can't wait for more.
Sep 02, 2015, 10:38 AM
Always Building
I'll be posting a thorough review when it arrives
Looks like the arms are easily replaceable if so that is a big plus. I wonder if the motors have bullet connectors for easy replacement as well.
Are the ESC's built onto the board or separate?
Oh so much to know and talk about.
I see the rtf version looks to include a monitor.
Oh wow I also see it has OSD. Can't wait to see what that shows and how good it is.
edit: Ok rcnewbiechris I look forward to it
wouldn't mind doing a review myself. Haha
Whoops! Eachine Racer 250 FPV Drone Built in 5.8G Tx OSD With HD Camera ARF 129.99 USD CyberX Hot Online Deals 8 Feb 03, 2016 09:53 PM
